If I had your old engine it might be some more motivationIt's got a use. It's become an integral part of the garage now and has become my official battery charging station for all of my cordless tools. There's three different battery chargers on top of it, for the three different brands of charger and batteries I have (really need to bin them all and settle on a DeWalt or similar range).Give it some good use. Sell it to chill
More seriously though, except for the coil packs which I need to pick up from Joe, I now have every component needed for a full on LSJ + HPTuners conversion with some additional upgraded goodies in the head. Just the motivation that is sadly lacking since I grew to hate the car. That's the stupid thing, I got this engine to solve most of my hatred of it but, the memory of my hatred for the upgraded Z22SE has meant I've had no motivation to get on with the swap. It's a paradox.
Project Chill 1
#641
Posted 12 July 2013 - 09:49 AM
#642
Posted 12 July 2013 - 10:04 AM
More seriously though, except for the coil packs which I need to pick up from Joe, I now have every component needed for a full on LSJ + HPTuners conversion with some additional upgraded goodies in the head. Just the motivation that is sadly lacking since I grew to hate the car. That's the stupid thing, I got this engine to solve most of my hatred of it but, the memory of my hatred for the upgraded Z22SE has meant I've had no motivation to get on with the swap. It's a paradox.Give it some good use. Sell it to chill
Additionally, I'm sure if you were able to get a shot in a car thats had such a conversion (Exmantaa's for example), you might gain the motivation. However, given that you'll be the first one in your neck of the woods, thats unlikely to happen!
I have most of the bits now too (including coil packs, but not the bits I sold you oh and an engine - ironically the easiet bit to source) but the wiring and mapping stuff scares me much...
#643
Posted 12 July 2013 - 10:12 AM
Yep, me too. I look at the OBDTuner setup and think "damn, that's so easy to do" and then look at the HPT stuff and think "hmmmmmm, easier than a regular Z22SE ecu but....". Luckily, I've got Monkfish Performance quite local who know HPTuners from all of their supercharged Monaro/VXR8/Corvette stuff, so think it may get pushed across to them to refine any mapping. Only other HPT guy I've spoken to was up in Scarborough or somewhere like that.mapping stuff scares me much...
#644
Posted 12 July 2013 - 10:28 AM
chill, your decision upgrade z22se or get a b207 opinions are split
price could be quite similar too
#645
Posted 12 July 2013 - 10:29 AM
Could link it in with a holiday, do Bridlington as well
#646
Posted 12 July 2013 - 10:40 AM
Monkfish Performancemapping stuff scares me much...
"Get you knickers on a make me a map.."
Sorry..
#647
Posted 23 July 2013 - 02:37 PM
#648
Posted 25 July 2013 - 03:54 PM
#649
Posted 26 July 2013 - 09:23 AM
#650
Posted 26 July 2013 - 09:26 AM
#651
Posted 26 July 2013 - 09:45 AM
#652
Posted 26 July 2013 - 10:17 AM
Quite surprised how soft these are expected something a lot stiffer
#653
Posted 26 July 2013 - 10:40 AM
OBD-Tuner for Z22SE and HPTuners for the LSJ ecu work quite similar. Only with the LSJ you have to do some tasks on your own, instead of the OBD software doing it for you, but that also gives you somewhat more flexibliity. LSJ has (lots of) extra tables to tinker with, if you know what you're doing.
HPTuners works with a seperate ECU Editor and a powerfull Scanner. If the scanner is set-up right for your engine, it's a matter of f.i. logging your wideband % error, copy this logged AFR %error table and multiply the %error onto the ecu fuelling table.
But as is also discovered with OBD, the ability to tinker with it makes you wanting for more.
@ Chill; Buy a good 2.0 engine; do some exh. porting on the head, fit decent cams (not the saab L/E turbo's. The R version is ok) with uprated springs. Get a lighter C20XE/LET pot-type flywheel and you have a nice revvy engine that very easily gets to 7600+ rpms and should hold around 350HP on stock internals.
#654
Posted 26 July 2013 - 10:53 AM
#655
#656
Posted 26 July 2013 - 10:56 AM
#657
Posted 26 July 2013 - 11:00 AM
I was offered yellow ones do i've fitted it but might be tempted by black ones after some reviewsThe inserts make a difference, regardless of how soft
You'll feel more vibration in the cabin now. Decided on yellow rather than "Black" performance ones?
Edited by CHILL Gone DUTCH, 26 July 2013 - 11:02 AM.
#658
Posted 26 July 2013 - 11:02 AM
How you getting on with that new engine Would still be interested in your old stuff if its availableIt does? Nobody told me that.
#659
Posted 26 July 2013 - 11:09 AM
YepIt does? Nobody told me that.
#660
Posted 27 July 2013 - 10:17 PM
Don't need to be stiffer if you look at the function of them, which is to fill the air gaps n the inserts and therefore add greater resistance to movement of the mounts. What they could really do with is large washers on each side to pack the mounts in properly.New poly insert installed this morning
In the long run I would like to replace my mounts with the vibra technics offerings, but they do cost much more than standard.
