Project Chill 1
#501
Posted 01 July 2013 - 12:39 PM
#502
Posted 01 July 2013 - 12:43 PM
This might be my next lesson, Fancy a visit one nightWhen doing the fuel learn the car is locked in 14.7:1 air fuel ratio so is running lean when you stick your foot down. This will give a very clean exhaust. When you go back to the normal running map your AFR map will control open loop fuelling. Have you tried changing your AFR? Remember the lower number is richer. My WOT AFR was set at 12.4 by Peter so I changed this by .2 each way but got no improvement. You would change the 90 - 200 map readings same as ignition.
#503
Posted 01 July 2013 - 03:09 PM
Your 12.4 sounds like the AFR number for an NA @ WOT? Supercharged engine need a bit richer mixture to keep things together, so aim for ~11.8 AFR.
#505
Posted 01 July 2013 - 05:32 PM
Nice 11.8's.
Do you have a wideband fitted to monitor the WOT mixture?
#506
Posted 01 July 2013 - 05:47 PM
#507
Posted 01 July 2013 - 06:22 PM
Nice 11.8's.
I was going to ask that exact question I will have when I do mine so see if it makes any difference
#508
Posted 01 July 2013 - 06:34 PM
Makes a difference to what ???I was going to ask that exact question I will have when I do mine so see if it makes any differenceNice 11.8's.
Edited by CHILL Gone DUTCH, 01 July 2013 - 06:34 PM.
#509
Posted 01 July 2013 - 06:38 PM
I don't know myself, I wonder if it will make a difference or not?
#510
Posted 01 July 2013 - 06:40 PM
#511
Posted 01 July 2013 - 06:41 PM
yes I have a wideband i brought some time ago so will wire it up
reading a basic explanation it depends on how good the ecu is
Narrow Band
A narrow band, or zirconia, oxygen sensor is a sensor that uses two electrodes and an oxygen-reactive fuel cell to create an electric current. The strength of the current is proportional to the amount of oxygen in the cylinder. The Engine Control Unit (ECU) can analyze the electrical data that the sensor gives it and adjust the amount of fuel used to run the car efficiently. If the ECU is old or poorly designed, it will show in the vehicle's gas mileage when compared with other cars
A wide band oxygen sensor is very similar to a narrow band sensor, the only difference being that it also has an electrochemical gas pump attached. The wide band sensor can process its own data and takes the place of the ECU in determining the most efficient amount of fuel to use. This cuts out the middleman of the operation and gives the car better mileage. However, wide band oxygen sensors are usually only available on higher-end or performance cars
, since they are more expensive and help the car to age more gracefully.
Edited by NickB777, 01 July 2013 - 06:44 PM.
#512
Posted 01 July 2013 - 06:43 PM
Where are you up to ie are you driving it, is it runningyes I have a wideband i brought some time ago so will wire it up
#513
Posted 01 July 2013 - 06:46 PM
you kidding
it's in a zillion bits and the national is 3 weeks away
#514
Posted 01 July 2013 - 06:48 PM
It's still late nights
you kidding it's in a zillion bits and the national is 3 weeks away
#515
Posted 01 July 2013 - 07:07 PM
#516
Posted 01 July 2013 - 07:17 PM
Might leave this until the winter incase the worst happens, don't want to do much more with the map until I have been to rolling road to check how accurate the software is (BHP and Torque) as I'm getting close to the limits of my internals The only thing I am going to change is the AFR correction at 98 degrees C make it richer at 98 I don't like car running high tempsI can pop around tomorrow chill if you want? You can check if the AFR changes make a difference with a power run same as ignition. Small changes only you don't want to melt a piston! The wide band gives the actual AFR and the software can now tune the map to make sure the requested AFR is correct by using the wide band output. Without the wide band the software calculates the AFR based on the fuel learn narrow band results.
#517
Posted 01 July 2013 - 07:31 PM
#518
Posted 01 July 2013 - 07:33 PM
#519
Posted 01 July 2013 - 08:36 PM
#520
Posted 01 July 2013 - 09:08 PM
