Project Chill 1
#2681
Posted 21 March 2016 - 11:50 AM
#2682
Posted 21 March 2016 - 12:51 PM
110 was in a very Hot day 39degree also Dual pass 2 coolers at the Front and big pump At the Moment i modified my intake manifold make a in and Outlet with 76mm pipes Remove laminovas and connect this pipes with a big water to air chargecooler Nice day
excellent work mige,
keep up the good work and experiments and please keep us all informed on how you are getting on
#2683
Posted 21 March 2016 - 01:38 PM
#2684
Posted 21 March 2016 - 05:06 PM
very interesting. I have a pro alloy Turbo chargecooler lying here since a while.
Wanted to built something like you described but never started.
So, please keep us updated +1 ;-)
#2685
Posted 21 March 2016 - 05:45 PM
Just an inspirational pic from a modded LSJ intake;
#2686
Posted 21 March 2016 - 05:47 PM
#2687
Posted 21 March 2016 - 05:59 PM
Execution could be a lot better than that...
Results in the US were not so good with those modded intakes and with their E85 there is not much efforts to change/mod/improve the stock intake...
A good water injection system is probably easier/cheaper and in the end better, but let's see.
#2688
Posted 21 March 2016 - 06:00 PM
you need to pull your finger out and get the XXL intake manifold finished
#2689
Posted 21 March 2016 - 06:05 PM
#2690
Posted 21 March 2016 - 06:11 PM
wheel power or engine
#2691
Posted 21 March 2016 - 06:12 PM
Well at the very least it's to quick for me
You will be used to it after this season.
Drive the fecker.
#2692
Posted 21 March 2016 - 06:14 PM
engine
unless this mbr setup is going to be the best ever im tempted to go back to the M62
big decision after this year
back to 300 ish hp ??
#2693
Posted 21 March 2016 - 06:19 PM
#2694
Posted 21 March 2016 - 06:33 PM
engine
but might just stick a small pulley on it just to try and top 400 hp
#2695
Posted 21 March 2016 - 06:34 PM
You will be used to it after this season. Drive the fecker.Well at the very least it's to quick for me
#2696
Posted 23 March 2016 - 01:34 PM
little update on the plug situation
after the miss fire on the BKR7E plug which have a gap of around 0.85mm and are nickel tipped
i changed them to the standard saab plugs which are ngkr 20pfr6d-10g iridium plugs with a gap of 0.9mm and the car runs extremely well on these but after inspecting the plug they are running a hot
here is a pic of the BKR7E nickel plug which also looks like its running slightly hot
so ive put some NGK 2668 BKR8EIX IX iridium plug in and from new arebetween 0.7 and 0.75mm gapped
ive not done many miles on them yet but first impressions are good. the car idles better with both type of iridium plug ( saab and latest plug ) than the nickel one and also the car seems to pull a lot smoother with them also
Edited by CHILL Gone DUTCH, 23 March 2016 - 01:42 PM.
#2697
Posted 23 March 2016 - 02:46 PM
#2698
Posted 23 March 2016 - 03:01 PM
#2700
Posted 26 March 2016 - 12:17 PM
