backwards running can put exhaust gas into the intake manifold which takes time to clear.
along with unburnt fuel,
sizeten where did you get your 9J rears ??
Posted 20 August 2017 - 11:49 AM
Posted 20 August 2017 - 11:58 AM
Posted 20 August 2017 - 12:50 PM
there was a group buy direct from rimstock , http://www.vx220.org...-team-dynamics/
Posted 20 August 2017 - 04:17 PM
Time for an LSD I think.Here is my Church spin
Posted 20 August 2017 - 04:54 PM
do you think a lsd would help ??
heard mixed reviews about them
Posted 20 August 2017 - 05:32 PM
Posted 20 August 2017 - 06:02 PM
Worth trying wider rear tyres? Exige V6 has 265s and I guess you have similar torque now?
Posted 20 August 2017 - 06:13 PM
v6 has TC aswell
i am contemplating fitting a lsd this winter.. group buy?
Posted 20 August 2017 - 06:32 PM
Having some driving tuition has to be your next step Chris. You have a really powerful car there and that was a really simple little step out there that should really have been a nothing more than a dab of corrective lock. I would not advise fitting an LSD until you learn how to control oversteer and how the balance and weight distribution affects the balance of the car. LSDs are good fun in Lotus cars (we have one going into our Honda build and my Cayman has one from the factory) but you have to really know how to peddle to get the benefits from one in terms of actually making you go quicker. I am not in that category by the way just like hooning sideways out of junctions. Its the fact that you really have to be a very good driver to use an LSD that makes most Lotus drivers shy away from them as most (like your V6 competition) just rely on having lots of power and mechanical grip. Of course the V6 traction control is a bit more than traction control too its a full on assist (Race) mode so I would see their results as artificially quick. If they were made to switch off I think we would have sold 6 clamshells every weekend they were out
Posted 20 August 2017 - 07:24 PM
Posted 20 August 2017 - 07:31 PM
Posted 20 August 2017 - 10:05 PM
On the first run you are a cars width to the right when you do the fast right which pushes you to far to the left at high speed for the 90 degree left after. You sort it on the second run.
Hand position will massivly help with car control. The centre of your hands needs to be at or below the horizontal centreline of the steering wheel. That way when you're turning you are pushing up to turn the wheel and the feedback you'll get will be much greater.
Posted 20 August 2017 - 10:50 PM
Posted 21 August 2017 - 06:25 AM
Posted 21 August 2017 - 07:01 AM
what mark said really is so important. personally, before getting any more stuff for your car i would learn to hold your wheel properly, the higher up the steering wheel you go the harder it will be to correct any slide. Your clips demonstrate that you're over correcting a lot of the slides which is going to cost you masses of time.
also, it looks like your sat a little too far away from the steering wheel and you could do with bringing the wheel slightly closer to your chest, ideally your forearm and upper arm should sit approx 90° to each other. when you sit in the car your wrist should just rest on top of your wheel.
get those 2 things correct and i think your will sort most of your immediate problems out.
Posted 21 August 2017 - 08:23 AM
1 horse race 😄
I dont think anyone would want to take away anything from Chris on actually going out there and having a go but if you are going to put it all over social media you have to take the rough with the smooth and it is true to say you dont actually have any direct competition. Reading the regs on Javelin I would actually place your car in A1. The B2 class "Your average trackday vehicle, a medium level of performance enhancing parts can be fitted" This is not an engine swapped car with a huge SC running over double stock power.
If you look at the overall results ignoring the Atom which is a silly thing to pretend to be competing in that puts you 13th but 6 seconds off the pace. If you took on some tuition and advice you could eat into that and that would be a real achievement to be proud of. Surely it would be more enjoyable as well to feel that you are actually competing? Hughcam is only 3 seconds behind you with 190BHP on tap in his Exige too. In fact everyone quicker is in the daft stuff so he has actually done really very well.
And hold your fecking wheel properly!
Posted 21 August 2017 - 08:34 AM
Posted 21 August 2017 - 08:40 AM
Where they put the thumbgrips
Posted 21 August 2017 - 08:57 AM
