Project Chill 1
#581
Posted 11 July 2013 - 08:14 PM
#582
Posted 11 July 2013 - 08:16 PM
How many cars have failed at 270 ish? Obviously Joe's did but has anyone else pushed it to see?
one was enough, seriously expensive lesson,
get the eagle rods, believe you can change them in situ, Vocky will now you can leave the pistons till 310+
#583
Posted 11 July 2013 - 08:26 PM
The whole "rods will fail at 270bhp" seems a bit odd to me..
Parasitic loss on the SC itself not taken into account, so these 270 cars are actually running 300 isch.
#584
Posted 11 July 2013 - 09:11 PM
looks like my engine is going to have a few new parts,
The only thing is ive never done anything inside a engine apart from change a head gasket when i was 17,
on saying that i never had any inclination to get involved inside a engine.
i have been on a steep learning curve since i have owned the VX and now im going to get involved in the internals of my engine.
Can you not get eagle rods in this country.
and does anyone have a guide for a idiot on how to change the rods. i might be tempted to get some pistons at the same time.
if anyone has any tips or places to get parts please let me know.
i will be doing the work over the winter so i better turn the engine down a bit.
#585
Posted 11 July 2013 - 09:16 PM
Ive never stripped or changed internals either but i wouldnt mind giving it a go. Everyone has to start somewhere so if you want we could do it together with a couple of guides. Tempted stick some rods in mine sometime to be on the safe side.
@Nick
I get that but when the 2.2 engines are relatively cheap and your risking a well used engine with its best days behind it and you can fit another engine yourself so no labour costs then i wouldn't say its too expensive. 260 is seen as the safe point as no one has had a failure but whats to say that Joe's wasn't slightly weaker and other engines could be happy at 270? Chris will be pushing 300bhp by the end of the year no doubt so it makes sense for him to get them done.
#586
Posted 11 July 2013 - 09:18 PM
You have quite a steep drop at max rpm. Sure your fuelpump is coping with all this?
(did you do a wideband logging?)
#587
Posted 11 July 2013 - 09:25 PM
Im sure i can iron that out with ignition changes but with all the talk of my engine needing new bits above im reluctant to play anymore and if anything i might have to detune a little,
injectors are only at 81% duty cycle
no wide band logging it will be soon though.
#588
Posted 11 July 2013 - 09:30 PM
@Nick
i was aiming for 320+
#589
Posted 11 July 2013 - 09:43 PM
Edited by oakmere, 11 July 2013 - 09:45 PM.
#590
Posted 11 July 2013 - 09:45 PM
all help will be welcomed
#591
Posted 11 July 2013 - 09:47 PM
#592
Posted 11 July 2013 - 09:49 PM
I would leave it at 260, and replace engine with crate engine if it goes pop.
#593
Posted 11 July 2013 - 10:03 PM
#594
Posted 11 July 2013 - 10:10 PM
I wish somebody had convinced me of that before I did it (twice). Stick with OEM parts (though upgraded rods will be fine) for as long as you can.Avoiding lumpy idle, piston slap and a shed load of cash for the sake of 25 bhp.
#595
Posted 11 July 2013 - 10:18 PM
I may have a set still sitting around, can have a look if you're interestd
Check out MandarinVX project thread, pretty sure he changed just the rods and has lots of pics
#596
Posted 12 July 2013 - 06:40 AM
http://www.vx220.org...project/page-25
If you wouldent mind having a look PM me the price
Cheers
Edited by CHILL Gone DUTCH, 12 July 2013 - 06:41 AM.
#597
Posted 12 July 2013 - 07:46 AM
you do realise 80% duty cycle is deemed maxed out for injectors
#598
Posted 12 July 2013 - 07:47 AM
Rods can be easily replaced with the engine in-situ, just whip the head and sump off.
#599
Posted 12 July 2013 - 07:51 AM
I think I would like the rods for peace of mind but keep the standard pistons. Then get the exhaust manifold port the head and be happy with 270-280 ish bhp. Avoiding lumpy idle, piston slap and a shed load of cash for the sake of 25 bhp.
Add some uprated valvesprings and maybe cams to that for high rev fun. A light flywheel and consider balancer delete if you can bear with some extra vibrations.
#600
Posted 12 July 2013 - 07:57 AM
Oh Peter indicated 90% duty cycle, Using his software, maybe he has a built in tolerance toyou do realise 80% duty cycle is deemed maxed out for injectorsinjectors are only at 81% duty cycle
