Project Chill 1
4396 replies to this topic
#2961 chris_uk
Posted 03 June 2016 - 02:56 PM
I've never tried any Pagids, what's their coeff of friction when hot please?
Doubt you'll get them hot to enough to appreciate them on the road.
  You might be a bit surprised, as my front brake discs which are 30mm thick and 330mm wide (i.e. a much larger heat sink than OEM) are sometimes golden/coppery yellow due to heat. I've also parked up and found the fronts smoking a bit on a few occasions. This is only since my upgrade to RC6 pads after my brake conversion project though.
Rc6's are quite abrasive on the discs when cold.. You should really stick with the rc5+ pads if your not going to track it. When discs get propperly hot, hot enough for you to worry about they go blue.
#2962 CHILL Gone DUTCH
Posted 08 June 2016 - 06:30 PM
MARGO is going all light weight
Pick these tomoz
#2963 CHILL Gone DUTCH
Posted 10 June 2016 - 06:15 PM
Well there in
#2964 CHILL Gone DUTCH
Posted 10 June 2016 - 06:17 PM
Croft Monday And the weather does not look great Was planning on getting in to 1:38 ( target ) Not sure how possible this will be because of the weather But time will tell
#2965 CHILL Gone DUTCH
Posted 10 June 2016 - 06:19 PM
At least I will have some free water injection
#2966 MAXR
MAXR
  • 2,719 posts
Posted 10 June 2016 - 07:57 PM
I like the seat pads, where are they from?
...Do they do matching scatter cushions & throw?  :D
#2967 Captain Vimes
Captain Vimes
  • 2,755 posts
Posted 10 June 2016 - 08:07 PM
Looking good. I'd have thought you'd be comfortably under 1:38 at Croft on a clear day. Hope the weather holds up for you.
#2968 CHILL Gone DUTCH
Posted 10 June 2016 - 08:09 PM
http://www.jkcomposi...om/7s-info.html
http://www.jkcomposi...lsterypage.html
Edited by CHILL Gone DUTCH, 10 June 2016 - 08:10 PM.
#2969 CHILL Gone DUTCH
Posted 10 June 2016 - 08:17 PM
cheers about the weather but not sure it will be easy to get in the 1:38 ive always found it difficult to get a flying lap in there without hitting traffic
the best ive ever done is a 1:40 with traffic
#2970 The Batman
Posted 10 June 2016 - 08:18 PM
I like the seat pads, where are they from?     ...Do they do matching scatter cushions & throw?  :D
Can definately tell you are a married man...
#2971 SteveA
SteveA
  • 9,152 posts
Posted 13 June 2016 - 09:21 AM
Absolutely, In the dry I'm in the mid 1:37s and Croft is a power circuit so you should easily top that. Just be brave through Clervaux, the Jim Clark Esses and Barcroft and you will easily do it.
You should be looking to get close to Cliffies 1:30.
Edited by SteveA, 13 June 2016 - 09:23 AM.
#2972 smiley
Posted 13 June 2016 - 09:30 AM
Without huge wing and splitter?
#2973 tommobot
tommobot
  • 1,008 posts
Posted 13 June 2016 - 09:39 AM
Have you retained the seat belts with the JK's, or are you using just the harnesses?
#2974 CHILL Gone DUTCH
Posted 13 June 2016 - 10:10 AM
Both belts I've done a 1:38.8 in the damp/greasey
#2975 tommobot
tommobot
  • 1,008 posts
Posted 13 June 2016 - 10:32 AM
Did you use the 340R bolts, or is there another way of getting both in?
#2976 CHILL Gone DUTCH
Posted 13 June 2016 - 03:07 PM
Who can guess what stopped play at croft
#2977 SteveA
SteveA
  • 9,152 posts
Posted 13 June 2016 - 03:12 PM
Exhaust hanger?
#2978 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 13 June 2016 - 03:57 PM
Exhaust hanger?
Yep that's what I think hope the box is repairable
#2979 The Batman
Posted 13 June 2016 - 04:03 PM
its a downpipe hanger, typical problem for the 3" systems, which is why i dont fit them :)
tullets new systems dont have them on
Edited by The Batman, 13 June 2016 - 04:03 PM.
#2980 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 13 June 2016 - 06:17 PM
How did the epoxy putty last? Sent from my iPhone using Tapatalk
