I'm
Deffo getting more grip from the rider wheels ( loaded side ) but I never thought for a second this would unload the unloaded wheel so much and this in it's self can unsettle the car which means I'm making to many deviations instead of driving through the corner
It sort of/partly makes sense to me that with wider wheels that you'll spin up the inside one more. This is because the difference in grip levels between the fully loaded wheel and the unloaded one are more pronounced now.
If you had an imaginary car with infinite traction on one rear wheel and almost no traction on the other, if you tried to accelerate (with an open diff) you'd just spin up the low traction wheel all the time (and oversteer wildly). In effect, every hard corner you're going round is having this effect. To solve it, you can either implement torque biasing of power (ie ATB diff) or you can try and add positive camber to the inside wheel to plant it more perpendicularly on the tarmac (ie rear ARB).
Do you know someone else with a VX220 with an ATB diff in? Maybe they'd let you have a drive and you could see how it works on a largish roundabout (with plenty of space and no traffic obviously) - try feeding the power in and out and I think you'll be pleasantly surprised by the lack of inside wheel spin.
I have a test roundabout near me that I use for any tweak I make, it's about 15 foot wide. I've set my car up so I can promote oversteer with power and mild understeer with no power. And I never get an inside wheel spinning up. As I said, if I overcook the power then the whole back end steps out, though it's quite progressive and the snap away point comes on slowly so there is plenty of warning when you are getting close.
Edited by Nev, 14 May 2018 - 04:03 PM.
