Cleared error code before I did learn session, It didn't come back so I think it had something to do with me having to start up the car with no exhaust or sensors in. I had to do this to put car on bricks so I could get jack under Thanks for adviceNo, you need the second sensor. I have faced this. I didnt have the second one on the previous CMS map as it is disabled but witht he obdtuner software it needs the second one. So I am off to get a bung fitted into my car soon. You couldput a cheater in, but you would be better off with an actual sensor and letting the software do its job. If your map expects a CAT and now you dont, it will bring up an error code to you.
Yes is still connected up, theres two options i think 1. Lambda got broke by cat breakage, 2. i broke it when i took it out to get the CAT out. can i just leave this diconnected, as i have the catalyst check disabled
i have got a error code P0141 second lamda i think, is this because there is no CAT
You have still got your post cat sensor installed and connected up, haven't you? That's a fault code related to the heater circuit in the lambda which would point to the lambda not being powered up. Good that it's not pinging up an EML though.But no EML
Didn't work on the VX or a different one on a previous Audi.You will want an O2 sensor spacer to take it out the flow of the exhaust.
Project Chill 1
#561
Posted 11 July 2013 - 12:01 PM
#563
Posted 11 July 2013 - 12:36 PM
Did you ask Peter why it is required?No, you need the second sensor. I have faced this. I didnt have the second one on the previous CMS map as it is disabled but witht he obdtuner software it needs the second one. So I am off to get a bung fitted into my car soon. You couldput a cheater in, but you would be better off with an actual sensor and letting the software do its job. If your map expects a CAT and now you dont, it will bring up an error code to you.
#566
Posted 11 July 2013 - 01:44 PM
look like quite a difference in the maps
I didnt as a "why" to peter, he just said it was needed, the way he phrased it was as a safety parameter for checking the first is ok.
Seeing as my exhaust is coming off for the wideband (and to get a singlepipe) I may as well fit the second lambda.
#567
Posted 11 July 2013 - 01:47 PM
OH
and ive managed to get rid of the knock nearly completely which suggests there is some improvement to be had,
i also want to get that dip out of the curve
Edited by CHILL Gone DUTCH, 11 July 2013 - 01:48 PM.
#568
Posted 11 July 2013 - 02:43 PM
#569
Posted 11 July 2013 - 02:45 PM
Might have to put new rods in soon , What else would be worth changing why I'm thereThem rods will be starting to cry!
#570
Posted 11 July 2013 - 02:50 PM
at the time of rods I ended up doing cams, pistons a new head, new clutch, new oil pump, new water pump, engine mouns etc etc etc.
I would much rather have the engine out once and know all is ok in there.
-might be worth putting a saab sump on it as well at the same time?
-lightened fly if you havent got one
-cam chain renew
#571
Posted 11 July 2013 - 06:18 PM
-cam chain renew
i will mention it to the wife
not a chance until i get a new job
#572
Posted 11 July 2013 - 06:22 PM
Lol i new this was heading this way when you first mentioned SC. Love your new user name you weirdo .
#573
Posted 11 July 2013 - 06:24 PM
all in the spirit of VX ownership
#574
Posted 11 July 2013 - 06:47 PM
#576
Posted 11 July 2013 - 07:07 PM
Who did that Call X files Mulder and scully where are you
Im Here mate :-)
#577
Posted 11 July 2013 - 07:20 PM
270 on standard rods won't last long
#578
Posted 11 July 2013 - 07:51 PM
i would like you to tell me a where a safer place would be,
and more importantly where do i get some rods from (which type)
what is the next weakest part after rods
Edited by CHILL Gone DUTCH, 11 July 2013 - 07:52 PM.
#579
Posted 11 July 2013 - 07:57 PM
Rods is 270 isch
Pistons is 300 isch
Liners are 400 isch.
Put maxrev on 6500 and stop trying to destroy your car.
Edited by smiley, 11 July 2013 - 07:58 PM.
#580
Posted 11 July 2013 - 08:02 PM
