Project Chill 1
4396 replies to this topic
#4101 chris_uk
Posted 15 May 2018 - 03:45 PM
You need to do is get your geo checked out.. if you do have neutral toe at the rear like you suggestes it might, it wont be helping.. Also, seriously consider improving your driving style, the binary on/off nature of your throttle application is not helping either. Quick but smooth application is what you need to aim for. Also, by uppin the tyre width you are creating a larger area which needs to be warmed up, maybe having wide tyres is actaully hindering the warm up of them and a smaller width tyre would actually be able to generate heat quicker and offer you more grip Can you get your old and new laps together on youtube and look at the differences between your driving techniques?
#4102 SteveA
SteveA
  • 9,156 posts
Posted 15 May 2018 - 03:48 PM
Would a rear arb not make it worse? I have the ep 1" front arb and my inside front wheel sometimes lifts off the road. Wouldnt a rear arb do the same to the inside rear?
All dependent on the damping rebound rates but In Chris' case probably yes as it won't have been optimised for this. Bars, dampers and springs should be matched to work with each other.
I agree that a test day would help but only if you can consistently lap within a few tenths, otherwise it's going to be difficult to isolate the problem.
Chris_uk - How dare you suggest that driving style is at fault! :lol:
Edited by SteveA, 15 May 2018 - 03:51 PM.
#4103 CHILL Gone DUTCH
Posted 15 May 2018 - 03:49 PM
will try and do it now
#4104 CHILL Gone DUTCH
Posted 15 May 2018 - 04:36 PM
#4105 jonnyboy
jonnyboy
    The hardtop guy
  • 8,290 posts
Posted 15 May 2018 - 06:47 PM
Chris. Spring rates!
#4106 CHILL Gone DUTCH
Posted 15 May 2018 - 07:00 PM
Same as last year
#4107 Captain Vimes
Captain Vimes
  • 2,755 posts
Posted 15 May 2018 - 07:21 PM
It looks pretty balanced and well setup in the video. It spins a wheel up coming out of slow corners but that's to be expected (even my 1.6 NA does that).
If you set it up so that it has maximum rear grip out of slow corners then you'll make it worse elsewhere ie. you'll take grip form the front AND with greater drive you'll generate greater weight transfer over the rear and less on the front - so it'll push into understeer much more quickly and you'll have to get out of the throttle anyway.
If you add an LSD it'll also mean you'll push into understeer OR slide the back into oversteer - either way you're not able to break the laws of physics and ask it to take full power out of a slow corner... can't you just feed the throttle in a bit more progressively?
#4108 CHILL Gone DUTCH
Posted 15 May 2018 - 07:35 PM
I'm Sure I can but it's difficult on cold tires you have to aggressive. And as some have mentioned I'm not exactly subtle naturally
#4109 The Batman
Posted 15 May 2018 - 07:51 PM
im going to try larger front tyres as since fitting the lsd it understeers, hoping this will cure it.
#4110 SteveA
SteveA
  • 9,156 posts
Posted 15 May 2018 - 08:01 PM
Where does it understeer? Corner entry, apex, exit, faster corners, slower corners, steady state cornering?
Edited by SteveA, 15 May 2018 - 08:02 PM.
#4111 The Batman
Posted 15 May 2018 - 08:03 PM
tbh only on the really tight corners lol so to be expected even with wider tyres :lol: :lol:
Edited by The Batman, 15 May 2018 - 08:04 PM.
#4112 CHILL Gone DUTCH
Posted 15 May 2018 - 08:04 PM
Front end is bang on . It's perfect
#4113 SteveA
SteveA
  • 9,156 posts
Posted 15 May 2018 - 08:05 PM
Sorry Chris, I meant Joe.
#4114 SteveA
SteveA
  • 9,156 posts
Posted 15 May 2018 - 08:10 PM
As per Captains post your car looks well balanced if you start changing things to solve a heavy right foot you will no doubt upset something else. I'd say tc or softer tyres are your methods of solving low speed mechanical grip issues.
#4115 fiveoclock
fiveoclock
  • 9,453 posts
Posted 15 May 2018 - 08:16 PM
All this talk of spring rates and LSD etc. is all a bit pointless if your contact with the track is inferior. The tyres you have cant possibly be at peak performance on a one lap sprint. Soft compound tyres, standard sizes (195/225) should be your first change. Someone else mentioned it, you could be a bit lighter on the controls!! Soft hands, caress the car round the corners :D
#4116 CHILL Gone DUTCH
Posted 15 May 2018 - 08:27 PM
#4117 CHILL Gone DUTCH
Posted 16 May 2018 - 07:47 AM
plenty of role/lean there
#4118 SteveA
SteveA
  • 9,156 posts
Posted 16 May 2018 - 09:31 AM
Roll in low speed corners is not necessarily a bad thing. In testing the other day I found it made me significantly quicker. Differently balanced car though.
#4119 CHILL Gone DUTCH
Posted 16 May 2018 - 10:15 AM
just out of curiosity what is considered
low speed
medium speed
and high speed
#4120 Captain Vimes
Captain Vimes
  • 2,755 posts
Posted 16 May 2018 - 10:22 AM
just out of curiosity what is considered  low speed  medium speed  and high speed    ??
Ill go for: Low is <50 (hair pins, tight chicanes) High is >90 (Stowe at Silverstone, Riches at Snetterton, coppice at Cadwell..) Medium is everything else
6 user(s) are reading this topic
0 members, 6 guests, 0 anonymous users
