Project Chill 1
4396 replies to this topic
#2921 CHILL Gone DUTCH
Posted 10 May 2016 - 03:41 PM
Well I've put 2 metres right around the perferated tube which is just of 5 times round but I've kept it as lose as I can mainly so it can expand and knot together Luckily the 2ubular perferated tube is right in the middle ( square ) I had a nightmare with the Tullet to because of the way it's offset I've took all the wire wool out Which has made the back box very light compared with before Let's hope it holds in for the year Can you explain the grease around perferated tube sizeten as I don't quite understand the advantage of it ?
#2922 CHILL Gone DUTCH
Posted 10 May 2016 - 03:45 PM
Just needs a new kid on it now
The steel wool took some getting out
#2923 CHILL Gone DUTCH
Posted 10 May 2016 - 03:59 PM
Is there and mileage in adding a tip like the Tullet on my system with the perferated internal ? As mine currently is just cut of bit of 3" pipe
#2924 techieboy
Posted 10 May 2016 - 04:04 PM
I've read that resonated tips can help a little bit but am not sure I believe it in the real world.
#2925 CHILL Gone DUTCH
Posted 10 May 2016 - 04:12 PM
Im going to extend my tip anyway as the exit is very close to the clam ( flame damage )
So may aswell put a resonated tip in
To see if they work
I'm also going to put a false tip above to make mine look a bit better
I'm also going to put a DB reducer in the false tip
So it can be moved down stairs if it's needed
The top will also be slightly set back from bottom one
So if the static tester pics up top one there will be a lesser reading 😜
Edited by CHILL Gone DUTCH, 10 May 2016 - 04:14 PM.
#2926 smiley
Posted 10 May 2016 - 04:51 PM
No more supergirl santa siztenboots?
#2927 siztenboots
  • 26,613 posts
Posted 10 May 2016 - 05:39 PM
grease inside the exhaust is common practical joke that garage mechanics often do each other. smokes like crazy.
#2928 siztenboots
  • 26,613 posts
Posted 10 May 2016 - 07:36 PM
she is always there when you need her
#2929 Nev
Posted 11 May 2016 - 07:33 AM
Those dB killers do work, I made one for Nipper and it dropped the noise by nearly 3 dB. However, you need to be aware that they create a good deal more back pressure, so your fuelling may be affected (though your ECUs will modify the fuelling tables appropriately over time presumably). Also your cylinder head temps may rise a bit.
Edited by Nev, 11 May 2016 - 07:58 AM.
#2930 CHILL Gone DUTCH
Posted 11 May 2016 - 08:45 AM
I will have a seperate map for it nev which I can call up on
#2931 siztenboots
  • 26,613 posts
Posted 11 May 2016 - 08:52 AM
if you know the rpm range of the static test , then you can map that area for less noise , it would not impact wide open throttle performance, just low load.
#2932 Bargi
Bargi
  • 4,483 posts
Posted 11 May 2016 - 11:29 AM
I'm sure someone at VW could help out here
#2933 Nev
Posted 11 May 2016 - 01:16 PM
Great idea :)
#2934 CHILL Gone DUTCH
Posted 11 May 2016 - 06:15 PM
This came today
And knocked this up
#2935 Nev
Posted 11 May 2016 - 07:05 PM
Could you show a few pics of how the exhaust box and the plate over it is attached and lined so that the gases dont escape please?
#2936 CHILL Gone DUTCH
Posted 11 May 2016 - 07:08 PM
I've just made the plate ATM nev I've been work to today It will over lap and have many riv nuts around it To clamp it down If it leaks which is unlikely until the wadding falls out 😜 I will put exhaust paste around it
#2937 CHILL Gone DUTCH
Posted 11 May 2016 - 07:54 PM
I was going to cut it out of the wife's stainless steel dust bin But decided against it 🐔
#2938 Exmantaa
Posted 11 May 2016 - 11:46 PM
just use pop rivets + paste (or silicone stuff, as that can have some heat). Drill-out/replace when repack is due. :sleep:
#2939 CHILL Gone DUTCH
Posted 13 May 2016 - 10:01 AM
Checked my spark plugs after around the 300 mile mark and 1 track day
There is little browning around the insulator so may still be a little hot running but will leave them for now and check again after croft on the 13th so may go up to 9s
BKR9EIX IX iridium NGK2669
#2940 CHILL Gone DUTCH
Posted 18 May 2016 - 06:36 PM
well margo is back together
exhaust was a bit of a PITA but got there eventually
at bedford the static test was 99 Db today a unconfirmed reading of 92Db was recorded at static
the car is significantly quiter especially when cruising around
the car was not as quick as it normally is though ??
    Bing (2)
