Project Chill 1
#3261
Posted 01 October 2016 - 07:41 AM
#3262
Posted 01 October 2016 - 08:01 AM
To my knowledge under 1 the ecu protection is nothing above 1. It certainly does retard ignitionLet me refrase. Is it worth it for regular obdtuner people to battle knock between 0 and 1 degree in the mapping? ie does the ecu protection kick in under 1, and if yes how much?
Thanks,
Does pro show the retardation correction from the oem protection?
(ie how many between 1 and 2 degree knock, 2 to 3 degreee etc?) I am very interested in understanding the standard protection features, due to it;s black boxed nature.
Edited by smiley, 01 October 2016 - 08:15 AM.
#3263
Posted 01 October 2016 - 08:43 AM
Thanks,
So am i stefan,
ive been out this morning and the car is now just better, the way it pulls etc etc
ive sked peter a few questions and i dont even know at this point if this is the same protection peter disables in V2 with stronger engines,
im sure it will all come to light but what i can tell you turning it off has worked the water injection map is now consistent which i was wasent getting before due to the protection
i now dont think ive fpunf the optimum ignition but do feel comfortable now it will be safe for me to use on track
#3266
Posted 01 October 2016 - 08:57 AM
Is it me, or does it show not much use to rev it over 7k?
#3267
Posted 01 October 2016 - 08:59 AM
its more to do with the ignition holding on stefan
it was bvloody cold this morning
#3269
Posted 01 October 2016 - 09:28 AM
I was expecting something intelligent or sarcastic But it never arrived Maybe even some useful information3.1what pulley are you running?
#3270
Posted 01 October 2016 - 09:40 AM
Ignition is not optimised it probably needs a little more ignition at the top But I'm happy now to use itIs it me, or does it show not much use to rev it over 7k?
#3271
Posted 01 October 2016 - 09:46 AM
Would be fun to hit 400, and match Artic Monkey with a larger pully.....
Edited by smiley, 01 October 2016 - 09:49 AM.
#3272
Posted 01 October 2016 - 10:35 AM
It's not a competition lolWould be fun to hit 400, and match Artic Monkey with a larger pully.....
#3273
Posted 01 October 2016 - 11:21 AM
It would be a clear message towards silly pullies though.
#3274
Posted 01 October 2016 - 11:24 AM
Maybe the water injection projects will make the most of the silly pullies
#3275
Posted 03 October 2016 - 08:35 PM
oulton park tomoz and feeling anxious
#3276
Posted 03 October 2016 - 09:55 PM
386 constant bhp.........have fun
#3277
Posted 04 October 2016 - 12:04 PM
#3278
Posted 04 October 2016 - 12:50 PM
Previously reported on those codes:
P1271 = Corroded or poor contact on connections on throttle loom. (Clean with contact spray or fix) = Wiring near stickshift exposed/damaged.
P1514
= scangauge set to showing more then 3 values = faulty injector = faulty map sensor = Leak in inlet manifold
#3279
Posted 04 October 2016 - 01:47 PM
ITs a good job i fetched the hole 25 litre bottle of water Lol Getting about 15 mins out of the header tank But the power is hanging on very well Will try and get some data this afternoon Down side I've had a 1271 code pop up a few times and got a 1514 I think it was first thing this morning
Are you experimenting with the minimal amount of water needed to keep your track temps under control?
#3280
Posted 04 October 2016 - 01:54 PM
iirc he is using the washer bottle tank, so i don't think he has much choice.
