Project Chill 1
4396 replies to this topic
#3321 VXT Tim
VXT Tim
    No it's not a Lamborghini!
  • 11,421 posts
Posted 07 October 2016 - 02:18 PM
I will have a look at mine later but I'm pretty certain mine haven't had ANYWHERE near as much use/abuse.
#3322 CHILL Gone DUTCH
Posted 07 October 2016 - 07:43 PM
I have those arms and never liked how little thread protrudes from the ball joint when done up. If the nut loosens on oem it should at least stay down the thread so if the taper fit goes it just gets loads of play rather than loss of control. On these arms the nut barely has a thread out the nylon.
The nut goes on a good complete 2-3 threads Not sure what else you would need as long as the nut is completely on threads I'm more concerned on why and how they have worked lose There is obviously a lot of heat from the brakes but this haven't changed from last year I will keep monitoring the nuts and see if they listen again
#3323 CHILL Gone DUTCH
Posted 08 October 2016 - 02:00 PM
#3324 CHILL Gone DUTCH
Posted 12 October 2016 - 10:13 AM
Oh new things
#3325 chris_uk
Posted 12 October 2016 - 10:42 AM
Whats the weight saving over standard??
#3326 CHILL Gone DUTCH
Posted 12 October 2016 - 12:32 PM
Spark plugs are looking a lot browner now with the water injection which is good
They might still need going one step hotter but they are are better than they have ever been will continue to monitor
#3327 CHILL Gone DUTCH
Posted 12 October 2016 - 12:33 PM
I have no idea
#3328 harboged
harboged
  • 392 posts
Posted 12 October 2016 - 01:02 PM
If I remember correctly I got approx 2 kg weight saving per disc. For a 288 mm disc that is.
#3329 smiley
Posted 12 October 2016 - 01:14 PM
Can't find those disks on the EP website.
Are they the regular alu belled ones but now coated and with EP  tuning sticker, or is it a new product?
Edited by smiley, 12 October 2016 - 01:14 PM.
#3330 Arno
Arno
  • 1,238 posts
Posted 12 October 2016 - 01:47 PM
10 bolt PCD on the bell, so likely the existing EP Tuning ones 'spruced up' a little.
#3331 chris_uk
Posted 12 October 2016 - 02:45 PM
not that much then.. i hope they were not too expensive..
#3332 harboged
harboged
  • 392 posts
Posted 12 October 2016 - 02:52 PM
Keep in mind it's unsprung weight ;) Skickat från min SM-G800F via Tapatalk
#3333 CHILL Gone DUTCH
Posted 12 October 2016 - 03:14 PM
  not that much then.. i hope they were not too expensive.. [/quote] Well with in my budget for rear discs
#3334 chris_uk
Posted 12 October 2016 - 04:56 PM
Of cause, im putting together a disc kit atm and if you was to replace standard 308 fronts and 288 rears with mine you will be saving 14kg of unsprung in total.
#3335 harboged
harboged
  • 392 posts
Posted 12 October 2016 - 05:11 PM
Yeah the 308s are very heavy. How much weight does your 288s save each then? Skickat från min SM-G800F via Tapatalk
#3336 CHILL Gone DUTCH
Posted 12 October 2016 - 06:38 PM
IS the same kit you were putting together at the beginning of the year
#3337 chris_uk
Posted 13 October 2016 - 07:05 AM
well its not been quite so long.. But yes.
#3338 GeorgeBC
GeorgeBC
    Needs a cheaper hobby
  • 3,138 posts
Posted 13 October 2016 - 08:02 AM
Chill and Chris sitting in a tree K I S S I N G
#3339 harboged
harboged
  • 392 posts
Posted 13 October 2016 - 09:08 AM
So how much lighter than standard is one of your 288 discs?
#3340 CHILL Gone DUTCH
Posted 13 October 2016 - 09:28 AM
He was supposed to be bringing me a set to look at to croft ( first track day ) which did not happen don't hold your breath about them But a guarantee you will get some attempted sales bull
