You need to go 4 pots Chris will help on cooling and cracking .i have elise parts and ap discs all with no problem
4 pot front with ap discs and 2 pot rear with elise parts .
Posted 15 July 2017 - 08:50 PM
Posted 16 July 2017 - 11:35 AM
Posted 16 July 2017 - 11:38 AM
I hope not lee But we will see
i have a set of 4 pots in the garage borrow them if you want ?
Posted 24 July 2017 - 08:19 AM
Posted 24 July 2017 - 08:32 AM
why don't you enter the time attack?
Posted 24 July 2017 - 09:06 AM
There's more than one reason But the main one is the money I would have to spend to be able to compete In the sprint series there no requirement to spend a lot , but just need to tweak things I also like the standing start, and there's no sponsors of the series which say you have to use this tire and these bit and bobswhy don't you enter the time attack?
Posted 24 July 2017 - 09:27 AM
Posted 24 July 2017 - 09:30 AM
Do I detect a hint of sarcasm in that quoteFair enough. TA does cost a lot, i just thought it would be a better showcase for your car/tallant.,
Posted 24 July 2017 - 09:33 AM
If you're wearing pads out so quickly, try an endurance compound. I used RS29s in the BM, it's illogical, but they worked as well as the other Pagid compounds but lasted a full season. I wouldn't have used them unless they were at least the equal of others in the market at stopping the car. Don't know if 29s are available for our caliper.
I bought a set of RC8s for Pembrey. Selected during a chat with the distributor Paul at Fortuna Moto. They amazed me how good they were. I can't speak for their longevity, but the 6E could be worth a go?
Edited by Pidgeon, 24 July 2017 - 09:34 AM.
Posted 24 July 2017 - 09:43 AM
It's not just the pads its more about the pads and disc combo overheating The set of front discs which were inspected by EP have been taken beyond there maximum opperating temp which caused the cracking EP are going to replace the cracked disc as a good will gesture but can't guarantee it won't happen again with my car setup and use, so it's unlikely I will be using them again on the frontIf you're wearing pads out so quickly, try an endurance compound. I used RS29s in the BM, it's illogical, but they worked as well as the other Pagid compounds but lasted a full season. I wouldn't have used them unless they were at least the equal of others in the market at stopping the car. Don't know if 29s are available for our caliper. I bought a set of RC8s for Pembrey. Selected during a chat with the distributor Paul at Fortuna Moto. They amazed me how good they were. I can't speak for their longevity, but the 6E could be worth a go?
Posted 24 July 2017 - 09:50 AM
kinetic energy down the straights and corner apex , both greatly affected by torque and mass.
Posted 24 July 2017 - 10:15 AM
Time to put your hand in your pocket. You have one of the most powerful VX's here, it's about time you got a braking system to match
Can't run a vx on a fiver and all that.
Edited by SteveA, 24 July 2017 - 10:16 AM.
Posted 24 July 2017 - 10:35 AM
Posted 24 July 2017 - 10:46 AM
I wish I had only spent a fiver then it would hurt less Not many guarantees once you get on track not even from APTime to put your hand in your pocket. You have one of the most powerful VX's here, it's about time you got a braking system to match
Posted 24 July 2017 - 10:47 AM
Do you have 4 pots I forget nowJust as im in the last stages of getting my discs sorted.. good timing.
Posted 24 July 2017 - 11:18 AM
4pots + 2 pots.
there will be a 288mm option as well if you want to keep standard sizing.
Edited by chris_uk, 24 July 2017 - 11:19 AM.
Posted 24 July 2017 - 11:22 AM
Ah your talking about the bells and rotors your having made What are the guarantee on these4pots + 2 pots. there will be a 288mm option as well if you want to keep standard sizing.
Posted 24 July 2017 - 11:26 AM
guarantee.. i guarantee they will be expensive.
comparisons from solid 308/288 sizes they save approx 14kg of un-sprung weight.
Edited by chris_uk, 24 July 2017 - 11:27 AM.
Posted 24 July 2017 - 11:38 AM
Maybe you should give a set to someone known to be very heavy on brakes for analysis and testing to build up a good repguarantee.. i guarantee they will be expensive. comparisons from solid 308/288 sizes they save approx 14kg of un-sprung weight.
Posted 24 July 2017 - 12:51 PM
0 members, 9 guests, 0 anonymous users
