Edited by ArticMonkey, 26 March 2016 - 03:39 PM.
Posted 26 March 2016 - 03:37 PM
Posted 26 March 2016 - 03:47 PM
Lets not confuse my car with cliffies
simular power probably
but my car is a road car which does not have any aero or silly gt hubs which will stop me using it on the road c, which was probably 150 kilos less than mine
which are not things im even considering doing to mine
Posted 26 March 2016 - 03:49 PM
cliffie car was built to win time attack mine is not
Posted 26 March 2016 - 03:59 PM
i never said i wouldent learn from tuition either but surely i would learn from tuition in a car i feel more confident in
Posted 26 March 2016 - 05:20 PM
Not following your logic there fella. Lessons will make you a better driver, end of. This will in turn enable you to enjoy your car more. And what's another £20 or so when your car blows the equivalent out of it's exhaust down the main straight?I'm stubborn for one And as for lessons I think they will unleash time for a track with local knowledge but it won't make me a better driver Plus what we're saying is ove got to spend even more money to get the best out of the car which will make me enjoy it even less than the £500 it costs per track day
Posted 26 March 2016 - 05:24 PM
Tuition is worth a shot.
I've only had tuition once in the vx and he taught me something different on every corner of the track. And also told me the tyres were sh*t (RSR's) and I should put some decent rubber on.
Posted 26 March 2016 - 05:34 PM
What did you bin the RSRs for ?
I'm not defending them btw I am on 888s but due to be replaced :-)
Posted 26 March 2016 - 06:19 PM
Posted 26 March 2016 - 06:47 PM
Any chance the lack of difference in lap times is due to high intake temps reducing the power with your Harrop set-up? On the road the extra 50bhp will be easy to take advantage of as you'll never be using full throttle enough for temps to become critical. But on track it won't take long for temps to build up to the point where the ECU is having to back off to protect the engine. Mike would probably have been doing shorter full speed stints in Time Attack so would probably have been less likely to suffer from heat build up.
I had a fairly similar issue with my turbo after fitting the original Pace charge cooler system. It was fine for short bursts of acceleration on the road. But on track intake temps climbed above 70 degrees after only a few laps (I saw a peak intake temp of 87 degrees competing at a hill climb event). The charge cooler system was not efficient enough to reject the heat through the rad.
My max speeds and acceleration rates suggested my Stage 2 power (245ish) was backing off to less than standard power after 5 or 6 quick laps.
Posted 26 March 2016 - 06:50 PM
This is exactly what I was thinking back to M62 It was fun enjoyable and within my limitsCertainly sounds like you found the limit of your driving at 300, so the extra 50 is wasted. Either get some tuition, as many have said, or sell the harrop and go back to 300.
Posted 26 March 2016 - 06:54 PM
No I monitored intake temps that day It was lack of confidence getting on the power also corner speeds were slow because the tires were past there best Also the extra acceleration was causing confidence lifts Will admit that particular track does not lend itself to power and more to handling IMO both would be good thoughAny chance the lack of difference in lap times is due to high intake temps reducing the power with your Harrop set-up? On the road the extra 50bhp will be easy to take advantage of as you'll never be using full throttle enough for temps to become critical. But on track it won't take long for temps to build up to the point where the ECU is having to back off to protect the engine. Mike would probably have been doing shorter full speed stints in Time Attack so would probably have been less likely to suffer from heat build up. I had a fairly similar issue with my turbo after fitting the original Pace charge cooler system. It was fine for short bursts of acceleration on the road. But on track intake temps climbed above 70 degrees after only a few laps (I saw a peak intake temp of 87 degrees competing at a hill climb event). The charge cooler system was not efficient enough to reject the heat through the rad. My max speeds and acceleration rates suggested my Stage 2 power (245ish) was backing off to less than standard power after 5 or 6 quick laps.
Posted 26 March 2016 - 06:55 PM
Posted 26 March 2016 - 07:07 PM
Posted 26 March 2016 - 07:11 PM
Edited by NickB787, 26 March 2016 - 07:13 PM.
Posted 26 March 2016 - 08:07 PM
I'd suggest more rubber, it really changed the confidence in my car, though it does have it's negative sides too. Loads of times I think I must be near the limit of traction, so on a wide open road with plenty of space and no other cars etc I warily wiggle the steering to see what happens and almost always the car has loads more grip than I imagine. If you are ever passing Bristol feel free to give me a call/PM and I'll show you happily.
At the end of the day, everything the car does is though the rubber. The right compound (for your temps/conditions) and the amount of it. I've learnt this the hard way 3 times now.
I dunno what widths + compounds you are driving on, but if you power has gone up from 150 HP to 350 HP, that is a 230% increase in power. Have you increased your grip by 230%...?
Edited by Nev, 26 March 2016 - 08:13 PM.
Posted 26 March 2016 - 08:52 PM
I'm still on the same worn out RSR's and actually quite enjoy feeling the car moving around. For more grip, I'd be looking at Avon ZZR'S. They've pretty much been designed for the elise, they're super sticky AND reports are that they last for ages too.What did you bin the RSRs for ? I'm not defending them btw I am on 888s but due to be replaced :-)Tuition is worth a shot. I've only had tuition once in the vx and he taught me something different on every corner of the track. And also told me the tyres were sh*t (RSR's) and I should put some decent rubber on.
Posted 26 March 2016 - 09:03 PM
Posted 26 March 2016 - 09:51 PM
Posted 27 March 2016 - 07:50 AM
Posted 27 March 2016 - 09:03 AM
Good advice from Max.
As you're off to Anglesey I thought I'd put together the video of the tuition I got there. The key messages I took away are covered by Max so I'll re-quote key points for me:
...it may well be your tyres giving you a lack of confidence....
🚓 Make smooth inputs 🚑 Practice getting on the power smoothly out of the corner, nothing else is more important. 🚙 smoothly, let the car settle enough before entering the corner. 🚒 Ensure that you approach each corner & exit that corner whilst looking ahead at where you want to come out. The corners before long straights are the most important.
And add/emphasise:
-work with the car, not against it
-the whole lap should 'flow'
-focus on corner exit speed, not entry (this was/is a big problem for me)
-transitions should be smooth and gentle
-Inputs to steering, brakes and throttle should all be measured and controlled i.e. squeeze it on don't stamp on the throttle. "Treat it like a good woman. Caress it gently"
Not sure about the advice from Chris about "linear power delivery so change up early" BUT changing up a little earlier takes pressure off the car and calms everything down. Being a gear too high gives more time to think about throttle,steering and brakes. It's not a qualifying lap and it helps build a smooth, flowing rhythm.
