Providing the wishbone mounts are intact, it should live. It also looks like you've avoided damage to the crash structure and radiators, which should keep the cost down to a replacement clam, respray and lights.
Project Chill 1
#4261
Posted 22 July 2018 - 02:20 PM
#4262
Posted 22 July 2018 - 03:29 PM
standard front clams are very weak between lights and grill
#4263
Posted 22 July 2018 - 03:50 PM
not funny crashing is it..
maybe next time you might refrain from taking the p*ss out of people when they crash.
#4264
Posted 22 July 2018 - 04:03 PM
but it happens and a risk all trackers take everytime
Not sure what's your talking by taking by the p*ss
Anyway little update I have brake/clutch fluid coming out of the drivers sill
Guessing it's from clutch
As that's what's failed to work
#4265
Posted 22 July 2018 - 04:10 PM
I thought the clutch line routed by the handbrake down the center?
#4266
Posted 22 July 2018 - 04:12 PM
#4267
Posted 22 July 2018 - 04:20 PM
clutch line goes along passenger sill
#4268
Posted 22 July 2018 - 04:22 PM
most likely the bonnet has nudged the clutch pipework at the master cylinder
lets hope it is not too bad a fix
#4269
Posted 22 July 2018 - 04:23 PM
#4270
Posted 22 July 2018 - 04:25 PM
Sent from my LG-H815 using Tapatalk
#4271
COuld be brake line or the fluid dripping out near sill front clutch
probably dripping down from the clutch master cylinder
#4272
Posted 22 July 2018 - 04:39 PM
Looking for a RR chassis I think
This one probably going to be retired
Or maybe even retire myself lol
Unless the resovoir dropped below the clutch intake
#4273
Posted 22 July 2018 - 04:54 PM
Ok
Needs what have you got
Crash box
Clam
Possible windscreen
Or rolling chassis with engine issues
Pm if you have
Dosent matter of condition
#4274
Posted 22 July 2018 - 05:03 PM
Really weird diagram, the gearbox isn't even on that side! where did this come from?
#4275
Posted 22 July 2018 - 06:39 PM
#4276
Posted 22 July 2018 - 07:57 PM
Not meaning to rub it in if you don’t just curious.
#4277
Posted 22 July 2018 - 08:34 PM
#4278
Posted 22 July 2018 - 08:38 PM
Chris, the car can be repaired! It's a risk we all take when on track. Your next reincarnation of the VX will be even better! I presume you had a trailer?
#4279
Posted 22 July 2018 - 08:44 PM
#4280
Posted 22 July 2018 - 09:09 PM
It's a hard one and have always said when it happens it's time to move on
It's had loads of time and I still have plenty of fancy bits on it, how ever if it goes I won't be coming back
So just going to start taking the damaged bits off and then take it from there,
I'm in no rush but will see,
Slightly annoyed about what looks like is going to be a brake or clutches line issue which could of been the start of the issue,
Must say big thanks to all the people showing support today's and there help if it's required,
