Project Chill 1
4396 replies to this topic
#301 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 14 April 2013 - 07:31 PM
What are you doing with the driveshaft in post #293?
Edited by Sticky, 14 April 2013 - 07:32 PM.
#302 CHILL Gone DUTCH
Posted 14 April 2013 - 07:40 PM
Changing the inner drive shaft boot
#303 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 14 April 2013 - 07:53 PM
Thanks. Maintenance or broken?
#304 CHILL Gone DUTCH
Posted 14 April 2013 - 07:55 PM
Only change things when they break
#305 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 14 April 2013 - 07:57 PM
Have been thinking about that during my suspension refresh :D
#306 CHILL Gone DUTCH
Posted 19 April 2013 - 04:50 PM
Going to finish the charge cooler pump this weekend, then George has kindly offered to put the clam back on next week while he is on call and I'm at work,, Just waiting on my header tank from Joe Then the mapping will commence
#307 CHILL Gone DUTCH
Posted 20 April 2013 - 12:46 PM
Rather large charge cooler pump fitted and plumbed in Relay wired just need hEADEr tank now from JOE
#308 CHILL Gone DUTCH
Posted 20 April 2013 - 03:58 PM
Ok I think the car is ready for the clam, at long last, I have managed to waste 3 hours or so today,
Whilst looking for a earth for my pump I decided to get it from the bolt just inside the chassis on the passenger side behind the ear.. Straight forward you would think? NO
The bolt started to turn but the nut on the back was spinning normally this wouldent be a problem depart from the fact the nut in the back was a round cylinder type thing with a tread on it.
It was also inside the box section part of the chassis in a in extensible place,
3 hours later with the wife turning the nut, and me under the car trying everything to tighten the earth bolt back up, in the end I had to use a long file wedged in between the chassis and the round cylinder, I think it tightened by luck in the end rather than skill..
Anyway a few pics of the car waiting for the clam and header tank.
#309 CHILL Gone DUTCH
Posted 20 April 2013 - 04:10 PM
One thing which will definitely needs sorting before HIghland Hoon trip, Since we have changed the fuel pump the fuel gauge is reading full and it isn't full Does anyone have any ideas what wrong with it, The car is still on jacks Or has the float thingy got jammed
Edited by Chill, 20 April 2013 - 04:10 PM.
#310 The Batman
Posted 20 April 2013 - 04:11 PM
if the fuel gauge is registering full and it isn't and the car is level, then you may have bent the float
#311 CHILL Gone DUTCH
Posted 20 April 2013 - 04:14 PM
I hope the float isn't broke/bent
Will have to get the car of the jacks and keep my fingers crossed
#312 CHILL Gone DUTCH
Posted 21 April 2013 - 12:53 PM
Car starting to come together
#313 jakbvx
jakbvx
  • 704 posts
Posted 21 April 2013 - 04:10 PM
Just noticed you had the apexi filter, I put one of these on my blue sc and it restricted it, intake pipe collapsing etc, Think nicolw on here had same problems, thought I was getting a bargain from Japan @ £40 instead of £70-80 over here, I was wrong, it was a very very good fake, same box, wrapping, stickers etc. Apparantly a few mm smaller bore, gold nuts on filter instead of silver and the black plastic cone is of a rough texture and not a gloss finish. The filter card element must be crap so double check it and you may release more bhp!
#314 CHILL Gone DUTCH
Posted 21 April 2013 - 05:12 PM
Yes it's a original cost a lot When switch car off it goes wooch which is strange
#315 CHILL Gone DUTCH
Posted 21 April 2013 - 05:15 PM
#316 CocoPops
CocoPops
  • 17,182 posts
Posted 21 April 2013 - 05:21 PM
Your ECU fitting looks a bit odd. Most are located where your pump is, well out of the way. What did you do to the felt lining, it looks ripped to shreds?!
#317 CHILL Gone DUTCH
Posted 21 April 2013 - 05:23 PM
I mounted ECU closer to the throttle body so I could mount pump there ,
The drill attacked the felt
#318 CHILL Gone DUTCH
Posted 23 April 2013 - 09:32 AM
Final piece of the puzzle has arrived today, Cheers Joe
#319 CHILL Gone DUTCH
Posted 23 April 2013 - 04:57 PM
No it hasent, Still waiting for my header tank, The delivery was my harnesses
#320 Rosssco
Rosssco
  • 4,183 posts
Posted 23 April 2013 - 05:58 PM
Just fit a tpiece and a bit of pipe with a bung to get you up and running...
1 members, 4 guests, 0 anonymous users
    martinf
