Project Chill 1
4396 replies to this topic
#2461 CHILL Gone DUTCH
Posted 10 February 2016 - 04:29 PM
You're either a braver man than me, or your suspension is much softer than mine. I've killed a magnetically mounted TomTom and broke the screen of a magnetically mounted phone in the VX on less than smooth roads. :wacko:
oooh i hope not, i will put a tether on it aswell i think, the magnets are very strong and have two on, and a spare one which i might end up using,
i cant see it falling of as the magnets are gripping it very very well so much so it is quite difficult to remove, i did find the adhesive pads are not so good so ive modded them and they will never come of again  :wacko:
the micro keyborad works a treat and well worth the less than £10 it cost at makes using the tablet a lot easier
#2462 Wreelybro
Wreelybro
  • 1,641 posts
    360 Gaming 10-Pin Bowling.
Posted 11 February 2016 - 11:28 AM
Interested also to see if flies off over the first curb you ride!
#2463 CHILL Gone DUTCH
Posted 11 February 2016 - 03:08 PM
I hope not But you will all be able to tell me I told you so Need a micro USB extension so I can tidy the cabling up And need some more wrap
#2464 Nev
Posted 12 February 2016 - 02:51 PM
Wow, u have some lumpy cams.
#2465 CHILL Gone DUTCH
Posted 12 February 2016 - 03:47 PM
Love a lumpy cam
#2466 Exmantaa
Posted 12 February 2016 - 04:13 PM
It's all in mapping...
I have the same Stage2 ZZP LSJ cams with a different ecu in my engine that idles almost normal @875rpm. (just a small hunting due to the slow closed loop feedback)
And that on a smaller 2.0 engine, in which they should act more agressive than with 2.2l displacement to feed.  :rolleyes:
#2467 CHILL Gone DUTCH
Posted 12 February 2016 - 04:21 PM
It's all in mapping...   I have the same Stage2 ZZP LSJ cams with a different ecu in my engine that idles almost normal @875rpm. (just a small hunting due to the slow closed loop feedback) And that on a smaller 2.0 engine, in which they should act more agressive than with 2.2l displacement to feed.  :rolleyes:
Can you send me a picture of the settings at idle So I can give them a try You have my email
#2468 CHILL Gone DUTCH
Posted 12 February 2016 - 05:09 PM
ive not messed with the idling setting, as its never really gave me any issues other than the sound of it which i quite like  :borg:
ive just looked at my setting and think my ignition is quite low at idle,
Edited by CHILL Gone DUTCH, 12 February 2016 - 05:14 PM.
#2469 CHILL Gone DUTCH
Posted 12 February 2016 - 05:51 PM
#2470 Exmantaa
Posted 12 February 2016 - 07:02 PM
I'm on the LSJ ecu and that has a totally different idle strategy... :sleep:
But my base idle advance around 800-1000rpm is 10 degrees. (Warm idle target is 880rpm..)
(I'm still struggling a bit with OBD's hard injector ms values in the base fuelling maps, as that implies it's impossible to exchange fuelling maps with someone on different injectors... I expected something like a Volumetric Efficiency table that works together with the injector parameters to calculate the final ms injection duration... Have to ask Peter sometime why he did it so, :happy: )
#2471 oakmere
oakmere
  • 2,143 posts
Posted 12 February 2016 - 11:27 PM
The fuel table is changed depending on the injector so a Volumetric Efficiency table would make more sense for sharing and comparing different setups. Chill I run 14.7 ignition advance flat across. Add ignition till you find the most stable idle. I found once I went above 16 degrees the engine would start to stumble so you just need to find the sweet spot for your cams. Warning Ignition at this level puts hydrocarbons to high for an MOT pass. I have a can of ITG filter oil rolling around in my boot for you as well.
Edited by oakmere, 12 February 2016 - 11:28 PM.
#2472 TFD
TFD
  • 607 posts
Posted 13 February 2016 - 07:17 AM
For comparison: mine runs 5deg all over the line... No speciall cams though. Must be corrected a bit. Asked Peter for a stock 2.2 map to sort these basics out.
Edited by TFD, 13 February 2016 - 07:18 AM.
#2473 oakmere
oakmere
  • 2,143 posts
Posted 13 February 2016 - 01:13 PM
Stock map is available from the obd tuner forum. High lift cams run smoother with more ignition advance. The key issue is with the closed loop fueling but this can not be adjusted in version 2. This is why Exmanter will have better idle because he has greater access to the mapping via the HP tuner software. I had perfect idle when I locked the software in open loop fueling (not now available) but this caused a few drivability issues so was not released in version 2.
#2474 CHILL Gone DUTCH
Posted 13 February 2016 - 04:05 PM
The lumpy cams dosent effect the way it drives I wouldent want to compromise the drivability But I'm sure I can improve the tick over without losing the drivability Will report when I get time to do a bit more
#2475 oakmere
oakmere
  • 2,143 posts
Posted 13 February 2016 - 07:33 PM
Chill Adding some ignition advance to the idle shouldn't effect drivability but give it a try and see.
#2476 CHILL Gone DUTCH
Posted 19 February 2016 - 07:12 PM
Yep going to do this next week as im getting bored of waiting for the 1st of march to tax the car,
done the oil change today and also checked the steering rack is ok
might even have to clean it next week
one more thing to do before going to MBR is cut the steering rack threads down as the reduce bump steer kit has caused the wheels to toe in a lot
#2477 CHILL Gone DUTCH
Posted 22 February 2016 - 04:49 PM
Spent all morning setting up somthing to measure the toe in and toe out on the front of the vx Plenty of measuring and adjusting later and cutting down the steering rack got the desired toe correct ( well straight ish for going down to MBR ) Role on the 1st of March then I can tax the car
#2478 CHILL Gone DUTCH
Posted 01 March 2016 - 09:18 AM
£290 to tax the car WHAT the fcuk
#2479 CHILL Gone DUTCH
Posted 01 March 2016 - 09:23 AM
#2480 speedster norway
speedster norway
  • 162 posts
Posted 01 March 2016 - 10:43 AM
  Its only 259,73£ in Norway........ :glare:
9 user(s) are reading this topic
0 members, 8 guests, 0 anonymous users
    Bing (1)
