Project Chill 1
4396 replies to this topic
#2901 smiley
Posted 09 May 2016 - 08:27 PM
Key question is how hot the gasses are when they arrive at the backbox.
A german guy did some measuring up to 1000 degrees, but could have been measured near the manifold.
The ZT1 is rated up to 850 degrees celcius.
#2902 CHILL Gone DUTCH
Posted 09 May 2016 - 08:32 PM
http://www.thermalve...ºC/p-117-425/ This one techie
#2903 techieboy
Posted 09 May 2016 - 08:36 PM
That's what was originally in there (and also what I replaced it with last year pre-Spa). I'd order new packing from Tullett but they couldn't get it to me in tine so as I was pushed for time I order that from Thermal Velocity. However, when the Tullett stuff did arrive in a black bin liner, it was the new AcoustaFil Boa stuff which is easier to work with as you can pack without removing the perforated tube.
http://www.thermalvelocity.co.uk/Silencer-Packing/AFILBOA/p-117-486/
#2904 techieboy
Posted 09 May 2016 - 08:40 PM
Key question is how hot the gasses are when they arrive at the backbox. A german guy did some measuring up to 1000 degrees, but could have been measured near the manifold. The ZT1 is rated up to 850 degrees celcius.
  I'd be interested to know myself but I think gas speed is possibly a bigger issue for us with such a short system, as you can feel the exhaust pulses at quite a distance from the tailpipes (on my car anyway).   I don't believe it's anything like 1000°C though. You've only got to look at the contents of the precat silencer to see it's nothing like that, as it hasn't expanded.   When I summon up the courage to remove the exhaust again over the next couple of weeks, I'll get yet another bung welded on for a thermocouple just before the decat silencer. In fact I can probably use the bung that's there for the wideband which has died yet again and relocate that somewhere else.
Edited by techieboy, 09 May 2016 - 08:44 PM.
#2905 CHILL Gone DUTCH
Posted 09 May 2016 - 08:44 PM
Ive put my wideband right near the back box after the first 180 bend and not had a issue with it there
i will try the boa stuff
#2906 smiley
  I don't believe it's anything like 1000°C though. You've only got to look at the contents of the precat silencer to see it's nothing like that as it hasn't expanded.   When I summon up the courage to remove the exhaust again over the next couple of weeks, I'll get yet another bung welded on for a thermocouple just before the decat silencer. In fact I can probably use the bung that's there for the wideband which has died yet again and relocate that somewhere else.
Yes please. Very interesting in what comes out.
If it's way under 850 (for ZT1) or even 800 (for PTX), then it's indeed the pulses that kill the acoustafill.
Edited by smiley, 09 May 2016 - 08:45 PM.
#2907 techieboy
Posted 09 May 2016 - 08:46 PM
Ive put my wideband right near the back box after the first 180 bend and not had a issue with it there  i will try the boa stuff
Yeah, with hindsight, I should have added it after the decat silencer but the exhaust guy liked the location and it meant I could swap in the cat and still have the wideband in the right place if I ever needed to. Three sensors down. Another one to go back in. :wacko:
#2908 MAXR
MAXR
  • 2,719 posts
Posted 09 May 2016 - 08:47 PM
I was static tested at 99db today at Castle Combe. That's after both my silencers were packed with Acousta-fill. I'm not sure if it was the latest stuff from them or not, but it didn't do much good.
Perhaps there may be other car manufacturers 2.5" & 3" OEM rear boxes that could be fitted & or made re-packable? Are they better designed than aftermarket silencers?
#2909 smiley
Are you using the wideband protector Techie?
http://www.innovatem...productid=16148
#2910 smiley
Posted 09 May 2016 - 08:50 PM
Ultimate had some interesting results bolting an NA backbox on his 3" manifold and downpipe.
Still made good power, but no measuring on backpressure change, and no track (ab)use.
#2911 techieboy
Are you using the wideband protector Techie? http://www.innovatem...productid=16148
Yup, that exact one. Two sensors dead with the AEM kit. And another dead one with the 14point7 kit. All genuine Bosch sensors. Have got yet another sensor here to try with the 14point7 kit again. Luckily, I made all of the wiring plug and play so I can swap the controllers in and out as well. :lol:
#2912 CHILL Gone DUTCH
do you twin exhaust outlets max, as a single exit helps
#2913 MAXR
MAXR
  • 2,719 posts
Posted 09 May 2016 - 08:53 PM
I've just ordered one that's long enough to take a db killer.
#2914 techieboy
Posted 09 May 2016 - 09:03 PM
Are they still doing the measuring in the frigging scrutineers garage, just to make it even worse. :beat:
I ordered a 24" 3 chamber stainless silencer from the States last week. So cheap, I thought it was worth a try.
I've got a couple of other mods to try first after consulting with another exhaust guy who deals with getting difficult race cars sorted. He recommended two different modifications to the perf tube. One is two put one or two crimps in it to change it into more of a 1" slot and then another one at 90° a bit further down the tube (makes it into kind of 3 chambers). That makes a useful difference according to him as it encourages the gas into the packing.
The second option was to try and get hold of a louvred tube instead of the perforated tube as again that slows the gas and actually scoops it into the packing. Reduces the flow by something like 5% but I don't think that's an issue for us with 3" systems, at least not with M62's anyway.
#2915 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 09 May 2016 - 09:45 PM
If you look at the stainless steel metal on the silencer you can tell what sort of temp it's getting to.
I remember seeing Graham's vx on the dyno where the exhaust was glowing red
#2916 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 09 May 2016 - 10:28 PM
This one?
#2917 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 09 May 2016 - 11:32 PM
Thats the one, cleary shows it's getting close to 900 degrees in places.
#2918 CHILL Gone DUTCH
Posted 10 May 2016 - 01:28 PM
Matt when you put your acustafil in did you rap it in tightly or losely
#2919 techieboy
Posted 10 May 2016 - 02:28 PM
I started off with it wound quite tight as it needed to be to use all of the supplied AcoustaFil. After spending a couple of hours trying to get the perforated tube and wrap back in (the Tullet perforated tube is offset at each end to get a bit more length) and seated, I ended up tearing off a few chunks to fit it which made it a bit looser. I reckon, if the tube was central to the casing, I'd have probably had 5 layers of AcoustaFil wrapped around the tube.
Hopefully, this new boa stuff will make life much easier. When I spoke to Tullet they advised packing it in quite densely and to use a bit of timber to pack it all in.
#2920 siztenboots
Posted 10 May 2016 - 02:42 PM
also smear the perf tube with grease for the full effect
