Project Chill 1
#3221
Posted 13 September 2016 - 05:25 PM
#3222
Posted 20 September 2016 - 07:22 PM
#3226
Posted 20 September 2016 - 09:26 PM
#3227
Posted 23 September 2016 - 05:16 PM
the water is now being injected in to the manifold, the early signs are looking
i think the water injection will be ongoing and trying different ratios
the question is, is it better to inject asleast water as possible to have the desired effect or better to inject more and keep the exhaust temps low also,
#3229
Posted 23 September 2016 - 05:20 PM
will be going oulton Park on the 4th october and will do a few laps and get the intake temps up and the switch the water on and see how quickly it can recover the temps
#3230
Posted 29 September 2016 - 09:13 AM
After speaking to others recently on the water injection thread about the burn rate being significantly slower afternoon increasing the ignition by 1.5 % the power is roughly where it was without the water injection
So target today will be to work on the ignition more to try and smooth things out and see what happens and achievable with the 100% water
I will also look further in playing with the ADR
#3231
Posted 29 September 2016 - 12:01 PM
lol just read back above
i meant 1.5 degrees of ignition not 1.5 % and AFR not ADR
#3232
Posted 29 September 2016 - 02:40 PM
well im still at it and finding quite hard to find consistency around the water injection
i still have more knock with the water than my old map without water also my old map feels so much better and is producing more power (& heat )
i may be really underestimating how much of a slow burn the water is producing and may need even more ignition in there, has anyone else had any expirience with how much ignition they have added to get the water injection to burn correctly ??
#3233
Posted 29 September 2016 - 09:11 PM
I suspect you are discovering why engineers have been using mixes of around 50/50 water/methanol. The methanol has a fairly high calorific value (about 90% of petrol roughly) which still also helps cools the charge and it's higher octane allows for some ignition advance without worrying so much about detonation.
Edited by Nev, 29 September 2016 - 09:16 PM.
#3234
Posted 30 September 2016 - 02:20 PM
#3235
Posted 30 September 2016 - 02:44 PM
would this change the dynamic compression , is there a risk of hydrolock
#3236
Posted 30 September 2016 - 02:57 PM
Chill have you gone through the process of reducing the amount of water injected until you see temps starting to raise? Or is this a constant that is set by the injector size? Just thinking you may be injecting too much water and no amount of ignition advance will get your power back.
Yes ive always thought i was on the brink of the water being effected i did reduce it and the cooling effect was quite poor so imo im already using the least amount, peter is injecting a lot more than me as is acidpopstar (acids car does worry me from what ive found out over the last few weeks )
#3237
Posted 30 September 2016 - 03:18 PM
Ive reduced the knock at wot considerably today but still have a little which i would like to get rid off
gone from this
to this with some 3-6 degrees of extra igniton
and the car feels a lot better now and a lot stronger but adding more ignition or lowering ignition is not helping
Edited by CHILL Gone DUTCH, 30 September 2016 - 03:19 PM.
#3238
Posted 30 September 2016 - 03:47 PM
#3239
Posted 30 September 2016 - 03:48 PM
Chill I would try changing the AFR just a few points to see how it affects things
leaner or richer
#3240
Posted 30 September 2016 - 03:52 PM
what pulley are you running?
6 user(s) are reading this topic
0 members, 6 guests, 0 anonymous users
