The rear upper wishbones angle back quite a bit. Quite dramatic compared to my rover elise. Is that how they get the extra wheelbase? I'd always assumed the pickups were moved.
Project Chill 1
#2381
Posted 05 January 2016 - 08:59 PM
#2382
Posted 05 January 2016 - 09:08 PM
Sorry I can't answer that But I'm sure your rightThe rear upper wishbones angle back quite a bit. Quite dramatic compared to my rover elise. Is that how they get the extra wheelbase? I'd always assumed the pickups were moved.
#2383
Posted 06 January 2016 - 07:20 AM
Actually they angle forward.
The rear suspension pickup points on the subframe are quite a bit further back than on the Rover powered Elises.
#2384
Posted 06 January 2016 - 08:55 AM
Thanks
#2385
Posted 09 January 2016 - 05:33 PM
ive built 95% of the rear up just waiting on some new abs brackets no pics yet but will get some up when its finished but im having a night mare on the upper wishbones getting the castor shims back in along side the two wishbone mounts on each side
the big shims are fine but what were lotus thinking putting them small ones in there almost impossible to line up all 4 with the wishbone and the bolt holes when its blind
then you have to get a bolt through them
and a little side note which im happy about is that ive managed to go from 16 stone 4 to 15 stone 7 since boxing day
#2386
Posted 09 January 2016 - 05:43 PM
#2387
Posted 09 January 2016 - 05:46 PM
By new shims all large from Eliese Parts.[/quotehttps://www.elisepar...ry/71/geometry/
#2388
Posted 09 January 2016 - 05:48 PM
#2389
Posted 09 January 2016 - 05:49 PM
#2390
Posted 09 January 2016 - 07:47 PM
#2391
Posted 09 January 2016 - 08:02 PM
cheers all will get it sorted im sure
#2392
Posted 10 January 2016 - 01:31 PM
And use an old bolt that you grind to tapered point to help align/seat the washers and bushing and then slide the actual bolt in place.
Usually you use the tapered bolt from the reverse side and then push it out as you fit the actual bolt in it's place.
Still is a very annoying job, but it's a little better
#2393
Posted 10 January 2016 - 01:58 PM
#2394
Posted 10 January 2016 - 02:47 PM
what bushing is that?
Started to put the bushes in
Just need to get the new ball joints on the wishbones and then start getting them on the car
I've already removed the radio to save a little bit of weight from the car but I'm going to make a major weight saving which is me the driver who currently stands at 16.5 stone ( 104 kg ) and my first target is 15 stone ( 95 kg ) before Feb when the car goes back on the road
So wish me luck with that .
#2395
Posted 10 January 2016 - 02:53 PM
#2397
Posted 11 January 2016 - 01:53 PM
if you can get down to the ride height and still have some preload on the spring at full droop , then the lower ones, otherwise the higher holes
#2398
Posted 11 January 2016 - 05:35 PM
#2400
Posted 11 January 2016 - 06:12 PM
