Project Chill 1
#461
Posted 27 June 2013 - 05:01 PM
#462
Posted 27 June 2013 - 05:07 PM
#463
Posted 27 June 2013 - 05:09 PM
I must of missed that bit will check, it seems to be workingThought for some reason you couldn't use the knock detection on SC'd cars. Sure I read that in Peter's manual at some point in the past.
#464
Posted 27 June 2013 - 05:15 PM
#465
Posted 27 June 2013 - 05:25 PM
Think your getting slightly confused with this
ive got this bit disabled, but it still works on the power measurment
#468
Posted 29 June 2013 - 06:47 AM
as soon as the weather improves im going to make a ignition settings taking the best bit out of the three above ignition setting ( base, 1.77%, 1.77+1.06%) then repeat the power measurement then check knock and then add1.06% and also reduce by 1.06% from new start point to see if there any other gains to be made.
then i will be doing a other fuel learn session and repeating the process again
#469
Posted 29 June 2013 - 06:59 AM
#470
Posted 29 June 2013 - 08:00 AM
#471
Posted 29 June 2013 - 08:03 AM
#472
Posted 29 June 2013 - 09:34 AM
Personally I'd leave it turned on, all the CS mapped cars will have it and haven't heard anyone with <300bhp with any problems. Only Harrop cars seem to have the issue.Think your getting slightly confused with this Misfire check The ECU knows how the crankshaft should react on a successful ignition. This is a good way to detect if there are misfires. However if the power output of the engine exceeds 250hp, this algorithm fails, and it can switch the ECU into leap home mode even when there is nothing wrong with the ignition. It is therefore advised to disable misfire detection if an engine produces more than 250hp ive got this bit disabled, but it still works on the power measurment
#474
Posted 29 June 2013 - 05:15 PM
Here is what i have been doing this afternoon
the red line is the current power curve
the green line is the current torque curve
the black lines close to each curve is the original curves after fuel learn session.
i havent been able to get much more out and out power but have managed to get the curves more stable and steeper
i should also say these results are only reference points as i havent been able to weigh the car probably and also i had tools and spares in the boot because the road i was using is quite far from home.
but for the people that want to no i have under estimated weight of car so the chances are its producing more than what the graphs suggest
Edited by Chill, 29 June 2013 - 05:17 PM.
#475
Posted 29 June 2013 - 05:21 PM
im getting to really love this dutch software
#476
Posted 29 June 2013 - 06:43 PM
I'd say those were very useful gains and as much, if not more than you could hope for, given the engine is mechanically identical pre and post tinkering. It's a supercharger, so boost is always the same unlike a turdo where you might gain 50bhp and 60ft/lb's of torque by electronically altering the max boost.i havent been able to get much more out and out power but have managed to get the curves more stable and steeper
Over estimated the weight, I hope? Wish Peter would set up switchable units in the software. All this metric stuff doesn't make sense in a world of bhp and ft/lb's.i have under estimated weight of car so the chances are its producing more than what the graphs suggest
#477
Posted 29 June 2013 - 06:48 PM
I weigh 100 kg and the boot was full of tools and spares and a full tank of fuel I reckon the car was weighing more than 1000 kgI'd say those were very useful gains and as much, if not more than you could hope for, given the engine is mechanically identical pre and post tinkering. It's a supercharger, so boost is always the same unlike a turdo where you might gain 50bhp and 60ft/lb's of torque by electronically altering the max boost.i havent been able to get much more out and out power but have managed to get the curves more stable and steeper
#478
Posted 29 June 2013 - 06:51 PM
#479
Posted 29 June 2013 - 06:53 PM
I think the more you mess with it the more you get out of it, I think it's a bit of chicken and egg syndrome You have to fuel learn first then play with ignition, But when you have altered ignition you have to do the fuel table again but then you want more from ignitionYou're a great advert for the software
Glad it's working so far. How much more tinkering do you think there is?
#480
Posted 30 June 2013 - 07:59 AM
