Project Chill 1
4396 replies to this topic
#261 JG
JG
  • 13,617 posts
Posted 11 April 2013 - 03:04 PM
If you start cutting fuelpipes etc and joining them id be more worried the joins will hold up under pressure
6000psi if you use aeroquip throughout
Even more so if you have a jg belt protector.
thumbsup
quite a rare thing :D
(i've actually got one, since i completed two when paul (big-bazza) went on and on and on and on ( :P :D) at me to get one to him)
#262 CHILL Gone DUTCH
Posted 11 April 2013 - 03:07 PM
I have ram my fuel lines over the alternator down the side of the block as they were originally, I think the belt cover would be I good idea will you PM me price with delivery then I can make up my mind And pictures
Edited by Chill, 11 April 2013 - 03:10 PM.
#263 CHILL Gone DUTCH
Posted 11 April 2013 - 03:08 PM
I haven't cut any fuel lines just shifted them away from belt, Look forward in the future I will have the lines changed and run them the other way across the engine
#264 techieboy
Posted 11 April 2013 - 03:24 PM
Tell me about it. Never got the one you'd promised me. :lol:
Still, that would undoubtedly still be sitting in amongst all the other bits and all the new AN/braided fuel line setup currently parked on top of that. :wacko:
#265 CHILL Gone DUTCH
Posted 11 April 2013 - 03:41 PM
#266 CHILL Gone DUTCH
Posted 11 April 2013 - 06:11 PM
I've got a few questions. 1. Where is the brake vacume hose I don't recall taking it of from anywhere?
#267 rik
rik
  • 2,187 posts
Posted 11 April 2013 - 06:41 PM
u mean you've lost it? it comes in from the pass side sill, its about a 13mm hose connects to sc just after tb, u can see it in the pic i posted earlier
#268 CHILL Gone DUTCH
Posted 11 April 2013 - 06:42 PM
Did it come off the old manifold
#269 rik
rik
  • 2,187 posts
Posted 11 April 2013 - 06:46 PM
yes i believe an L shaped outlet close to the tb mount if i remember the na manifold correctly
#270 CHILL Gone DUTCH
Posted 11 April 2013 - 06:50 PM
I will find it tomorrow, I'm sure it's there somewhere is it long enough
#271 rik
rik
  • 2,187 posts
2.4 manifold is an L shaped outlet right next to tb 2.2 manifold it seems to come out of the side of main body of manifold
#272 rik
rik
  • 2,187 posts
Posted 11 April 2013 - 06:51 PM
should be long enough, maybe too long :)
#273 CHILL Gone DUTCH
Thanks a lot I might sleep tonight now
#274 CHILL Gone DUTCH
Posted 12 April 2013 - 12:59 PM
Just started a bit more on the vx.
Ok I have found my brake vacuume pipe
It's not long enough and if you look carefully it has already been joined
Is this normal?
Do you need the clip on the end to connect it to the SC or can you just push it on
#275 badgerade
badgerade
  • 1,173 posts
Posted 12 April 2013 - 01:04 PM
That join is the one-way valve. Can't answer the other questions though :D
#276 JG
JG
  • 13,617 posts
Posted 12 April 2013 - 01:06 PM
It's on my bench :D
Will be sent to you when you are declared worthy, i.e when its taxed and MoTed :lol:
#277 chris_uk
Posted 12 April 2013 - 01:10 PM
Cut that clip off and replace with new from the 1 way valve.
#278 smiley
Posted 12 April 2013 - 01:17 PM
:yeahthat: It's normal 12mm inner diameter fuel hose. You should find that at any automotive store.
#279 CHILL Gone DUTCH
Posted 12 April 2013 - 01:25 PM
Thanks all going to extend from the one way valve with 12mm inner diameter tube and I'm going to try it with the clip and locking yellow plastic thingy. Ps thanks all.
#280 CHILL Gone DUTCH
Posted 12 April 2013 - 02:34 PM
Just a other quick question,
I've just replaced and extended the brake hose but can anyone confirm the inner diameter the 1 I have bought (12mm) looks bigger than the original
Edited by Chill, 12 April 2013 - 02:35 PM.
