Project Chill 1
4396 replies to this topic
#2661 oakmere
oakmere
  • 2,143 posts
Posted 19 March 2016 - 08:49 AM
As I said Saab engines can't use the original plugs. I think as long as the plug resistance is the same as the original GM plugs it should be fine.
#2662 Exmantaa
Posted 19 March 2016 - 09:27 AM
I've never heard of this ion sence and is a new concept to me I've done a bit of reading about it So please correct me if I'm wrong Is this in the coil pack And is it only used as a knock sensor on our engines? Does this cut spark when it is triggered ?? And could this be linked to the so called soft limiters which some have thought they have had As I don't have the issue on the standard spark plugs does this sound as if it was the old plugs with a issue or past there best ( Ngk7E ) due to the resistance feeding back to the coil pack ?
Z22SE ion sense => http://www.speedster...entatie/csi.pdf
#2663 Bargi
Bargi
  • 4,483 posts
Posted 19 March 2016 - 11:21 AM
I had stuttering/misfire for ages up the top end, gaping the plugs down to .7 fixed the problem
Standard is about 1 or .9mm
Peter also recommended this, said he'd seen it with a lot of high boosted and Harroped SCd' cars
#2664 siztenboots
  • 26,613 posts
Posted 19 March 2016 - 11:53 AM
at high rpm there comes a point where the coils charge time is limited, this can be made worse if igntion timing is late as well. what is the dwell time set to?
#2665 CHILL Gone DUTCH
Posted 19 March 2016 - 03:11 PM
How is this calculated sizeten or is it a fixed figure ??
#2666 CHILL Gone DUTCH
Posted 19 March 2016 - 04:09 PM
will keep this in mind, but you should not  gap the iridium plugs but believe they do not require the same amount of voltage to jump the gap.
im still hoping its the plugs that caused my issue and not the coil pack but the signs look promising and will be giving it a good run next week to double check
BKR8EIX IX plugs should be .8mm gap but will double check them before they go in
#2667 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 19 March 2016 - 04:23 PM
I had stuttering/misfire for ages up the top end, gaping the plugs down to .7 fixed the problem Standard is about 1 or .9mm  Peter also recommended this, said he'd seen it with a lot of high boosted and Harroped SCd' cars
What make of plugs were the ones you gapped?
#2668 CHILL Gone DUTCH
Posted 19 March 2016 - 04:27 PM
i would also like to know this
#2669 Bargi
Bargi
  • 4,483 posts
Posted 19 March 2016 - 05:33 PM
I think Matt said he used whatever the standard Saab turbo plugs. Will need to have a look, but don't hold your breath as the cars been undercover since last year :D
#2670 CHILL Gone DUTCH
Posted 19 March 2016 - 05:36 PM
are you not on a z22se?
#2671 Exmantaa
Posted 19 March 2016 - 05:47 PM
Are these not a bit "cold"? (heatrange 8)
Original is range 6, you tried BKR7E's (gapped to 0.8mm?) and now you want range 8 in?
Was thinking about the performance of the OEM wasted spark system on higher revs (dwell) but I think that should be no problem. The GM LSJ has 4 seperate coil-on-plugs.
Edited by Exmantaa, 19 March 2016 - 05:50 PM.
#2672 CHILL Gone DUTCH
Posted 19 March 2016 - 05:51 PM
was told to go up one heat range (colder ) per 100 hp over stock originals are 6s at 200 hp ish so went up two heat ranges as its better to be to cold rather than to hot
the 7s looked like they were running a touch hot
Edited by CHILL Gone DUTCH, 19 March 2016 - 05:53 PM.
#2673 Bargi
Bargi
  • 4,483 posts
Posted 20 March 2016 - 03:27 PM
So a bit more background to this. When I first went Dutch it was with the standard stage 2 setup. Even then at higher rpm/load I'd get misfire and stutter. As soon as I swapped back to CS map it was fine. Did this multiple times and same results. This was on whatever plugs CS recommended. I never solved it and upgraded to Harrop and Saab head with stg2 cams and was still there. Was only after a Zandvoort trip I met Peter and he mentioned gapping down the plugs. Boom problem solved.
#2674 CHILL Gone DUTCH
Posted 20 March 2016 - 04:01 PM
Was the Rev limit the same when you switched from CS to Dutch ? What plugs did you gap down and what are you on now
#2675 mige
mige
  • 54 posts
Posted 20 March 2016 - 08:23 PM
Hello I have Last year also Problems with missfire Z22head Harrop 2.9 Pulley was ok with 2.6 pulley missfire than Gapped down to 0.7mm its ok
#2676 CHILL Gone DUTCH
Posted 20 March 2016 - 08:44 PM
chinky chinky
2.6 pulley wow thats super small have seen much gain over 2.9 and have you managed to control temps
would be good to get to find optimum pulley size for one of runs and track use with and without water injection
#2677 mige
mige
  • 54 posts
Posted 20 March 2016 - 09:26 PM
Thats the Problem with the iat I swap At the Moment to external chargecooler Boost was with 2.6 About 1.65 bar i Hope it Drops a Little bit with Bigger cooler About 20-30 hp but much problems with iat when make powerruns retardet Ignition To much Heat from laminovas My brother had Last year with 3.1 Pulley 110 iat in pannonia Ring racetrack without waterinjection i think is a Must have for harrop If drive hard Nice day mige
#2678 CHILL Gone DUTCH
Posted 20 March 2016 - 09:34 PM
110 degrees C is very hot i also run 3.1 but have not seen them temps
normally less than 85 but maybe i dont drive as hard but i use a pro alloy rad and high flow CC pump with dual pass
what do you mean by external charge cooler ??
#2679 Bargi
Bargi
  • 4,483 posts
Posted 20 March 2016 - 10:02 PM
Yep. But problem would occur well before limiter
#2680 mige
mige
  • 54 posts
Posted 21 March 2016 - 11:34 AM
110 was in a very Hot day 39degree also Dual pass 2 coolers at the Front and big pump At the Moment i modified my intake manifold make a in and Outlet with 76mm pipes Remove laminovas and connect this pipes with a big water to air chargecooler Nice day
