Project Chill 1
4396 replies to this topic
#4021 CHILL Gone DUTCH
Posted 06 April 2018 - 11:23 AM
The zt1 I said a lot denser than the ptx Assume it's not as good on sound deadening
#4022 swast4
swast4
  • 416 posts
  • Interests:Trackdays
Posted 06 April 2018 - 09:27 PM
Thanks Chris uk for confirming that I can get the exhaust off without the clam off, that will save me about of hassle. Chris Chilli, I have had a bit of a Google and i take it is a 2bular exhaust, they appear to be the best out there, just trying to use what I've got, so will pack the silencer, blank off one of the tips and take it to Oulton for a static test and see where I am. The other issue is I really want to drive it to work on nice days but I work shift and leave at 6am and I definately can't do that now as its far too loud and don't want to p*ss off the neighbours. Sent from my LG-H815 using Tapatalk
#4023 CHILL Gone DUTCH
Posted 23 April 2018 - 06:41 AM
Exhaust cut open again
Not much left in there and even some of the wire wool has gone
So took it somewhere local to have the back box re-skinned
However after speaking to them they/we decided to make new box
And to make it re-packable and I should be able to access it from the wheel arch
Old and new
#4024 CHILL Gone DUTCH
Posted 23 April 2018 - 08:05 AM
SHINY
#4025 Exmantaa
Posted 23 April 2018 - 11:37 AM
I see they copied the resonance chamber design at the entry?
Edited by Exmantaa, 23 April 2018 - 11:37 AM.
#4026 CHILL Gone DUTCH
Posted 23 April 2018 - 12:06 PM
It's very close to my original with a few minor mods
#4027 CHILL Gone DUTCH
Posted 23 April 2018 - 05:15 PM
#4028 ultimate
ultimate
  • 261 posts
Posted 23 April 2018 - 05:55 PM
What is different to the old Backbox regarding internal design?
#4029 CHILL Gone DUTCH
Posted 23 April 2018 - 06:37 PM
the chamber is not fully open to the main flow its more perforated rather than just completely open and its repack-able on the end cap.
the perforated are large
seems to tick over better with this box
Edited by CHILL Gone DUTCH, 23 April 2018 - 06:40 PM.
#4030 swast4
swast4
  • 416 posts
Posted 23 April 2018 - 08:02 PM
Looks good, much better to be able to repack, as it looks a ball ache to chop out and re weld.� Is that picture opened up showing what was left in it? As it looks like it's empty. Sent from my LG-H815 using Tapatalk
#4031 CHILL Gone DUTCH
Posted 23 April 2018 - 08:15 PM
There was a bit in corner
#4032 smiley
Posted 23 April 2018 - 08:50 PM
How many track days did your wire wool and PTX survive before you noticed the sound increase?
#4033 CHILL Gone DUTCH
Posted 23 April 2018 - 08:56 PM
It's over 12 months It went all of a sudden at snetterton sounded a bit noisey in the morning and before the last lap it was dead
#4034 CHILL Gone DUTCH
Posted 23 April 2018 - 09:05 PM
July 2016 just checked invoice
#4035 swast4
swast4
  • 416 posts
Posted 23 April 2018 - 09:06 PM
When I was on the phone to Tullet I asked about the wire wool wrapped round first and they said that the manufacture (thermal velocicty) don't recommend using it, as it kind of superheats the wool and makes it worse. So I'm not sure what is the best way? Sent from my LG-H815 using Tapatalk
#4036 swast4
swast4
  • 416 posts
Posted 23 April 2018 - 09:07 PM
Just seen that, 2 years and lots of track days is pretty good going Sent from my LG-H815 using Tapatalk
#4037 swast4
swast4
  • 416 posts
Posted 24 April 2018 - 02:26 PM
Hi Chris, I ordered my wider wheels and tyres like yours which where due at the end of the month but I've been on the phone chasing up and one of the rear wheels failed its casting tests and so they won't be making any more for 4-6 weeks....... They have been back on the phone and said that they can get some 17x9s with an et35 rather than a et 30. This pushes the wheel further into the arch, which means I'll need some spacers. So do you think I will just need 5mm to get back to et30 or 10mm after your experiences on track? Sent from my LG-H815 using Tapatalk
#4038 CHILL Gone DUTCH
Posted 24 April 2018 - 02:36 PM
5mm spacer will put you at the same as mine And I think you will need it
#4039 swast4
swast4
  • 416 posts
Posted 24 April 2018 - 08:33 PM
Ok thank you Sent from my LG-H815 using Tapatalk
#4040 CHILL Gone DUTCH
Posted 28 April 2018 - 02:42 PM
also worth mentioning the wire wool is heat treated wire wool
