Project Chill 1
4396 replies to this topic
#2561 smiley
Posted 07 March 2016 - 12:11 PM
I asume you're not on an obdtuner pro beta, but talking about 2.7.9 versus 2.7.7?
Maybe open your map(s) on both versions and see.
Edited by smiley, 07 March 2016 - 12:12 PM.
#2562 Exmantaa
Posted 07 March 2016 - 12:46 PM
Think Chill talks not about mapping changes, but more the difference in power measurement oucome 2.7.9 vs his older 2.7.7 numbers...
#2563 smiley
Posted 07 March 2016 - 12:52 PM
The power management run is executed via the ecu only. (with the run variables entered from the client) The result file is then pulled from the ecu for analysis by the client. That file can be opened by both versions.
#2564 Exmantaa
Posted 07 March 2016 - 01:38 PM
But the power calculation is in the client software... I have an even older OBD version (where you can manually input injector parameter values. :happy: ) saved somewhere that gives different power numbers from the same logged powerrun than later versions.
#2565 smiley
Posted 07 March 2016 - 01:40 PM
Yes, hence my remark to open the file in both 2.7.7 and 2.7.9.
#2566 Exmantaa
Posted 07 March 2016 - 03:45 PM
That would be an easy way to see where the differences are. Post the powerrun log for us.
(I have the 2.7.1.6 version on my laptop and an even older one saved somewhere. :happy:)
Edited by Exmantaa, 07 March 2016 - 03:46 PM.
#2567 CHILL Gone DUTCH
Posted 07 March 2016 - 04:19 PM
 well ive spent the afternoon trying to get my power back
#2568 CHILL Gone DUTCH
Posted 07 March 2016 - 04:21 PM
ive got some of it back but, its not 100% there
#2569 oakmere
oakmere
  • 2,143 posts
Posted 07 March 2016 - 04:24 PM
What changes were made? Need to go back to efi now so I can win the contest 😂
Edited by oakmere, 07 March 2016 - 04:25 PM.
#2570 smiley
Posted 07 March 2016 - 04:26 PM
What was the cause?
#2571 CHILL Gone DUTCH
Posted 07 March 2016 - 04:42 PM
What was the cause?
Unsure I've remapped the car completely
#2572 CHILL Gone DUTCH
Posted 07 March 2016 - 04:50 PM
All I no is the car felt good before going to the RR with the new transient setting I tried
While it was on the RR it didn't make the power I was expecting but chris said the transient is terrible
Lol
Made 338 on the RR
The car was rich on the rollers
Came home and today I checked on the obd
The car felt sluggish
But the power output matched the rollers
But I occasionally got a misfire
Did logs etc and somthing was not right it was running rich
At lunch i decided to remap it
Fuel learn
Knock measurement picked up quite a lot of knock especially top end ??
So there was a bit ignition being pulled because of this
My ignition map then was all over the place
So smoothed this out manually and added where I made power and dos have to remove a bit where there was a touch of knock nothing significant but got rid anyway
The ignition map soon started looking like it was last year
Wacko 🤔🤔🤔
A other power run and things started to look like I was expecting
This to comparisons is where it was at around 2:30 and where it is now
#2573 CHILL Gone DUTCH
Posted 07 March 2016 - 04:51 PM
Transient is almost back where it was last year
#2574 CHILL Gone DUTCH
Posted 07 March 2016 - 04:55 PM
The only other thing that has changed is I'm using the newer version of the software now What was the issues with the previous ones
#2575 oakmere
oakmere
  • 2,143 posts
Posted 07 March 2016 - 05:21 PM
Can you see if you were getting KR from the logging on the rollers? Also the runs look smoother than last years with no strange dip
Edited by oakmere, 07 March 2016 - 05:23 PM.
#2576 CHILL Gone DUTCH
Posted 07 March 2016 - 05:44 PM
BINGO
your right martin
but why did it not go back to original ignition when i did the runs this morning ??
#2577 TFD
TFD
  • 607 posts
Posted 07 March 2016 - 05:58 PM
Normally a hard knock or something that needs corrected (by the ecu) can result in going to a second safe map in the ecu (the ecu uses this map as a safe base map to prevent damage). I dont think this is in our ECU's though. We only have the safefail with temps (the 57C thing).
1.1 bar @ 80% DC should be ~370bhp according the calculator. Keep in mind you ran rich at 11.2:1 so some lost horses there.
Can you post the transient map you use now?
What were your wheelHP numbers btw?
Inlet temps during the RR run? Some retarding because of hot temps?
#2578 CHILL Gone DUTCH
Posted 07 March 2016 - 06:12 PM
there was no retarding from heat on the RR the temps were very low and ive had all these safetys removed
the new power is 365PK so lines up with the calculation you are making
i now have 11.8 afr
#2579 CHILL Gone DUTCH
Posted 07 March 2016 - 06:24 PM
im going to email Peter to see if there was a reason the ecu would store and keep the retardation
if thats the case
#2580 CHILL Gone DUTCH
Posted 07 March 2016 - 06:28 PM
there was also a error code but no eml light
so probably the reason why it was still there today
Edited by CHILL Gone DUTCH, 07 March 2016 - 06:34 PM.
    Bing (1)
