had a bit of a issue with the coilpack which i thought was a bit more serious but it turned out just to be the coil pack rattling round on the saab cover
Posted 18 May 2016 - 06:39 PM
Posted 18 May 2016 - 06:51 PM
still need to get my tip extended so it can take the DB reducer but hopefully i wont need that now
also going to have a false bit put above the single exit to make it look more oem
Posted 18 May 2016 - 07:15 PM
easy fix for a change.
Posted 23 May 2016 - 08:12 PM
Posted 23 May 2016 - 08:30 PM
Posted 23 May 2016 - 08:52 PM
Posted 23 May 2016 - 09:00 PM
Posted 23 May 2016 - 09:05 PM
Posted 23 May 2016 - 09:14 PM
However you look at it im certainly more confident with the car than i was last year
Posted 23 May 2016 - 10:19 PM
:However you look at it im certainly more confident with the car than i was last year
Posted 24 May 2016 - 08:38 AM
Looking at your old vids I remember thinking there was nothing wrong with your driving style so the only thing making you slow at the National was clearly the car.
Posted 24 May 2016 - 12:13 PM
Confidence is certainly key I reckon, and thanks for commentLooking at your old vids I remember thinking there was nothing wrong with your driving style so the only thing making you slow at the National was clearly the car.
Posted 24 May 2016 - 08:45 PM
I've never tried any Pagids, what's their coeff of friction when hot please?
Posted 24 May 2016 - 08:47 PM
i have no idea
but they last longer than anything else ive tried
Posted 24 May 2016 - 09:04 PM
i have no idea
as much as 1 and a half trackdays ?
Posted 24 May 2016 - 09:09 PM
.5 (same as RC6)
Edited by smiley, 24 May 2016 - 09:10 PM.
Posted 24 May 2016 - 09:11 PM
Doubt you'll get them hot to enough to appreciate them on the road.I've never tried any Pagids, what's their coeff of friction when hot please?
Posted 25 May 2016 - 12:00 PM
You might be a bit surprised, as my front brake discs which are 30mm thick and 330mm wide (i.e. a much larger heat sink than OEM) are sometimes golden/coppery yellow due to heat. I've also parked up and found the fronts smoking a bit on a few occasions. This is only since my upgrade to RC6 pads after my brake conversion project though.
Edited by Nev, 25 May 2016 - 12:10 PM.
Posted 03 June 2016 - 12:18 PM
