Project Chill 1
#661
Posted 28 July 2013 - 07:07 AM
#662
Posted 28 July 2013 - 09:00 AM
#663
Posted 28 July 2013 - 11:01 AM
#664
Posted 28 July 2013 - 11:27 AM
I would rather have that than the high temps in getting on track, Will give the stat a go and update when I've done it, Where is best place for it??Triple pass rad is only good for track and will not run at its he's in stop start traffic. I had the upgraded thermostat on my SC and only ever got 98 on track. It would run 92-94 on road and of you hit 80mph upwards it would drop off the scale down to 78!
#665
Posted 28 July 2013 - 03:24 PM
#666
Posted 31 July 2013 - 02:40 PM
#667
Posted 08 August 2013 - 11:05 AM
#668
Posted 08 August 2013 - 02:53 PM
Water wetter does help add to charge cooler tank and rad header tank
#669
Posted 08 August 2013 - 02:55 PM
Do you mean a watery mixture rather than 1-1 make it 2-1 in favour of waterWater wetter does help add to charge cooler tank and rad header tank
#671
Posted 08 August 2013 - 03:01 PM
He means something called water wetter, which supposedly reduces surface tension. Personally I wouldn't touch the stuff as it isn't tested for seal compatibility.
#672
Posted 08 August 2013 - 03:02 PM
No its an additive to the cooling system. I'm personnaly very sceptical...
http://www.thetrutha...etterĀ®-review/
Even it was effective in the engine cooling circuit, I think its highly dubious it would make any difference to chargecooling performance..
#673
Posted 08 August 2013 - 04:30 PM
Agreed. The charge cooler does very little to start with.
#674
Posted 08 August 2013 - 04:34 PM
#675
Posted 08 August 2013 - 05:40 PM
#676
Posted 08 August 2013 - 06:00 PM
Wouldn't air be more swirly than direct if air was there because of low pressure.You need to think about air flowing from high to low pressure. It probably works more evenly than you think.
#677
Posted 11 August 2013 - 08:20 AM
Edited by CHILL Gone DUTCH, 11 August 2013 - 08:28 AM.
#678
Posted 11 August 2013 - 02:20 PM
#679
Posted 12 August 2013 - 09:12 AM
#680
Posted 14 August 2013 - 05:07 PM
