Project Chill 1
4396 replies to this topic
#481 CHILL Gone DUTCH
Posted 30 June 2013 - 08:01 AM
Excellent work there chill the graph looks really good now. Might have to do a fuel learn on mine as I have only done it once!
Cheers Martin Are you going to peaks meet on 7 th
#482 CHILL Gone DUTCH
Posted 30 June 2013 - 08:03 AM
I'm convinced there would be more to gain if I changed my exhaust manifold, As I'm still on OEM
#483 Kieran McC
Kieran McC
  • 3,416 posts
Posted 30 June 2013 - 09:11 AM
I put a Tullett 2.5" with their full system Big gain .I did have to put the uprated fuel pump on, as it ran quite lean at the top end.
#484 CHILL Gone DUTCH
Posted 30 June 2013 - 09:14 AM
I've uprated fuel pump to 255 Walbro And I have Tullett 2.5" back box just need manifold but on the other hand I don't want to go over 260bhp because of engine internals are standard and will be staying that way
#485 Kieran McC
Kieran McC
  • 3,416 posts
Posted 30 June 2013 - 09:17 AM
My 2.2 NA engine is standard just make it a lot freer with the Tullett manifold
#486 oakmere
oakmere
  • 2,143 posts
Posted 30 June 2013 - 10:02 AM
Unfortunately not we have guests next weekend.
#487 CHILL Gone DUTCH
Posted 30 June 2013 - 10:06 AM
Ok we will have to get you out and about soon,
#488 Nev
Posted 30 June 2013 - 11:58 AM
Wow, 320 ft/lb of torque - am I reading that graph right? That's a lot more than I would have guessed, how much torque does an OEM mapped ECU make for a stage 2 for comparison please? Seems like the power figure is low though, even accounting for power drain due to winding up the supercharger. Surely at 7000 RPM you'd expect something in the region of 7000/5252 * torque ?
Edited by Nev, 30 June 2013 - 12:02 PM.
#489 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 30 June 2013 - 12:00 PM
Wow, 320 ft/lb of torque - am I reading that graph right? A lot more than I would have guessed, how much torque does an OEM mapped ECU make for a stage 2 for comparison please?
Come on Nev, look again. It's a supercharged car for Christ sake. ;)
#490 Nev
Posted 30 June 2013 - 12:02 PM
I don't understand, what have I missed (hence the question) ?
#491 techieboy
Posted 30 June 2013 - 12:06 PM
Torque unit is Nm
#492 Nev
Ah, yes, I just read back several pages and realised my mistake.
#493 CHILL Gone DUTCH
Posted 30 June 2013 - 12:09 PM
It's running about 250 ft Ib Which is about 20-30 more
#494 CHILL Gone DUTCH
Posted 30 June 2013 - 12:12 PM
But I'm running a 3.1 pulley instead of 3.35
#495 CHILL Gone DUTCH
Posted 01 July 2013 - 12:07 PM
Ok ive had a interesting morning
after i had been playing with all the ignition settings over the last week or so i have seen some good improvements (see above graphs) however i have noticed the exhaust has started to get sooty.
so i wanted to prove my theory that the fueling is now running rich after the ignition changes, so i did a other fuel learn session thinking that the fuel must not be right after the ignition changes,
whilst doing the fuel changes the exhausts have now gone back to the way they were,(NO SOOT)
and here are the results..
red line is average after a run in each direction
#496 CHILL Gone DUTCH
Posted 01 July 2013 - 12:10 PM
And here are the differences from when i started last week to how they are now
#497 CHILL Gone DUTCH
Posted 01 July 2013 - 12:12 PM
The problem i have now im convinced i will get more from playing with the ignition again
SO TO ANSWER THE QUESTION WHAT CAME FIRST CHICKEN OR EGG?
You cant have one without the other.
so the more you work on the maps the more you will get.
but you cant have 1 without the other
:ninja:
Edited by CHILL Gone DUTCH, 01 July 2013 - 12:31 PM.
#498 CHILL Gone DUTCH
Posted 01 July 2013 - 12:14 PM
PS
I really need to get a new job before i kill my car
#499 fezzasus
Posted 01 July 2013 - 12:16 PM
Diminishing returns. Yes, more adjustment to timing followed by fueling refinements may help, but since you're limited in power by the con rods what will you do with the gain?
#500 CHILL Gone DUTCH
Posted 01 July 2013 - 12:18 PM
It depends on where the gains are im no confident i can put the power where i want if there is anymore
