Project Chill 1
4396 replies to this topic
#3081 TFD
TFD
  • 607 posts
Posted 13 July 2016 - 05:08 PM
Thats a benefit of a turbo. Electric boostcontrol. Low boost for the streets with streettires, high boost on track with tracktires.
#3082 Nev
Posted 13 July 2016 - 07:45 PM
A lot of these fast vx's still look like road cars.
It's pretty drastic to cut the arches and put on some pastic extenders, or put on a GMS clam.
Yep, it is drastic, I can understand not wanting to cut into bodywork.
#3083 vocky
Posted 15 July 2016 - 06:51 AM
you might want to reconsider going for 400bhp after what I have seen happen to a block :ninja:
#3084 CHILL Gone DUTCH
Posted 15 July 2016 - 06:58 AM
Please tell me what you have seen ? For the record I'm not bothered about going for any more power, just want consistant power
#3085 vocky
Posted 15 July 2016 - 07:04 AM
It is not an engine I built, but it was built from a brand new Saab engine. The cylinder wall cracked :(
He is still p'd off about it, but hopefully he will post the picture.
He needs to go Darton sleeves if he still wants to go for big bhp, the GM build book does say 400+ requires sleeves.
#3086 SteveA
SteveA
  • 9,151 posts
Posted 15 July 2016 - 07:58 AM
Look at it this way, BTCC cars only have 350bhp and they are unbelievably quick! As you say though just constant, reliable 350bhp.
#3087 CHILL Gone DUTCH
Posted 15 July 2016 - 08:48 AM
It is not an engine I built, but it was built from a brand new Saab engine. The cylinder wall cracked :(   He is still p'd off about it, but hopefully he will post the picture.   He needs to go Darton sleeves if he still wants to go for big bhp, the GM build book does say 400+ requires sleeves.
Is this the same for z22se or just b207 And was it opened up for bigger Pistons Just curious
#3088 CHILL Gone DUTCH
Posted 15 July 2016 - 08:53 AM
Have you told Lee 2.2
#3089 Exmantaa
Posted 15 July 2016 - 09:32 AM
Crancase wise a B207 = Z22SE (Ecotec gen 1 block), so exact same weakness.
For reliable 400+ you need a reinforced Gen3 block, or re-inforce the weak Gen 1 cilinder walls or fit complete steel liners like the Darton sleeves.
(PS; who, what? Impressive power if you can crack the sleeves... :happy:)
Edited by Exmantaa, 15 July 2016 - 09:33 AM.
#3090 fezzasus
Posted 15 July 2016 - 09:52 AM
Are you sure it's not down to piston-liner overlap at high temperatures? There are massive frictional losses from a standard aluminium piston in a cast iron liner, if you add extra heat into the system then it's only going to get worse. I would be looking into the thermal expansion characteristics of the piston material. This is also where differences in the B207 and Z22SE occur as the under piston oil jets are responsible for 50 % of the piston cooling
Where did the crack originate?
#3091 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 15 July 2016 - 10:09 AM
If it happens it happens will build another bottom end
#3092 Nev
Posted 15 July 2016 - 10:44 AM
Ooh that sounds worrying, I can give you a nice sturdy Z20LET iron block if you want ;)
Actually even the z20LET can crack around the cylinder tops if the deck isn't semi-closed off (roughly £100 job at a machine shop).
Edited by Nev, 15 July 2016 - 11:05 AM.
#3093 CHILL Gone DUTCH
Posted 15 July 2016 - 11:49 AM
Thanks for offer nev but I'm happy sticking to current power levels which does not exceed the failure
#3094 CHILL Gone DUTCH
Posted 15 July 2016 - 12:05 PM
Was it a uk vx ? And what piston/rods
Edited by CHILL Gone DUTCH, 15 July 2016 - 12:06 PM.
#3095 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 15 July 2016 - 12:51 PM
Graeme's car is the only forged Saab untouched by Vocky. However it's a 2L with standard rods if memory serves me correct.
#3096 vocky
Posted 15 July 2016 - 04:00 PM
B207 with under piston oil jets, Wiseco standard bore pistons with gapped rings, Eagle 2.2 steel rods, standard z22se crank and a fully balanced bottom end.
Edited by vocky, 15 July 2016 - 04:00 PM.
#3097 TFD
TFD
  • 607 posts
Posted 15 July 2016 - 04:41 PM
These kind of things are allways a debate. Was it actually power that crackef the liner or was something else not right?
#3098 CHILL Gone DUTCH
Posted 15 July 2016 - 05:06 PM
#3099 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 15 July 2016 - 06:59 PM
Correct. Could be thousands of things that lead to it. Bad run in process, bad mapping, workmanship of the build etc. Im not buying into the scaremongering of it all just right now. It's a classic thing that happens on this forum. :lol:
#3100 Bargi
Bargi
  • 4,483 posts
Posted 15 July 2016 - 07:29 PM
I'm surprised the Detective Monkey doesn't already know who it is :D Sent from my cuntyfuckbollock phone by Twatatalk
