Project Chill 1
4396 replies to this topic
#3881 pete-r
pete-r
  • 2,771 posts
Posted 02 October 2017 - 05:30 PM
Great minds think alike! Does the cc tank need to be at the highest point? Or could you put the tank in low and a bleed valve up high like the one on the fuel line?
#3882 Nev
Posted 02 October 2017 - 05:46 PM
I think a watertight cap on the top of the CC tank and a bleed valve/filler high up would work fine.
When I rebuilt my exhaust, I considered running the exhaust pipe up the passenger sill and putting a silencer in the sill and where the water heater exchange matrix is, with 2 exhaust tail pipes exiting the bonnet top or near the front wheel arches, sort of American hot rod style. This would have shifted 20+ Kg from the rear to the front and made a substantial difference to the axle weights and also correct the left/right balance. I was concerned about heat output making the epoxy weaken/fail, and also heating up the brake lines, so abandoned the idea.
Edited by Nev, 02 October 2017 - 05:50 PM.
#3883 pete-r
pete-r
  • 2,771 posts
Posted 02 October 2017 - 06:01 PM
If there's a way to shift both tanks to the front, there's going to be benefits on weight and cooling, and the heavy bracket can go. Ecu and cc pump could move forward. There must be more and if you replaced the battery for a tiny one and removed the heater system and used a heated screen [and heated seat pads ;) ] then there'd be a good bit of room for that or even a plumbed in extinguisher. It would effectively remove 1/3 of the bulk at the top of the engine bay so airflow would be much better and could even allow for a more elaborate cold air intake shield above the gearbox so air comes in through the side then is channeled up through the bootlid away from the heat.
#3884 The Batman
Posted 02 October 2017 - 06:09 PM
ecu isnt heavy tho and the wiring that would be involved to move the ecu would outweigh the ecu in the back :lol:
the cc pump is easy to move, as is the cc tank aslong as the filler neck is higher enough to be at the top of the system.
heater system is easy to delete, just blank off at the thermostat.
there would probably be enough room there for chris to mount his water injection pump further forward in the car
#3885 CHILL Gone DUTCH
Posted 31 October 2017 - 04:11 PM
I think i took the car of the road far to early,
getting bored now, but it has aloud me to buy a new set of wheels which will be heavier than my original tds, lol. cant wait for them to come
also waiting on my capacitor battery replacement to come soon and start testing that
now its starting to get  cold its time i got on the garage floor and start the service
its been a nice break not doing anything with the car.
#3886 Nev
Posted 03 November 2017 - 10:50 AM
Does this mean your old TDs are for sale please Chris?
#3887 CHILL Gone DUTCH
Posted 03 November 2017 - 11:52 AM
I've decided the old wheels will have somthing which will deal with water better And the new tires dependant on the rules in the sprint series could have slicks on them
Edited by CHILL Gone DUTCH, 03 November 2017 - 11:53 AM.
#3888 CHILL Gone DUTCH
Posted 21 November 2017 - 08:31 AM
New wheels are in paint and should be ready for end of week, but my capacitors haven't turned up and the seller is no longer on eBay So dosent look promising
#3889 hughcam
hughcam
  • 730 posts
  • Interests:driving, motorcycling, snowboarding, v12 lawn mowers
Posted 26 November 2017 - 01:47 AM
What wheel widths have you gone for? Interested to see what you have planned!
#3890 CHILL Gone DUTCH
Posted 26 November 2017 - 03:58 AM
Going to moving up from the standard 225 rears hopefully will allow me to push harder on the corner exits and help get the power down just a experiment ATM but it can't hurt considering I'm pushing more than double the power of standard Hopefully I can offset the bigger wheels by reducing the weight a little Can't make any final decision on slicks or emarked until rules are announced Plan is to get a class win and class championship next year and if rules are kind I will be jumping from B to A
#3891 CHILL Gone DUTCH
Posted 18 December 2017 - 11:55 AM
#3892 CHILL Gone DUTCH
Posted 18 December 2017 - 11:56 AM
I love it when a delivery comes
Merry Christmas 🎄
#3893 smiley
Posted 18 December 2017 - 12:21 PM
Spending xmass putting the dremel in the vx. We need pix of that.
#3894 CHILL Gone DUTCH
Posted 18 December 2017 - 12:28 PM
It is possible but hoping they fit ok
#3895 CHILL Gone DUTCH
Posted 18 December 2017 - 01:34 PM
Oh 4
#3896 smiley
Posted 18 December 2017 - 01:55 PM
I'm confused. 255 will not fit without arch extenders. Arch extenders have no use without cut out of clam. Are you saying 255 will fit without cutting somehow?
#3897 SteveA
SteveA
  • 9,156 posts
Posted 18 December 2017 - 02:25 PM
I had 255's on mine without arch extensions, it was very tight but no rubbing. I think it depends on camber, tyre make, manufacturing tolerances on hubs, clams, fixings etc.
#3898 CHILL Gone DUTCH
Posted 18 December 2017 - 04:34 PM
Keep my fingers crossed then that I get away with it, I did do some rough calculations to give it a good chance
#3899 SteveA
SteveA
  • 9,156 posts
Posted 18 December 2017 - 04:59 PM
Pics are gone but
http://www.vx220.org...e-tyres-are-go/
#3900 CHILL Gone DUTCH
Posted 18 December 2017 - 05:14 PM
Cool I also ordered et30 rears so sounds promising But sticking with 205 16s on the front for now
