Project Chill 1
4396 replies to this topic
#4321 CHILL Gone DUTCH
Posted 27 July 2018 - 09:14 AM
Started to get the gear box out of the car this morning before family time
And found this on the subframe
The way it's cracked looks like the subframe has actually tornrather than just cracked
41E8E52C-D476-4550-88F8-C2E5C703457D_zps
Never rains but it poors
Decided to not rush now and try have it ready for Anglesey
On a other note I did a 400 mile round trip yesterday to Somerset for a second hand clam
FE1FEAE7-9DE9-451C-BF06-C89E4D731F3C_zps
#4322 hughcam
hughcam
  • 730 posts
  • Interests:driving, motorcycling, snowboarding, v12 lawn mowers
Posted 27 July 2018 - 10:31 AM
That subframe looks absolutely FUBAR :/
#4323 Arno
Arno
  • 1,238 posts
Posted 27 July 2018 - 10:35 AM
IMHO That's a fairly normal stress crack in steel that has simply progressed over time. (the tip 'creeps' futher)
Likely it has been there for some time but (much) smaller. But as it progresses the area around it becomes more 'loose' so flexes more under repeated loads and that speeds it up and... you get the idea :)
A bit like bending a tab on a coke can back and forth. It will slowly 'give' and then rapidly come apart.
Definitely needs fixing though.. But luckily the subframes are (as far as I know) pretty boggo steel, so crack can be arrested (drill hole at tip), damaged area ground down and then a good weld bead to tie it all back together. If you want to be fancy you can do a dye penetrant test around the cracked area to see if there are any small 'branches' from the main crack that need attention too.
#4324 Arno
Arno
  • 1,238 posts
Double post..
Edited by Arno, 27 July 2018 - 10:38 AM.
#4325 CHILL Gone DUTCH
Posted 27 July 2018 - 10:43 AM
Thanks arno I will take advice and re-weld and extra streghthening
#4326 CHILL Gone DUTCH
Posted 27 July 2018 - 10:44 AM
It deffenately was not there 18 months ago when I did suspension rebuild
But could be anytime after that
#4327 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 27 July 2018 - 10:46 AM
Do you have a brace bar?
#4328 siztenboots
Posted 27 July 2018 - 11:54 AM
must admit , I never jack under those rear subframe parts where the undertray bolts to , metal there is very soft , always on the middle of chassis and only for short periods.
#4329 siztenboots
Posted 27 July 2018 - 11:55 AM
if the subframe had been powdercoated , would this have been visible during inspection?
#4330 FLD
Posted 27 July 2018 - 12:17 PM
These cracks are appearing from a sharp (ish) edge on the sheet steel making up the frame. Could the fix for this issue be as simple as dressing the corners off the edge where it starts and polishing up to remove the start point? I know this doesn't help Chill.
#4331 CHILL Gone DUTCH
Posted 02 August 2018 - 09:07 AM
REtired from the sprint series and decided to fix her up hopfully for next year when I might give it a other go
56BBEDFE-F6F7-43AA-B635-DDCFCEBA4F95_zps
#4332 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,516 posts
    "Yes, I built it"
Posted 02 August 2018 - 09:40 AM
Whoop whoop Exige Won!
:tt:
Will be good to see you back in 2019  rallly
#4333 SteveA
SteveA
  • 9,158 posts
Posted 02 August 2018 - 09:43 AM
How many rounds are left Chris?
#4334 CHILL Gone DUTCH
Posted 02 August 2018 - 09:51 AM
There's 3 rounds left
#4335 CHILL Gone DUTCH
Posted 20 August 2018 - 03:51 PM
Finally got round to taking he gearbix out to investigate the no pressure and found the slave/thrust bearing has had a bearing failure
F2C7492D-C850-48A8-A351-F63F45516843_zps
FF6609D1-EA60-4F79-A7B6-A283A882B396_zps
FA4B8884-AAC7-4522-A56A-947E6BF47D70_zps
#4336 CHILL Gone DUTCH
Posted 20 August 2018 - 03:55 PM
Not the end of the old but the clutch does have some wear on it so That's being replaced to
This brings up a other question is it worth sticking a 4.17 gearbox in there while it's off
The car will no longer be used on the road so track only and I currently can't remember using fith gear in the last 2/3 years infact the only time I remember using 5th is at zandvoort
Does anyone have the data between standard and 4.17 g box at 7500 rpm limiter please
#4337 CHILL Gone DUTCH
Posted 20 August 2018 - 04:00 PM
On a other note hat to remove the inlet to get to one bolt of bell housing
It's very clean in there since water injection and pcv system
Will check the laminovas before it goes back in
B8CD37B9-5A91-4668-9195-6FD29C15E511_zps
62A077E9-5992-4C53-8E35-7FECEB95F071_zps
Edited by CHILL Gone DUTCH, 20 August 2018 - 04:00 PM.
#4338 Danny Scarbro
Danny Scarbro
  • 245 posts
  • Interests:Track days!
Posted 03 September 2018 - 03:06 PM
Hopefully this will help you Chris;
Stock 3.95
mph / RPM 1000 2000 3000 4000 5000 6000 7000 7500
1st Gear 5.3 10.5 15.8 21.1 26.3 31.6 36.9 39.5
2nd Gear 9.3 18.7 28 37.3 46.7 56 65.3 70
3rd Gear 14 27.9 41.9 55.9 69.8 83.8 97.8 104.7
4th Gear 19.4 38.9 58.3 77.7 97.2 116.6 136.1 145.8
5th Gear 23.3 46.6 69.8 93.1 116.4 139.7 162.9 174.6
4.17 FD
1st Gear 5 10 15 20 24.9 29.9 34.9 37.4
2nd Gear 8.8 17.7 26.5 35.4 44.2 53 61.9 66.3
3rd Gear 13.2 26.5 39.7 52.9 66.1 79.4 92.6 99.2
4th Gear 18.4 36.8 55.2 73.6 92.1 110.5 128.9 138.1
5th Gear 22 44.1 66.1 88.2 110.2 132.3 154.3 165.4
4.41 FD
1st Gear 4.7 9.4 14.2 18.9 23.6 28.3 33 35.4
2nd Gear 8.4 16.7 25.1 33.4 41.8 50.2 58.5 62.7
3rd Gear 12.5 25 37.5 50 62.5 75.1 87.6 93.8
4th Gear 17.4 34.8 52.2 69.6 87 104.5 121.9 130.6
5th Gear 20.8 41.7 62.5 83.4 104.2 125.1 145.9 156.4
That's based on a 255/40/17 tyre? Is that correct?
4.41 would be perfect really, doubt you would see anymore than 156mph on any circuits in the UK...might be wrong though your car is seriously fast!
Dan
#4339 CHILL Gone DUTCH
Posted 03 September 2018 - 04:36 PM
Thanks for the information Dan
Think it's time for a 4.17
Rather than a 4.41
#4340 MAXR
MAXR
  • 2,719 posts
Posted 03 September 2018 - 06:01 PM
Chris, what's the max speed you get upto along the main & back straight at Snet? Do you reach 150mph now? I have to get into 5th with a 4.17
7 user(s) are reading this topic
0 members, 7 guests, 0 anonymous users
