Project Chill 1
4396 replies to this topic
#3481 Nev
Posted 01 May 2017 - 10:49 AM
Phew, Georges car certainly takes off like a scalded cat.
You guys really should try your hand at rock climbing, the adrenalin and intensity of the moment is much the same, though of course you also get fit too. Most indoor climbing walls do intro lessons (makes a good present for Xmas or B'day).
Edited by Nev, 01 May 2017 - 11:04 AM.
#3482 CHILL Gone DUTCH
Posted 01 May 2017 - 10:51 AM
You guys really should try your hand at rock climbing, the adrenalin and intensity of the moment is much the same. Most indoor climbing walls do intro lessons.
yep the ways georges car took of out the corners was ammense, not sure if this was down to the LSD or the fact he was using the R888Rs
if i tried to do that i just lit the tires up
as for the rock climbing i ca barely do a press up never mind lifting my body weight up a vertical wall
Edited by CHILL Gone DUTCH, 01 May 2017 - 10:53 AM.
#3483 CHILL Gone DUTCH
Posted 01 May 2017 - 04:52 PM
From George's car following me Seems I was losing a lot of time in the mountain area to
Edited by CHILL Gone DUTCH, 01 May 2017 - 04:53 PM.
#3484 chris_uk
Posted 01 May 2017 - 07:04 PM
its more to do with using your legs. :)
#3485 CHILL Gone DUTCH
Posted 26 May 2017 - 10:43 AM
Update Next month I'm going to croft with lee, luke, and Joe with LOT which I'm going to use as a bit of a practise day a few days before a sprint also at croft on the 25th June which I'm really looking forward to I'm now really happy with the amount of water I'm now adding in to car to keep the inlet temps down Which is as little as possible , I've also setup pro to reduce the amount of water when the temps are already low ( below 40 degrees ) by 90 % of target and also 110% when inlet temps go more than 60 degrees I've also been exploited a few of the other features in pro I'm now using the wideband to control the fueling for anything other than idling Future plans I've been posting on a other thread about reducing the wheel size of the to 15" wheels which now looks like it's going to happen one way or a other The ZZRs are coming to the end of there life now but have a new set of rear R888R to go on rather before the sprint or just after So then when they are dead I'm hoping to have the 15s ready to go on the car
Edited by CHILL Gone DUTCH, 26 May 2017 - 10:45 AM.
#3486 ufods
ufods
  • 235 posts
Posted 26 May 2017 - 08:05 PM
...i have a question regarding the Aquamist system? Is it only connected with the EGR out port to get the data how tho spray? Or is it also connected with one of the injectiors?
#3487 CHILL Gone DUTCH
Posted 26 May 2017 - 08:08 PM
Just the egr I assume peter has picked up the INjector from the ecu to the egr Then the failsafe uses the wiring from the redundant second lambda
Edited by CHILL Gone DUTCH, 26 May 2017 - 08:09 PM.
#3488 CHILL Gone DUTCH
Posted 26 May 2017 - 08:13 PM
Don't forget a resistor And change the controller to accept positive pwm
Edited by CHILL Gone DUTCH, 26 May 2017 - 08:15 PM.
#3489 ufods
ufods
  • 235 posts
Posted 26 May 2017 - 08:22 PM
In the moment I have some strange problems with my Snowperformance system. I hope I can cure it. But the Aquamist is damn expensive. But I believe it is the better system Thanks for your answer!
