Project Chill 1
4396 replies to this topic
#2421 Chris P Duck
Chris P Duck
    I can change this?
  • 1,506 posts
Posted 25 January 2016 - 07:53 PM
All looking good bud.
#2422 CHILL Gone DUTCH
Posted 25 January 2016 - 07:55 PM
Things you end up doing lol
one thing leads to  a other
#2423 Chris P Duck
Chris P Duck
    I can change this?
  • 1,506 posts
Posted 25 January 2016 - 07:56 PM
Don't, I have 4 new hubs sat on my bench which weren't part of the original plan!
#2424 CHILL Gone DUTCH
Posted 25 January 2016 - 08:25 PM
may aswell do the wishbones while your at and put new bushes in also
lol
Edited by CHILL Gone DUTCH, 25 January 2016 - 08:26 PM.
#2425 Chris P Duck
Chris P Duck
    I can change this?
  • 1,506 posts
Posted 25 January 2016 - 08:41 PM
Wishbones, bushes, ball joints, drop links, track rods ends and a steering rack refurb were the original plan. New hubs and a new quick rack weren't, but they somehow happened!
#2426 CHILL Gone DUTCH
Posted 25 January 2016 - 08:43 PM
project thread
#2427 Chris P Duck
Chris P Duck
    I can change this?
  • 1,506 posts
Posted 25 January 2016 - 08:46 PM
It's a bit late, the cars almost finished (yes I'm aware that statement will never be true)
#2428 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 25 January 2016 - 09:32 PM
  Do you not really need discs and bells for track work?   I found the brakes wanting tbh, not very confidence inspiring....
Eh? You're not doing it right.
#2429 stu8v
stu8v
  • 745 posts
Posted 25 January 2016 - 09:33 PM
Enlighten me
#2430 CHILL Gone DUTCH
Posted 25 January 2016 - 10:10 PM
  Enlighten me
What brake setup have you tried ??
#2431 stu8v
stu8v
  • 745 posts
Posted 25 January 2016 - 10:22 PM
Decent pads,fluid and braided lines. Abs disconnected after 20 or so laps. Maybe I'm used to better brakes and expect too much? Tbh I was thinking discs/bells and ducting for the front and rear in the hope I could get them somewhere near my previous track cars.
#2432 stu8v
stu8v
  • 745 posts
Posted 25 January 2016 - 10:24 PM
Surely there is a definitive setup? Previous searches are hit and miss tbh. Ice mode ain't great on track lol hence the disconnected abs
#2433 Chris P Duck
Chris P Duck
    I can change this?
  • 1,506 posts
Posted 25 January 2016 - 10:45 PM
One front and one rear disconnected?
#2434 CHILL Gone DUTCH
Posted 25 January 2016 - 10:58 PM
which pads did you try
brake ducts certainly help i ran mine from the fog light holes
brakes are a very personal thing but personally im on standard brake callipers and find the limiting factor is tires
#2435 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 26 January 2016 - 12:44 AM
  Enlighten me
Standard brakes with track focused pads and fluid are more than enough IMO. I have a switch to disable the ABS as I find it lethal. Have you managed to lock up the wheels?
#2436 MAXR
MAXR
  • 2,719 posts
Posted 26 January 2016 - 06:28 AM
I disagree. For a very long time I had standard calipers, RS14's, braided hoses, ABS off, AP 295's & a good brake fluid. It was fantastic on track, I openly said its all any avid trackers would ever need. However, upgrading to 4 pots on the front, bigger standard steel discs & better pads all around, I've found a major improvement. So far I've not had any fade, the initial bite is far better at wiping speed. The pedal feel is so much better, no brake squeal after long periods, no drama & consistency which allows you to control the brakes at the limit of adhesion. The car remains balanced at all times under hard braking with no hint of lock ups. That said, standard calipers with upgraded pads, hoses & fluid is not to be sniffed at! I'd go down that route first, I'm sure you'll think that's more than enough (just don't drive a 4pot braked car) I've not driven Lee's car (hint, hint!) but GeorgeBC has said it's immense in the brakes department. His brake setup is pretty much as good as you can get.
#2437 CHILL Gone DUTCH
Posted 26 January 2016 - 04:39 PM
Today has caused more questions than answers
The car is back on all 4 wheels 🤘🏻
Ride heights have caused me a few issues which will need more time to achieve the desired
There's been quite a few messages to MBR today
Because the car has the bump steer kit it has rediculas tow in
Any way it's on all 4s so it's getting there slowly
Edited by CHILL Gone DUTCH, 26 January 2016 - 04:40 PM.
#2438 CHILL Gone DUTCH
Posted 26 January 2016 - 04:42 PM
Oh well there goes next years budget New brakes
#2439 CHILL Gone DUTCH
Posted 26 January 2016 - 04:44 PM
  Enlighten me
Yep I can lock up the fronts wheels But I don't run any of the really grippy tyres just the RSRs
#2440 stu8v
stu8v
  • 745 posts
Posted 26 January 2016 - 06:21 PM
  Enlighten me
Yup. But there is more to it than that.
