Project Chill 1
4396 replies to this topic
#4341 CHILL Gone DUTCH
Posted 03 September 2018 - 08:22 PM
Chris, what's the max speed you get upto along the main & back straight at Snet? Do you reach 150mph now? I have to get into 5th with a 4.17
I'm getting close to the limiter even in the wet in 4th down back straight in 4th and looking back at the video I could probably of pulled 5th gear and been on full throttle for a lot lot longer (3.95) box
Edited by CHILL Gone DUTCH, 03 September 2018 - 08:27 PM.
#4342 MAXR
MAXR
  • 2,719 posts
Posted 03 September 2018 - 09:39 PM
You video was in the wet, so that’s not a good comparison for your top speed. But I presume you’ll be nearing 148+ in the dry.
As your power comes in so rapidly, you may be swapping gears more than you’re used to. It may not be ideal in the wet or in damp conditions
#4343 CHILL Gone DUTCH
Posted 03 September 2018 - 10:00 PM
I've also got to get off the line but going by the data danny put up there's not a lot of difference in speeds
As for top speeds my car hits a invisabke wall at around 140 so maybe the slightly higher revs ( more power ) might help me to push through easier
#4344 MAXR
MAXR
  • 2,719 posts
Posted 04 September 2018 - 07:20 PM
It must be higher than 140 as I hit that in my car (mind you, that's only a speedo reading). A 4.17 is great, I wouldn't go back to a standard box in a hurry.
#4345 CHILL Gone DUTCH
Posted 04 September 2018 - 07:35 PM
Its looking like i might have to change the final drive in my gearbox, been looking today for a z22se 4.17 today with no joy
can get the final drive out of quite a few other gearboxes
#4346 CHILL Gone DUTCH
Posted 04 September 2018 - 08:09 PM
While searching around today its also possible to go even shorter using a f23 WR ratio with a 4.17 FD (using some parts from f23 diesel gearboxs )
but think this will be a step to far for me
#4347 Danny Scarbro
Danny Scarbro
  • 245 posts
  • Interests:Track days!
Posted 04 September 2018 - 09:26 PM
4.41 Chris.
You won’t regret it!
Vx220 are geared far too tall for track days/racing.
Even with a 4.41 it’s still tall gearing, you’ll never hit the limiter on track, and you’ve only got 5 gears so you won’t be changing gear all the time, just be in a higher gear in different parts of the track.
#4348 1cobrav8
1cobrav8
    Joe is faster than me
  • 516 posts
Posted 04 September 2018 - 09:47 PM
4.41 Chris.
If my 4.17 goes wrong I’ll be changing for a 4.41
#4349 Tony H
Tony H
    Lotus on Crack
  • 1,729 posts
Posted 04 September 2018 - 10:11 PM
If you can find one
#4350 MAXR
MAXR
  • 2,719 posts
Posted 05 September 2018 - 03:21 AM
To be fair, my car's 2nd is virtually obsolete & hardly ever used. Even with my meagre torque, compared to yours, it has plenty of pulling power low down in 3rd. So, only 3 gears are used on track.
If you take a look at my video below at Snet, you'll see that 2nd gear is not used at all.
#4351 The Batman
Posted 05 September 2018 - 03:28 AM
im looking forward to our battles next year max thumbsup
p.s. chill ive sent you a link to a 4.17
#4352 MAXR
MAXR
  • 2,719 posts
Posted 05 September 2018 - 04:28 AM
...Bring it on Mr flymo!
#4353 The Batman
Posted 05 September 2018 - 04:33 AM
ok old man ;)
#4354 Firthy
Firthy
  • 576 posts
Posted 06 September 2018 - 10:05 AM
Chris I would almost certainly consider a diff as well :) (if you're not already)
4.17 gives a lot more punch and I know you already have issues with one tire fire on corner exit.
That said you are usually up a gear so it may actually help smooth the delivery.
Edited by Firthy, 06 September 2018 - 10:11 AM.
#4355 Firthy
Firthy
  • 576 posts
Posted 06 September 2018 - 10:07 AM
Yeah me too Max I wouldn't want any shorter personally I very rarely use 2nd. I only rev mine to 6k though so very different to your higher reving built engines
Edited by Firthy, 06 September 2018 - 10:15 AM.
#4356 CHILL Gone DUTCH
Posted 07 September 2018 - 05:04 PM
I suppose if it it end so up to short for the Harrop I could always just stick the M62 back on
#4357 MAXR
MAXR
  • 2,719 posts
Posted 07 September 2018 - 06:22 PM
The Harrop has vast amounts of torque and grunt compared to my car and it also comes in very quickly. Your tyres my squeal in pain if you're heavy footed and you may find that it's not a match made in heaven.
#4358 CHILL Gone DUTCH
Posted 07 September 2018 - 09:06 PM
Lucky enough I'm quite delicate on the throttle 🤥
I also don't run the silly boost pressures everyone else insists on running
I use a big pulley and have less the 1 bar of boost
The bigger tires I use have not made any difference I still drive to the grip but regularly over do it in corner exit and not having a lsd I normally spin up the inside wheel (
#4359 MAXR
MAXR
  • 2,719 posts
Posted 08 September 2018 - 05:44 AM
Chris,
my car is going to Joe's soon and Neil is doing some engine work whilst there. As you know, my car has a 4.17 box and an Lsd fitted. If you can sort out with them to remove the box, you're welcome to try it out on your car? It may cost you a couple of hundred pounds to pay them to remove & re-fit it and a day's effort, but at least you'll know if the 4.17 & LSD sorts out your problems?
Max
#4360 CHILL Gone DUTCH
Posted 08 September 2018 - 07:40 PM
Thats a kind offer Max
but sounds a lot of messing about switching and switching gearboxes twice in two cars
so im going to say thanks for the offer but i am not prepared to strip mine down twice just to try a gearbox
(time is very short atm
but it was a kind offer thanks
