Project Chill 1
#3861
Posted 30 September 2017 - 02:02 PM
#3862
Posted 30 September 2017 - 02:55 PM
Have to much time on much handsThere seems to be a lot of 'why bother' challenge here suddenly. I think the answer is 'because I can'! It's just playing cars for a bit of fun.
#3863
Posted 30 September 2017 - 04:12 PM
#3864
Posted 30 September 2017 - 04:16 PM
#3865
Posted 30 September 2017 - 04:22 PM
Im at about 845kg with a cage and extinguisher. I think the cage is 30-40kg?
My front splitter is heavy as it's 12mm ply and I've not cut anything out the clams and doors as far as I remember. I also have a standard battery.
#3866
Posted 30 September 2017 - 04:23 PM
#3867
Posted 30 September 2017 - 04:24 PM
Probably less now than it did before the crash. Definitely more layers of fibreglass though.
#3868
Posted 30 September 2017 - 04:50 PM
#3869
Posted 30 September 2017 - 04:57 PM
Wouldn't bother with wet lay C.F. expensive and won't save you any weight.
VRI FTW
#3870
Posted 30 September 2017 - 05:14 PM
strip out the wiring loom, you will be surprised how much the radio wiring weighs - it goes via the engine compartment to the speakers
I removed a few kilos from my loom, but that included quite a chunk of engine wiring stuff - I have a Webcon ecu
#3871
You got any track days booked?
Not currently, got an endurance race at the end the month but I've slowed the spending.
#3872
Posted 30 September 2017 - 05:21 PM
#3873
Posted 30 September 2017 - 06:16 PM
It can do. My hardtop was wet layed and vac bagged. Came in at 4kg so not too shabby for weight saving.....although I must confess I don't know what an oem roof weighs!! It can be dear though, unless you have a source of cheap materialsWouldn't bother with wet lay C.F. expensive and won't save you any weight.
#3874
Posted 30 September 2017 - 06:30 PM
There was a French guy on here who went to extreme lengths to lighten his VX220 and came to the same conclusion. He gave up eventually and just bought a 450 Kg Radical. No way a VX can compete with that, no matter how much time you spend trying to get it's weight down you won't get near 450Kg (clearly!)
[/quote]
I think you are talking about Rapidos...
He is from Belgium and his Turbo Speedster reach less than 800 kg... But more like a race car, without lights...
But there is also a French turbo owner here: Chris and he is also below 800 kg but has kept all road and esthetic features... (everything looks like an unmodified Speedster) and he kept the 5x110 pattern for wheels.
He is one of the lightest in road configuration.
He has machined some titanium parts to replace heavy steel when it was possible..
#3875
Posted 30 September 2017 - 07:25 PM
[quote name="Nev" post="1935259" timestamp="1506726314
You forgot the Rapist!!!!!!
http://forum.opel-sp...showtopic=37411
796KG for a turbo!
#3876
Posted 30 September 2017 - 07:46 PM
Ah yes, Radpidos - Belgium is the same as France isn't it ?!
Glad to hear you still have your VX220, I think I must have got you confused with someone else who sold theirs.
Edited by Nev, 30 September 2017 - 07:47 PM.
#3877
Posted 01 October 2017 - 10:15 AM
#3878
Posted 02 October 2017 - 10:06 AM
I'm not sure why you'd want a lighter battery anyway - you don't want to lighten the front any more IMO, and any weight reductions should be coming from the rear, or at least matched by corresponding weight reduction at the rear. The battery is mounted very low over the front wheels, so kinda optimal location wise.
Off the wall extreme idea - Do a VX 211.. Remove the front screen completely, the rear screen and all surrounding bodywork to leave just the roll-over hoop. Remove the dash top and replace with a section of carbon fibre sheet. Completely remove the boot and vent the rear clam. Your car will probably be unsellable after this, but you'll come a solid second to the Atom!
#3879
Posted 02 October 2017 - 01:00 PM
#3880
Posted 02 October 2017 - 05:17 PM
If you remove the battery and heater could you relocate some of the engine bay stuff to the front for better weight distribution and better airflow at the back. The cc pump, ECU, there must be other things too?
I agree, I also thought about doing this sort of thing years ago. I even wondered if the CC header tank would be relocatable to the front.
