Project Chill 1
#3681
Posted 15 August 2017 - 01:40 PM
#3682
Posted 15 August 2017 - 01:48 PM
Fair comment. Lets wait and see..£1600 is a lot to spend on a unproven product, but who knows when you have finished them and proven them they might be good option but until that time im quite happy spending a lot less money, admittedly a lot heavier than your claims on yours, but keep me posted on them.Chav-tastic
Final stages for mine now.. getting milled up and final fitment will be in a week or two.
#3683
Posted 15 August 2017 - 01:49 PM
who you getting to test them chris? by your own admission your not hard on brakes,
#3684
Posted 15 August 2017 - 01:54 PM
Forged wheels... forged wheels... forged wheels...
Good move on the brakes though, I think you'll be fine now.
Lets hope so, just a case of how long the the pads last, i think the sprint on Saturday at Anglesey will probably be the last outing for the car this year unless i get a sneaky Oulton park TD in, im at a bit of a crossover point in what im going to do,
im ready for a new set of wheels probably wider to try and help get the power down, but do i change to lotus hubs ?
decisions decisions
#3685
Posted 15 August 2017 - 02:24 PM
What benefits would you get from Lotus hubs?
#3686
Posted 15 August 2017 - 02:26 PM
more wheel options and alcon do brake kits for lotus hubs
floating discs and bells
wheel options
Edited by CHILL Gone DUTCH, 15 August 2017 - 02:30 PM.
#3687
Posted 15 August 2017 - 03:52 PM
Edited by pete-r, 15 August 2017 - 03:53 PM.
#3688
Posted 15 August 2017 - 04:00 PM
#3689
Posted 15 August 2017 - 04:11 PM
#3690
Posted 15 August 2017 - 04:31 PM
#3691
Posted 16 August 2017 - 08:44 AM
if the weight is close to the centre of rotation, its not so bad , but the tyres really do create a lot of force on a high speed corner , you will notice it at Spa, or Copse/Stowe at Silverstone
#3692
Posted 16 August 2017 - 09:09 AM
went for a drive yesterday and the difference is a lot between the EP bells and rotors and the 308mm single piece discs i hope it not upset the car to much as it was feeling particularly good this year, time will tell, as its all experimental at the moment and the the target is to try and get pads to last longer and then maybe moving on to something a little lighter,
#3693
Posted 16 August 2017 - 11:11 AM
#3694
Posted 16 August 2017 - 11:26 AM
the feel is so much more heavier on the wheel and where i haven't been on track yet when loading the car up on the front axle it just seems lazy and less responive
#3695
Posted 16 August 2017 - 12:53 PM
How is the brake bias? Not too much front now??
I struggled a lot with this on my car (std brakes on normal 288mm discs and RC6 pads) and now finally have a less front-heavy bias. So I'm able to brake later and brake-turn it into a corner, instead of locking the fronts up early...
#3696
Posted 16 August 2017 - 01:09 PM
ive never had a issue wit the fronts locking up early/first and until ive been on track wont really know if anything when using the same discs front and rear i would say the rears were a bit snappy when braking in a straight line but this could be down to other issues rather than locking up
will have to see how it goes,
Frank what size front tires do you run ? i use 205 which gives a lot more grip than the 195
Edited by CHILL Gone DUTCH, 16 August 2017 - 01:16 PM.
#3697
Posted 16 August 2017 - 02:48 PM
What is your configuration?How is the brake bias? Not too much front now?? I struggled a lot with this on my car (std brakes on normal 288mm discs and RC6 pads) and now finally have a less front-heavy bias. So I'm able to brake later and brake-turn it into a corner, instead of locking the fronts up early...
#3698
Posted 16 August 2017 - 02:58 PM
That's exactly the feeling I get when I say lighter set up is more finger tippy, On the old setup I steered more with my shoulders, but now the fronts feel narrower even though they are the same size and on stickier tyres.the feel is so much more heavier on the wheel and where i haven't been on track yet when loading the car up on the front axle it just seems lazy and less responive
#3699
Posted 16 August 2017 - 03:47 PM
#3700
Posted 16 August 2017 - 03:48 PM
Std brakes, std 288mm discs, RC6 pads. Toyo 888's 205-40-17 / 225-45 17. Quantums blacks. 550lb/ 650lb, 1 inch ARB. Around 115-130mm ride height.
Last trackday at Zandvoort I also disconnected the rear right ABS sensor (left front was already off) and that made the difference in more rear brake bias...
Bing (2)