#3490 CHILL Gone DUTCH
Posted 03 June 2017 - 01:39 PM
attention has now moved towards croft sprint on the 25th month (really looking forward to this )
list of things to do
1. hard top on
2. bleed brakes
3. possibly new set of tires (already in garage just in case )
also going to croft a few days before for a track day to home in on the track
Now im going for the win, but a few things have crossed my mind since entering, ive entered in class B2 which my car fits in to the regs absolutely fine, how ever the rules in classes are quite lose and subject to javelins thoughts, so could get moved up a class if its seen that i have to much of a advantage how ever if i get bumped up there is  probably little chance of winning against cars on non E marked tires
no i dont no how me and the car are going to compare to other competitors and im certainly not taking a win for granted but by the looks of things i dont want to win by a huge margin (which might not even be possible )
so my thoughts are if weather conditions look to be the same through out the day
1st run get a banker in not fast but hopefully this will give me a idea on the competition but there probably also playing games
and take it from there and build up as the day goes on
from a car point of view
looks like i will be queuing up towards each run which means the car is going to be hot so i have  reduced my road map fan start point to 92 degrees so the coolant should be cool , then when i switch to the water injection map just before run the fan will stop as the fan will trigger at a higher temp  probably 105 or something like that
tires and brakes are going to be cold which is playing on my mind a little so starts will be like miss daisy i think unless i decide to be a thug and light up the tires in a attempt to get some heat in then ?? not decided yet
on the track day a few days before i will be pushing on the first lap trying to get a feel for things when tires and brakes are far from optimal
Has anyone else got any other tips or ideas for standing start one lap events
tire pressures etc ?
#3491 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 03 June 2017 - 05:16 PM
I'm sure I've read tyre manufactures recommendations on warming up tyres and they say a couple of gentle heat cycles is the way to go rather than lighting them up which can knack the rubber. Will they be brand new tyres? Sent from my iPhone using Tapatalk
#3492 CHILL Gone DUTCH
Posted 03 June 2017 - 06:34 PM
Will get a few heat cycles on them in morning
#3493 The Batman
Posted 03 June 2017 - 08:54 PM
I tried being a thug and ended up spinning. The crowd said it was epic for 5 or so seconds :lol:
#3494 Captain Vimes
Captain Vimes
  • 2,755 posts
Posted 04 June 2017 - 08:42 AM
Set cold tyre pressures slightly higher than for a track day. It's an alien feeling not doing a lap or two to warm everything up so its worth practicing a fully committed out lap during the track day. Tyres should be warm in a couple of corners. I'd aim to spin the tyres a bit but not a complete bonfire.
#3495 hughcam
hughcam
  • 730 posts
  • Interests:driving, motorcycling, snowboarding, v12 lawn mowers
Posted 04 June 2017 - 05:41 PM
I will be impressed if you can get near to Dale in the Exige 350 sport. Its a very quick car!
#3496 CHILL Gone DUTCH
Posted 04 June 2017 - 06:19 PM
Yes seems to be very quick, hope i can compete with him
he has not yet booked
but sent him a message and he indicated he was going
Edited by CHILL Gone DUTCH, 04 June 2017 - 06:21 PM.
#3497 CHILL Gone DUTCH
Posted 19 June 2017 - 01:10 PM
Took a bit of convincing to get him to bring the exige, he  had a choice of his  mclaren,subaru which he has just got going,
but glad to see him on B2 grid and Ben has also entered, so some vx love going on
looks like we have 10 runners in B2 so see how it goes
#3498 CHILL Gone DUTCH
Posted 25 June 2017 - 08:12 PM
What a epic long weekend, must first of all say thank to luke (Haggie) for putting me up and doing some of the sh1t work that has to be done on these things,    This is how my sprint day went  Run 1 on brand new un-scrubbed R888R
Edited by CHILL Gone DUTCH, 25 June 2017 - 08:18 PM.
#3499 CHILL Gone DUTCH
Posted 25 June 2017 - 08:24 PM
Run 2
Edited by CHILL Gone DUTCH, 25 June 2017 - 08:25 PM.
#3500 CHILL Gone DUTCH
Posted 25 June 2017 - 08:39 PM
i forgot to start the video for run 3 but it was a 1:35.50 (over driven) here is run 4 1:34.86
Edited by CHILL Gone DUTCH, 25 June 2017 - 08:40 PM.
7 user(s) are reading this topic
0 members, 7 guests, 0 anonymous users
