Project Chill 1
#441
Posted 19 June 2013 - 02:13 PM
#442
Posted 19 June 2013 - 02:29 PM
#443
Posted 19 June 2013 - 02:35 PM
Yes I think in going have to take it somewhere to be set up, Only problem with having new shocks I recorded all the setting of the set I wanted refurbingI believe they keep the main spring fully extended when on full droop, Its well worth getting the Geo sorted, go to some who knows what they are doing, Plenty of recommendations on here .
#444
Posted 19 June 2013 - 02:39 PM
http://wiki.seloc.org/a/Geo_SetupsYes I think in going have to take it somewhere to be set up,I believe they keep the main spring fully extended when on full droop, Its well worth getting the Geo sorted, go to some who knows what they are doing, Plenty of recommendations on here .
#445
Posted 19 June 2013 - 02:45 PM
#446
Posted 19 June 2013 - 02:48 PM
Cheers Martin will give them a call, I think ride heights etc want looking at, I was very low on my old shock and regularly grounded out on road and track ( shocks were very worn) So maybe a full setup is required,Blink charge £125 for geo though it might be less if not much needs changing. As you have had a previous geo you might only need the toe checking.
#447
Posted 19 June 2013 - 02:53 PM
#448
Posted 21 June 2013 - 04:36 PM
Difference between old gazs and the new ones
I've done ball joint today to I managed to snap bolts on my new removal tool,
Got it done with some threaded bar,
#449
Posted 21 June 2013 - 06:34 PM
snapped the bolts? I've heard it before but seriously don't see how. I've bent both plates and not by a small amount without breaking the bolts....usual case of user error rather than a fault with the tool.
#450
Posted 21 June 2013 - 06:37 PM
#451
Posted 27 June 2013 - 12:52 PM
Edited by Chill, 27 June 2013 - 01:21 PM.
#452
Posted 27 June 2013 - 02:57 PM
I hope your right I won't have too much time from getting my CAT back till the National and I have to map it...
How far is Cheshire from bedford?
#453
Posted 27 June 2013 - 03:03 PM
#454
Posted 27 June 2013 - 03:06 PM
3 hoursI hope your right I won't have too much time from getting my CAT back till the National and I have to map it... How far is Cheshire from bedford?
#455
Posted 27 June 2013 - 03:07 PM
#456
Posted 27 June 2013 - 03:11 PM
I have some serious reading to do, I want to be very careful as this thing will have a new cat
#457
Posted 27 June 2013 - 03:14 PM
#458
Posted 27 June 2013 - 03:24 PM
sounds good hope it's sorted by then though
#459
Posted 27 June 2013 - 03:25 PM
#460
Posted 27 June 2013 - 04:37 PM
