Edited by CHILL Gone DUTCH, 30 June 2016 - 02:50 PM.
Project Chill 1
#3041
Posted 30 June 2016 - 02:49 PM
#3042
Posted 30 June 2016 - 02:55 PM
225 nev Standard tds rims
Can you think about increasing them, with wheel arch extensions to make it a worth while increase? An extra 6 CM each side would make it much more planted for sure. Also, moving up a wheel size to 18" and using 30% profile tyres would give you a slightly greater contact patch and less tyre wall deformation, meaning you can run slightly lower pressures for even more grip whilst retaining near OEM wishbone angles. I often drop to around 23 or 24 PSI (cold) for low/mid speed stuff, gives more grip and I don't notice any adverse effects.
Edited by Nev, 30 June 2016 - 03:13 PM.
#3043
Posted 30 June 2016 - 05:53 PM
#3044
Posted 04 July 2016 - 01:39 PM
#3046
Posted 05 July 2016 - 09:34 AM
And then covered that with some more wadding
This exhaust is now going to be welded up and forgot about until I get kicked of a track, ( never going back to Bedford )
I do wish I hadent even opened this exhaust up
#3047
Posted 05 July 2016 - 09:42 AM
#3048
Posted 05 July 2016 - 10:16 AM
#3049
Posted 05 July 2016 - 11:11 AM
G ot a nice 3" Tullet for sale ;-) not that loud lol
#3050
Posted 05 July 2016 - 11:27 AM
Is Bedford worth the pain of getting a quiet exhaust? Often wondered.
No, its average at best.
#3051
Posted 05 July 2016 - 11:56 AM
Lol I think this exhaust was quieter without that Db reducer you had at Bedford when you got a New Bedford high reading recordG ot a nice 3" Tullet for sale ;-) not that loud lol
#3052
Posted 05 July 2016 - 11:57 AM
#3053
Posted 05 July 2016 - 12:39 PM
Maybe the water injection will also help the wadding stay intact due to cooler temps
I think you'll find even higher EGT with WI
#3054
Posted 05 July 2016 - 12:44 PM
Even with 100% water no methI think you'll find even higher EGT with WIMaybe the water injection will also help the wadding stay intact due to cooler temps
#3055
Posted 05 July 2016 - 12:47 PM
Yes.
WI will increase the charge density which means more fuel to maintain lambda therefore greater heat.
#3056
Posted 05 July 2016 - 12:50 PM
#3057
Posted 05 July 2016 - 12:56 PM
i was planning on getting the AFR between 12 - 12.6 and using water injection but will experiment more with this stuff after zandvoort
#3058
Posted 05 July 2016 - 01:48 PM
Yes.
Not that I don't believe you ...
Lets assume 300HP, which means about 250 gr air per sec. WI at 10 liters per hour (got this from some WI calculators, but seems low). Specific heat of water 4.2 KJ/kgK, of air 1.0 KJ/kgK. Latent heat 2265 KJ/kg for water. You inject 2.8 ml/sec which is about the same in grams. And you have to cool 250 grams of air with that. Heating the water from 20C to 60C (assumptions) will cool the air with about 2C. Less than I expected. On the other hand, evaporation of all the water will remove about 25C. Lets assume the air was 90C and goes to 63C. Air density goes up by about 6%, but you have injected about 1% water, so total of 5% more air. You need 5% more fuel with a whopping 42 MJ/Kg energy content (that's 20 times more than the latent heat for water). Additional fuel to injected water ratio is 5 to 1 ...
... so yes, temperatures will go up
#3059
Posted 05 July 2016 - 03:26 PM
#3060
Posted 12 July 2016 - 03:37 PM
Bing (1)
