Project Chill 1
4396 replies to this topic
#241 techieboy
Posted 11 April 2013 - 08:36 AM
No prob to me :)
Nor me. I just get Vocky or Courtenay's to remove mine, as required. :lol:
#242 rik
rik
  • 2,187 posts
Posted 11 April 2013 - 09:22 AM
I didnt bother with the S bend.
Mine is exactly the same. Just as Courtenay's did it four years ago when they did the conversion and no ill effects.
same here, been like that for years..
The only difference i can see is it being a little more awkward when taking the charger off.
No prob to me :)
a little but its ok :)
#243 smiley
Posted 11 April 2013 - 09:53 AM
Either around the charger, or go over it, the result is the same.
#244 CHILL Gone DUTCH
Posted 11 April 2013 - 10:06 AM
I was thinking of bringing the fuel pipes over the other of the engine well away from the belt, Thoughts on this please, Also what has been used to join the S bend to the original hose, My original hose is not long enough to go over the charger without putting unnessary presure on it
Edited by Chill, 11 April 2013 - 10:08 AM.
#245 VIX
VIX
  • 9,497 posts
Posted 11 April 2013 - 10:07 AM
Shocking harness fitting! thumbsdown ;)
#246 rik
rik
  • 2,187 posts
Posted 11 April 2013 - 10:23 AM
I did this (didn't like them so close to the belt)
Replaced with rubber hose all the way back to the fuel pump much safer i think
Will post some pics later, can be done fairly cheaply if you don't go the aeroquip way..
#247 CocoPops
CocoPops
  • 17,182 posts
Posted 11 April 2013 - 10:24 AM
Take a look at JGs project thread for fuel line stuff.
#248 chris_uk
Posted 11 April 2013 - 10:25 AM
Just unclip the fuel pipes and cabletie them out of the way.
#249 CHILL Gone DUTCH
Posted 11 April 2013 - 11:06 AM
Ok that what I'm going to do,
#250 rik
rik
  • 2,187 posts
Posted 11 April 2013 - 11:17 AM
#251 smiley
Posted 11 April 2013 - 11:42 AM
http://www.courtenay...m/prod_830.html
#252 chris_uk
Posted 11 April 2013 - 11:45 AM
If you start cutting fuelpipes etc and joining them id be more worried the joins will hold up under pressure than the possibility of them catching the belt, expecially if ive cabletied them out of the way.. Even more so if you have a jg belt protector.
#253 CHILL Gone DUTCH
Posted 11 April 2013 - 01:04 PM
I've got that 1 it's far to thin
#254 chris_uk
Posted 11 April 2013 - 01:05 PM
Thin or short? Ive just put that on pauls sc conversion and it was fine.
#255 CHILL Gone DUTCH
Posted 11 April 2013 - 01:17 PM
Thin or short?
Thin
#256 rik
rik
  • 2,187 posts
Posted 11 April 2013 - 01:20 PM
i believe you need a 32mm one (don't quote me on that), the one linked was 19mm?
#257 CHILL Gone DUTCH
Posted 11 April 2013 - 01:22 PM
Yes I bought 1 for the job but its far to thin IMO
I've put in a bit of 32 mm waste pipe in for now
#258 rik
rik
  • 2,187 posts
Posted 11 April 2013 - 01:31 PM
http://www.cbsonline...e_Joiner_BEAD32
#259 smiley
Posted 11 April 2013 - 01:49 PM
i may have linked to the wrong item, sorry.
Is the 32mm aloy joiner mentioned on the SC parts CS site, as i can´t seem to find it.
#260 CHILL Gone DUTCH
Posted 11 April 2013 - 01:52 PM
32mm against 19mm
They only list the 19mm one
Edited by Chill, 11 April 2013 - 01:53 PM.
    Bing (1)
