Project Chill 1
4396 replies to this topic
#361 CHILL Gone DUTCH
Posted 05 May 2013 - 05:10 PM
Ok I couldn't wait any longer I've been out to do a other run
Power Bhp
256.5 BHP
337 NM @ 4000
#362 CocoPops
CocoPops
  • 17,182 posts
Posted 05 May 2013 - 05:26 PM
337nm seems a little optimistic? :unsure: that's around 250lb/ft? Should be closer to 220-225 lb/ft I think?
#363 CHILL Gone DUTCH
Posted 05 May 2013 - 05:27 PM
I thought the same but thought I would post it anyway
#364 CHILL Gone DUTCH
Posted 05 May 2013 - 05:29 PM
I guessed the weight of the car so we will have to results with I pinch of salt for now, But it's still made me smile
#365 CocoPops
CocoPops
  • 17,182 posts
So is it all mapped now? Worth a 30/40quid power run on a local rr?
#366 CHILL Gone DUTCH
Posted 05 May 2013 - 05:30 PM
Does anyone no how much a stage 2 SC should weigh including half a tank of fuel no weight reducing
#367 CHILL Gone DUTCH
Posted 05 May 2013 - 05:33 PM
Probably but I'm waiting to after the Highland hoon now,
I just want to drive it now and stop pissing around with the program
EFI are going to see if they can squeeze anything else out of it, see how good the self mapping process is
Edited by Chill, 05 May 2013 - 05:34 PM.
#368 smiley
Posted 05 May 2013 - 08:11 PM
A few dutchies had the same comparable result earlier this week.
I also think the nm's are calculated to optimistic.
Just get a decent dyno to be sure.
#369 Rosssco
Rosssco
  • 4,183 posts
Posted 05 May 2013 - 09:04 PM
Your running a smaller pulley though? 3.1? And maybe that porting on the SC outlet is helping ;-)
#370 CHILL Gone DUTCH
Posted 05 May 2013 - 09:27 PM
I was hoping to get torque lower down with the 3.1 Pulley,
its what i wanted, but it does seem a tad high
who knows at the moment that is all i have and it might be right.
:D Or :groupjump: :jump:
#371 smiley
Posted 05 May 2013 - 09:41 PM
Thought you were on a 3.35. The dutch guys were on that, getitng those results. On a 3.1 it could be correct.
#372 CHILL Gone DUTCH
Posted 07 May 2013 - 06:09 PM
Bump
#373 Rosssco
Rosssco
  • 4,183 posts
Posted 07 May 2013 - 06:14 PM
Bump
Circa ~900kg I believe, which is just NA kerb + 25-30kg for the Stage 2 conversion.
#374 CHILL Gone DUTCH
Posted 07 May 2013 - 06:30 PM
Ok 900 +. 30kg Sc stage 2 100kg me. No comment Total. 1030 kg I underestimated the weight of me and car by 50 kg or so Thanks Ross
#375 Rosssco
Rosssco
  • 4,183 posts
Posted 07 May 2013 - 07:46 PM
No I meant 875 + 25kg
#376 CHILL Gone DUTCH
Posted 24 May 2013 - 05:17 PM
Ok it's started again after work today,
Need to sort the loud exhaust out and a few other things whilst clam is off
Clam off in around three hours on my own,
George BC will be proud of his apprentice
Then took the exhaust apart to find this
Not Alot in there
#377 CocoPops
CocoPops
  • 17,182 posts
Posted 24 May 2013 - 05:20 PM
What exhaust is/was that?
#378 CHILL Gone DUTCH
Posted 24 May 2013 - 05:21 PM
Tullet
#379 techieboy
Posted 24 May 2013 - 06:32 PM
Not Alot in there
:lol:
Mine with the fancy stuff after 3 years, 16 trackdays and 18000 miles of  Stage 2 and Stage 3 power.
Felt kind of cheated when I opened it up to find that and then it took two hours to put back together again because all of the stuffing was totally intact. Especially as that meant I wasn't going to be able to improve the noise levels. Was definitely worth the £70 extra it cost to have that in when it was made.
Even my mini silencer with one layer of the high temp stuff was fine too.
#380 CHILL Gone DUTCH
Posted 24 May 2013 - 06:39 PM
I was wondering how to wrap it because of the way the tube passes through the exhaust. ( diagonally ) how did you do it techie
12 user(s) are reading this topic
0 members, 12 guests, 0 anonymous users
