Good stuffRods can be easily replaced with the engine in-situ, just whip the head and sump off.
Project Chill 1
#601
Posted 12 July 2013 - 07:58 AM
#602
Or......... Get a decent used Z20NET / B207, bin the balancers, light weight fly, port the head, fit your NA cams, and a couple of other relatively minor tweaks (e.g. external trigger wheel) and you'll have an engine happy till ~300+
AND... you get to do the ECU calibration all over again (you love it)
#603
Posted 12 July 2013 - 08:00 AM
Most injectors will max out at 80% duty cycle and this is the accepted industry standard.
from a quick google search
#604
Posted 12 July 2013 - 08:01 AM
Need to slow up a little here going to engine safe first then take it from thereI think I would like the rods for peace of mind but keep the standard pistons. Then get the exhaust manifold port the head and be happy with 270-280 ish bhp. Avoiding lumpy idle, piston slap and a shed load of cash for the sake of 25 bhp.
Add some uprated valvesprings and maybe cams to that for high rev fun. A light flywheel and consider balancer delete if you can bear with some extra vibrations.
#605
Posted 12 July 2013 - 08:03 AM
Are you saying the internals on this engine are strongerOr......... Get a decent used Z20NET / B207, bin the balancers, light weight fly, port the head, fit your NA cams, and a couple of other relatively minor tweaks (e.g. external trigger wheel) and you'll have an engine happy till ~300+ AND... you get to do the ECU calibration all over again (you love it)
#606
Posted 12 July 2013 - 08:05 AM
Marginally. It's partially why I'm throwing away my uprated Z22SE and installing one of these as I can't stand the Z22SE with the uprated bits in it.Are you saying the internals on this engine are stronger
#607
Posted 12 July 2013 - 08:07 AM
Do you want to throw it away in my directionMarginally. It's partially why I'm throwing away my uprated Z22SE and installing one of these as I can't stand the Z22SE with the uprated bits in it.Are you saying the internals on this engine are stronger
#608
Posted 12 July 2013 - 08:11 AM
#609
Posted 12 July 2013 - 08:16 AM
I wish I knew what a trigger wheel wasOr......... Get a decent used Z20NET / B207, bin the balancers, light weight fly, port the head, fit your NA cams, and a couple of other relatively minor tweaks (e.g. external trigger wheel) and you'll have an engine happy till ~300+ AND... you get to do the ECU calibration all over again (you love it)
#610
Posted 12 July 2013 - 08:21 AM
Depends what we mean by marginal, and what the end goal is. However, if for example, we assume the notional Z22SE power limit is ~270bhp, the B207 / Z20 equivalent would be somewhere in the region of 350-400bhp.. My thinking is that a standard bottom end on one of these is up to the task (with supporting cooling mods and ECU calibration) of anything the M62 can throw at it. Not so much when the TVS is included (but quite a few in the US do).
Interesting that the high power outputs achieved in the US also correspond with that fact that they have much better ECU calibration options (HP Tuner, Trifeca) than what we have had (until recently) with the Z22SE..
#611
Posted 12 July 2013 - 08:26 AM
#612
Posted 12 July 2013 - 08:29 AM
What's the difference
#614
Posted 12 July 2013 - 08:34 AM
Is this not what we want, Which one has external trigger wheel the R oneExternal Trigger wheel
#615
Posted 12 July 2013 - 08:37 AM
Yet Maptun (and Neo Brothers) and separately Abbot Racing have all said they reckon the pistons are the limiting factor on a B207R and wont go past 320bhp before upgrading them. Rods are good to 400bhp. Crank is good for anything. Now whether turbo ponies are more nasty to pistons than supercharger ponies, or vice versa, I don't know. Nor whether these are exactly the same components that the LSJ uses as opposed to directly compatible.the B207 / Z20 equivalent would be somewhere in the region of 350-400bhp..
#616
Posted 12 July 2013 - 08:39 AM
Nothing in the picture, they're the same. But I think it's basically only cams between them (and a different turbo in an OEM install).What's the difference
#617
#618
Posted 12 July 2013 - 08:40 AM
basically just the camshafts are different
#619
None of them. You'll need to fit an external trigger wheel to run it with the Z22SE ECU as the internal trigger wheel pattern is different between the Z22SE and the B207/Z20NET/LSJ.Which one has external trigger wheel the R one
#620
8 user(s) are reading this topic
0 members, 8 guests, 0 anonymous users
