my under tray was left on when it was on the RR and the straps for the RR were touching the undertray so this could be where the knock retard and error code has come from via the knock sensor
Project Chill 1
#2581
Posted 07 March 2016 - 06:53 PM
#2582
Posted 07 March 2016 - 06:57 PM
#2583
its been a real dilema nick
#2584
Posted 07 March 2016 - 07:48 PM
but im wondering if the lack of the car reving is related to martins car
are you there frank !!
#2585
Posted 07 March 2016 - 07:54 PM
#2586
Posted 07 March 2016 - 08:09 PM
ive emailed peter to see if its viable
#2587
Posted 07 March 2016 - 08:15 PM
#2588
Posted 07 March 2016 - 08:18 PM
there is changes in the map which is still not 100% ive not looked at them side by side
its a completely relearned map and have not put a lot of time in to the ignition yet
Edited by CHILL Gone DUTCH, 07 March 2016 - 08:19 PM.
#2591
Posted 07 March 2016 - 08:30 PM
#2592
Posted 07 March 2016 - 10:12 PM
Just looking to all the plots... (can you just post your logging here? much easier then to search and zoom in or us..)
It now revs to 7150 or so before power drops off? You borrowed Martin's downpipe or what?
#2593
Posted 07 March 2016 - 10:17 PM
I had the same on my run this evening.
See Pipo's reaction on the speedsterclub forum. He may be onto something, where obdtuner maybe cuts in before the limiter.
#2594
Posted 07 March 2016 - 10:21 PM
Was there not someone else here recently that experienced the same OBD soft limiter? But that one also moved when the hard limit was set higher.
#2595
Posted 07 March 2016 - 10:35 PM
yes captain vimes managed to trick the limiter by coming of the throttle just before the limiter
#2596
Posted 07 March 2016 - 10:36 PM
Found it => http://www.vx220.org...18#entry1844841
"power/torque drop consistently ~200rpm before the limiter setting"...
Not sure if the power drop issue is only a curve thingy, or also experienced while driving? If real you should feel the power dropping when approaching the rev limit.
If it's just an OBD measurement issue the car drives straight into the rev limiter without hesitation...
Edited by Exmantaa, 07 March 2016 - 10:40 PM.
#2597
Posted 08 March 2016 - 07:35 AM
The only other thing that has changed is I'm using the newer version of the software now What was the issues with the previous ones
that, and you're running different fuel. Even if you're buying it from the same place, crude sources have a change a lot since last year - almost all of it is coming from the middle east (verses north sea for us last year). It'll behave very differently even if it's the same RON
#2598
Posted 08 March 2016 - 09:17 AM
Very interesting I only filled up just before the RRthat, and you're running different fuel. Even if you're buying it from the same place, crude sources have a change a lot since last year - almost all of it is coming from the middle east (verses north sea for us last year). It'll behave very differently even if it's the same RONThe only other thing that has changed is I'm using the newer version of the software now What was the issues with the previous ones
#2599
Posted 08 March 2016 - 10:55 AM
#2600
Posted 08 March 2016 - 11:12 AM
I set fire to the car.. and left it to burn... (Booked in to CS in April as I've given up trying to find the issue)Dosent mark Beszant. Have a misfire issue also
