Project Chill 1
4396 replies to this topic
#4301 Arno
Arno
  • 1,238 posts
Posted 24 July 2018 - 08:49 AM
it's surprising how easy the front end is to change on a vx, most parts are simply bolt on and even gluing another crashbox on is not difficult :)
It's the cutting off of the old crashbox and cleaning up the mating/bonding surfaces that's highly annoying though! :D
#4302 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 24 July 2018 - 09:09 AM
even cutting the old one off isnt that bad (if you dont intend to reuse it. getting one off to reuse on the otherhand...
i know the opinion of repo crashboxes, but if considering one, try 'North Plastics' based in greece. they are an actual Composite manufacting company (not a backshed Job) and make excellent stuff. i think their repo crash box costs €300. same guys i got my GT3 Body from.
#4303 CHILL Gone DUTCH
Posted 24 July 2018 - 11:04 AM
Ok found a place that sells s2 Elise heatedly windscreens so I can lose the heater box
Just need to find soneone to fit it
#4304 oakmere
oakmere
  • 2,143 posts
Posted 24 July 2018 - 12:03 PM
Can you buy the windscreen surround from lotus?
#4305 CHILL Gone DUTCH
Posted 24 July 2018 - 12:47 PM
I would of thought so
But there's nothing wrong with my sorround
#4306 CHILL Gone DUTCH
Posted 24 July 2018 - 01:37 PM
Unless it one use and needs relacing
#4307 CocoPops
CocoPops
  • 17,182 posts
Posted 24 July 2018 - 02:06 PM
The surrounds are bonded to the screens.
So unless you can try and remove it... it's one use.
#4308 CHILL Gone DUTCH
Posted 24 July 2018 - 02:34 PM
THought as much after having a closer look today
I like to salvage the sourround if possible, will try tomoz
If not a new one will do the same
Last pic of the vx before incident
92866141-9F17-45DA-95A5-813D2F8D8ECA_zps
#4309 sford
sford
  • 1,454 posts
Posted 24 July 2018 - 03:35 PM
I know at this stage the horse has bolted but to alleviate your lack of front splitter, would dive planes help? Possibly more secure to mount?
#4310 CHILL Gone DUTCH
Posted 24 July 2018 - 04:45 PM
It was the rear of the car which got away from me I need the last kink before the finish which normally wouldent be a issue
My issue was the finish line was closer than I expected and also closer to the solid white line than I thought it should be
I Was completely flat in 4th gear going in tin the link lost the rear slightly
Corrected and before I new it I had hit the A frame with the chequered board on it
Unfortunately I also took out 2k worth of timing equipment which was not found
#4311 CHILL Gone DUTCH
Posted 24 July 2018 - 04:48 PM
As you can see from this video the finish line is close you the last link
https://youtu.be/uWO6TGowYmw
I was also on full chat from bunga bunga
The tighter left before thevteisty bits
And I estimate the speed to be over 120 mph
Also looks like then put thevrenewed sign on the grass after I hit it
Edited by CHILL Gone DUTCH, 24 July 2018 - 04:49 PM.
#4312 The Batman
Posted 24 July 2018 - 05:08 PM
did they say anything about paying for the timing equipment?
i bet that made them happy!
#4313 CHILL Gone DUTCH
Posted 24 July 2018 - 05:49 PM
They just mentioned they haven't found the timing equipment
#4314 rob999
rob999
    Cat in a Hat
  • 12,795 posts
Posted 25 July 2018 - 08:19 AM
Get it on eBay, should be in the front clay somewhere!
Did the Lap time count?
#4315 Firthy
Firthy
  • 576 posts
Posted 25 July 2018 - 12:32 PM
Double posted
Edited by Firthy, 25 July 2018 - 12:38 PM.
#4316 Firthy
Firthy
  • 576 posts
I can see how that would be very easy to do, especially as its so narrow.
Not the greatest place to have them tbh, the noise must have been horrible!!
Edited by Firthy, 25 July 2018 - 12:35 PM.
#4317 CHILL Gone DUTCH
Posted 25 July 2018 - 12:46 PM
I know this screen sorround is a nightmare
Can you just buy the sorrounds on there own ??
#4318 CHILL Gone DUTCH
Posted 25 July 2018 - 04:44 PM
INvestigated the lack of clutch pedal and strangely it's in the gearbox so it's got to come out
C63C47FC-B8C0-445D-AE95-C9038108F491_zps
7B22AF6D-D003-421C-A925-DB34B9C1604D_zps
Big thanks to George for coming round and lending a hand
And more importantly keeping my spirits up
Edited by CHILL Gone DUTCH, 25 July 2018 - 04:46 PM.
#4319 WrightStuff
WrightStuff
    i am sheldon cooper
  • 2,238 posts
Posted 25 July 2018 - 07:38 PM
If you're getting an S2 heated screen which will have a black surround, surely the path of least resistance is just to wrap that back to silver ?
#4320 CHILL Gone DUTCH
Posted 25 July 2018 - 08:17 PM
Colour really dosent matter
What' I don't like is the heated screen dosent have a sorround vertually impossible to take the old one off in one piece
Edited by CHILL Gone DUTCH, 25 July 2018 - 08:18 PM.
    Bing (1)
