Project Chill 1
4396 replies to this topic
#3241 CHILL Gone DUTCH
Posted 30 September 2016 - 04:01 PM
double post
Edited by CHILL Gone DUTCH, 30 September 2016 - 04:02 PM.
#3242 CHILL Gone DUTCH
what pulley are you running?
3.1
#3243 oakmere
oakmere
  • 2,143 posts
Posted 30 September 2016 - 04:23 PM
If you are running 11.8 I would try 12.0 if you get more KR try a little ritcher
#3244 CHILL Gone DUTCH
Posted 30 September 2016 - 04:26 PM
pro uses lambda out put rather than AFR
standard was 0.80 and i changed it to 0.82
#3245 oakmere
oakmere
  • 2,143 posts
Posted 30 September 2016 - 06:01 PM
How did that effect KR?
#3246 CHILL Gone DUTCH
Posted 30 September 2016 - 06:06 PM
I did that before adding the ignition, Peter changed his to 0.85 so I thought to it first then I could always try 0.78 later on on top of the ignition
#3247 oakmere
oakmere
  • 2,143 posts
Posted 30 September 2016 - 06:44 PM
Have you tried 0.85?
#3248 The Batman
Posted 30 September 2016 - 06:47 PM
He's too busy watching Bridget jones I imagine he wants to do some fluid injection later :lol:
#3249 CHILL Gone DUTCH
Posted 30 September 2016 - 09:25 PM
After spending the last two weeks of work on the car I think a few hours watching a great film with the wife was well deserved
Edited by CHILL Gone DUTCH, 30 September 2016 - 09:26 PM.
#3250 CHILL Gone DUTCH
Posted 30 September 2016 - 09:45 PM
I also got a email back from peter It looks like I've got to turn Off the oem protection as there is a lot of heavy retardation even with low knock So it's time to reduce ignition by 2 degrees with protection off and see where we are Then see how it goes Frank has also sent me some data to read up on
#3251 CHILL Gone DUTCH
Posted 30 September 2016 - 09:48 PM
Not yet Can anyone tell me if I want high % of flame velocity
#3252 smiley
Posted 30 September 2016 - 09:55 PM
It looks like I've got to turn off the oem protection as there is a lot of heavy retardation even with low knock
That's interesting. Everything  under 1 still ignored by the ecu, or stuff between 0 and 1 also impacts retardation?
Do we know the retardation correction for knock?
Edited by smiley, 30 September 2016 - 09:57 PM.
#3253 CHILL Gone DUTCH
Posted 30 September 2016 - 10:10 PM
In pro you can set up between rpm / kpa how much the knock is ignored and reacts
#3254 CHILL Gone DUTCH
Posted 30 September 2016 - 10:12 PM
I think peter must of set this up in v2
#3255 CHILL Gone DUTCH
Posted 30 September 2016 - 10:13 PM
It's all a new learning curve in the pro version and the water injection
#3256 smiley
Posted 30 September 2016 - 10:18 PM
I was thinking of the time needed to spend to get it all flat (ie as close to 0 if possible) if it''s worth it.
For the non pro users out there.
#3257 CHILL Gone DUTCH
Posted 30 September 2016 - 10:23 PM
If your going for water injection surely all of this has proven you need a failsafe map and Be able to control from the ecu
#3258 CHILL Gone DUTCH
As the map seems area night and day away from each other
#3259 smiley
Posted 30 September 2016 - 10:51 PM
Let me refrase.
Is it worth it for regular obdtuner people to battle knock between 0 and 1 degree in the mapping?
ie does the ecu protection kick in under 1, and if yes how much?
#3260 CHILL Gone DUTCH
Posted 01 October 2016 - 07:15 AM
Let me refrase.   Is it worth it for regular obdtuner people to battle knock between 0 and 1 degree in the mapping? ie does the ecu protection kick in under 1, and if yes how much?
To my knowledge under 1 the ecu protection is nothing above 1. It certainly does retard ignition
