Project Chill 1
4396 replies to this topic
#381 techieboy
Posted 24 May 2013 - 06:47 PM
I didn't have to work out how to do it, as mine was all intact (most of the stuffing towards the exit of the silencer was still pure white and looked like new). That's what made it such a pain in the arse to fit back together again, as it wasn't nice tight unexpanded stuffing at the end above.
Smiley posted a couple of pics in the thread the General Discussion that showed how he's done it:-
#382 CHILL Gone DUTCH
Posted 24 May 2013 - 07:08 PM
I will come up with a clever ish way of doing it
#383 2deano5
2deano5
  • 668 posts
  • Interests:Cars / Squash
Posted 24 May 2013 - 07:47 PM
This I will have to see :P
#384 CHILL Gone DUTCH
Posted 24 May 2013 - 07:54 PM
[quote name="2deano5" post="1549119" timestamp="1369424876"]
This I will have to see :P[/quote
I will take a pic tomorrow when I do it
#385 CHILL Gone DUTCH
Posted 25 May 2013 - 04:14 PM
Ok exhaust is back on and full of wadding as for that clever way ..... No It was a case of wrap up the perforated tube in wadding then try and locate it in the exhaust not a easy job to do then I put More in before putting it all together the pipe which runs at angels makes this job a royal pain in the ass I also found out why my fuel gauge wasent working the ceramic plate wasent located low enough, so I put it back, tested it and it worked I then convinced my self that I would need to take it out again to make it more secure I then snapped the ceramic plate so tomorrow I will be putting a other fuel pump holder thing in and hopefully things will be good
#386 CHILL Gone DUTCH
Posted 25 May 2013 - 04:44 PM
I also forgot to mention after SC the car my oil consumption has gone down, if anyone could explain this it would be appreciated, and the engine runs a lot smoother and dosent knock anymore,
#387 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 25 May 2013 - 04:46 PM
Might be the map? How have you got on with the Dutch software and process to map and drive?
#388 CHILL Gone DUTCH
Posted 25 May 2013 - 04:52 PM
It was so easy it was embarrassing to call it a self map. The hardest part is working your way around the software ( which is also quite easy) I have next to no knock throughout the rev range I would strongly recommend it even though I never gone the other route, Me and JT are going to compare Dutch V courtenays soon, we are both running same pulley but john has a better manifold, My torque is massive from 3k revs
#389 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 25 May 2013 - 04:55 PM
Sounds great. It's a matter of when not if I get it. Just need to collect all my parts.
Edited by ArticMonkey, 25 May 2013 - 04:55 PM.
#390 CHILL Gone DUTCH
Posted 25 May 2013 - 04:56 PM
The biggest advantage is yet to come, Because I've re packed my exhaust I'm going to map it again, so it's still running perfectly
#391 oakmere
oakmere
  • 2,143 posts
Posted 26 May 2013 - 03:58 PM
Chill When you have done the fuel I would recommend you run a knock session if you have not done this yet.
#392 CHILL Gone DUTCH
Posted 01 June 2013 - 08:35 PM
I'm going to remap tomorrow afternoon followed by knock session and ignition Will be interesting to compare maps after the exhaust re-pack Im also going to do a log session as Peter has contacted me and asked me to send him a log so he can give a once over for me, And also to see if my injectors will allow me to raise the rev limiter .
Edited by Chill, 01 June 2013 - 08:36 PM.
#393 oakmere
oakmere
  • 2,143 posts
Posted 02 June 2013 - 09:55 AM
Chill Don't go over 7200 on std valve springs. I would stick to 7000 with a SC as JJJ saw valve bounce on his track car at high rpm.
#394 CHILL Gone DUTCH
Posted 02 June 2013 - 10:16 AM
At the moment I'm not going much over 6000 until I have had confirmation the injectors will be ok
#395 CHILL Gone DUTCH
Posted 02 June 2013 - 01:08 PM
Ok been having a play with the car again today,
Margo ( the car) realy dosent want to go to snetterton on Wednesday since the hoon i have:
Repacked exhaust,
Fitted harnesses,
And I still have to take my gaz golds of and send them away to be refurbed, thanks to George BC who has leant me his for the track day,
And to top it all off the roof cable has snapped,,
Few pics from today
Holes are in
George BC managed to nearly cut his leg off with a screwdriver
One in
Both in got a bit anal trying to line OMP badges up
#396 CHILL Gone DUTCH
Posted 06 June 2013 - 10:54 AM
run out at snetterton first time the SC has been put under a bit of presure
#397 techieboy
Posted 06 June 2013 - 11:08 AM
Noooooo. Image stabilisation. It maketh me seasick.
#398 CHILL Gone DUTCH
Posted 06 June 2013 - 04:05 PM
Ooh and on track I managed 101 miles on a 32 litre tank and a 20 litre jerry can, leaving just enough fuel to get to station so around 48-50 litres 101 miles So that's 2.1 miles to a litre Not very impressive 2.1x 4.4 = 9.3 ish miles to the gallon
#399 techieboy
Posted 06 June 2013 - 04:13 PM
I did 7.8mpg in mine, the last time I measured it on track. Wouldn't be much worse if I stuck a scrwdriver through the bottom of the tank on the way to the track. :wacko:
#400 higgins
higgins
  • 126 posts
Posted 06 June 2013 - 05:42 PM
Did you have any more problems with the oil from the driveshaft?
Spotted my car at 6:20 in your vid
7 user(s) are reading this topic
0 members, 7 guests, 0 anonymous users
