Project Chill 1
#3301
Posted 04 October 2016 - 07:31 PM
#3302
Posted 04 October 2016 - 07:39 PM
Edited by CHILL Gone DUTCH, 04 October 2016 - 07:39 PM.
#3303
Posted 04 October 2016 - 07:42 PM
#3305
Posted 04 October 2016 - 07:46 PM
#3307
Posted 05 October 2016 - 06:46 AM
im sure the temps would of stayed between 30 and 40 for as long as the water lasted,
one thing i did think about last night was changing the restrictor in the fast acting valve to a smaller one i will put this on my list to try next
ive tried reducing the duty cycle to the controller but this didnt cool as well and also tried altering the controller to control the water later and this didnt work well with the temps
so there is a few more things to try which will reduce the amount of water used and be effective
#3308
Posted 05 October 2016 - 07:27 AM
IAT's between 30° and 40°C while giving it the beans on track is an achievement...
How about fitting a size smaller jets? (a PITA to access/fit now...)
#3309
Posted 05 October 2016 - 07:34 AM
yes this would be a PITA to do but is a option, i will try puting a smaller restrictor in the fast acting valve first and then see how that goes
my thinking was keeping the duty cycle the same but restrict the a amount of water
but its working and at the moment im happy there will also be a bit of fine tuning in the map as i dont think im making the most of the water with ignition yet, the failsafe is working great, a the water gets lower the second map kicks in the bit to becareful off as the ecu comes out of failsafe when you get the water at a level with the sensor it takes three seconds for the water to kick back in.
#3310
Posted 05 October 2016 - 10:23 AM
#3311
Posted 06 October 2016 - 08:17 AM
#3313
Posted 06 October 2016 - 03:14 PM
#3314
Posted 06 October 2016 - 04:07 PM
Does this mean my tires will be bald quickerShark helmets are the fastest. In white they're worth at least 30bhp.
#3315
Posted 06 October 2016 - 05:21 PM
You might be lucky but I only use my black HJC in the vx these days. My white shark is reseved solely for motorbike use. If you want tyre life, try a yellow Arai.Does this mean my tires will be bald quickerShark helmets are the fastest. In white they're worth at least 30bhp.
#3316
Posted 07 October 2016 - 01:08 PM
#3317
Posted 07 October 2016 - 01:10 PM
#3318
Posted 07 October 2016 - 01:18 PM
#3319
Posted 07 October 2016 - 01:19 PM
Could well be the arms Has anyone else had issues ??Wondering if it's something to do with those fancy steering arms? Surely you can't forget to do both nuts up lol
#3320
Posted 07 October 2016 - 01:49 PM
