Project Chill 1
#3961
Posted 25 January 2018 - 09:19 PM
#3964
Posted 15 February 2018 - 04:45 PM
#3965
Posted 15 February 2018 - 04:52 PM
do what I think lee did and dremel back the support bar on the clam
#3966
Posted 15 February 2018 - 05:01 PM
Edited by CHILL Gone DUTCH, 15 February 2018 - 05:02 PM.
#3967
Posted 16 February 2018 - 05:48 PM
When I went from a 195 front to a 205 I thought that was amazing hoping for the same on the rear time will tell
I did try a 235 RsR federal before moving to the Avon Zzr which was better slightly
What's happening with the rear of your car steve
Baby turbo Huracan
#3968
Posted 18 February 2018 - 03:52 PM
Don't forget that when you corner hard the bushes will deflect and the rubbing issue will likely become worse...
I get mild rubbage at times (seems to vary) and I have put a thick layer (approx 1mm) of masking tape on the chassis as a witness bearer (so I can monitor the issue). HTH.
Edited by Nev, 18 February 2018 - 03:59 PM.
#3969
Posted 20 February 2018 - 02:03 PM
I am hoping for no modification to the clam or no need to use spacers, but will have to see,
fired her up today after finding the reason for lack of power, ( the exhaust had a hole in it again where the first hanger ripped out a few years ago ) been plated and welded now so hopefully will last a life time,
it also started up a lot easier ( which was nice) fuel trims are slightly out but will take her for a good run and see how it goes,
just need to get the clam back on, adjust the handbrake cable for the bigger wheel, get a track day booked to test the new wheels oh and fit the new brake pads and change the brake fluid
i wanted to do so much this year but work has been busy and family time along with car blues have left me not doing as much as i wanted, but maybe i will get more of this stuff done as the year goes on.
or there is always next winter. This year is primarily going to about doing the best i can in the sprint series.
and on that subject we have had a few other vx220.org owners past and present entered in to the first round at snetterton on 1st of April (batman, cobrav8 (in my class) and 5oclock in a mx5 in a other class along with firthy) so should be a good gathering.
#3970
Posted 13 March 2018 - 03:53 PM
#3971
Posted 14 March 2018 - 07:15 AM
#3972
Posted 14 March 2018 - 12:18 PM
It's lateral G that it going to make it rub and you are never going to be able to replicate that on the road.
#3973
Posted 14 March 2018 - 12:57 PM
#3974
Posted 14 March 2018 - 01:54 PM
If it's gonna rub anywhere it will be at cascades, maybe lodge too.
Edited by SteveA, 14 March 2018 - 01:54 PM.
#3975
Posted 14 March 2018 - 03:22 PM
#3976
Posted 14 March 2018 - 06:06 PM
X2 16x7 et20 5/110 with 65.1mm centre bore and X2 17x9 et30 5/110 with 65.1mm centre boreHi Chilli, I'm really interested how you get on at Oulton on 21st of you get on, I'm down at Donny on the 21st (in my old car). I went down to a local race car set up place yesterday to ask about putting slicks on, but he just recommended using cut slicks, to save all the faff, so I think I'll get a new set of TD rims from deemon tweeks and 888R 255 rear and 205 front. £600 for a set of tyres seems good. Then I'll use rain sports on my standard wheels. Please can you tell me the size off sets PCD and widths etc? Thanks Adam Sent from my LG-H815 using Tapatalk
Edited by CHILL Gone DUTCH, 14 March 2018 - 06:09 PM.
#3977
Posted 14 March 2018 - 06:12 PM
#3978
Posted 14 March 2018 - 06:22 PM
#3979
Posted 16 March 2018 - 12:36 PM
Edited by CHILL Gone DUTCH, 16 March 2018 - 12:39 PM.
#3980
Posted 21 March 2018 - 06:34 PM
13 user(s) are reading this topic
0 members, 13 guests, 0 anonymous users
