Project Chill 1
4396 replies to this topic
#681 D3YMO
D3YMO
    Scammer
  • 1,554 posts
  • Interests:Cars, Gym, Basketball, Football, LFC, Usual Stuff...
Posted 14 August 2013 - 05:26 PM
Ive just been speaking with Vocky...this seems to be the most sensible option for me to opt for...i can keep the engine and m62 setup i have now (safely running 262bhp) and buy and rebuild a brand spanker for the same price or modding my current one...and if needed, sell my current one to recoup costs
It means i can keep the car running too and gives me something to tinker with in my own time and at my own pace
#682 CHILL Gone DUTCH
Posted 14 August 2013 - 05:30 PM
Ive just been speaking with Vocky...this seems to be the most sensible option for me to opt for...i can keep the engine and m62 setup i have now (safely running 262bhp) and buy and rebuild a brand spanker for the same price or modding my current one...and if needed, sell my current one to recoup costs   It means i can keep the car running too and gives me something to tinker with in my own time and at my own pace
Do you need the lsj ecu to and a external trigger wheel
#683 D3YMO
D3YMO
    Scammer
  • 1,554 posts
Posted 14 August 2013 - 05:43 PM
One for Vocky that mate...think we should have a 3 way to discuss :lol:
#684 2deano5
2deano5
  • 668 posts
  • Interests:Cars / Squash
Posted 14 August 2013 - 05:49 PM
Not if you change the crank to the z22se one
#685 CHILL Gone DUTCH
Posted 14 August 2013 - 05:55 PM
Deano are you doing this 2 Deymo and Deano are you both on Dutch software
Edited by CHILL Gone DUTCH, 14 August 2013 - 05:56 PM.
#686 CHILL Gone DUTCH
Posted 14 August 2013 - 06:09 PM
I just need to no what the full financial impact would be to get the b207 to fire up with the M62 in my car
#687 vocky
Posted 14 August 2013 - 06:11 PM
roughly £1k less than using an old z22se :)
#688 CHILL Gone DUTCH
Posted 14 August 2013 - 06:14 PM
And I would have new engine
#689 ArticMonkey
ArticMonkey
  • 4,792 posts
How is that saving made vocky roughly?
#690 CHILL Gone DUTCH
Posted 14 August 2013 - 06:15 PM
No reboring costs and the engine already would have most of the parts on from new
#691 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 14 August 2013 - 06:20 PM
Rebore is only £125. Do them engines come with starter motor and water pump?
#692 oakmere
oakmere
  • 2,143 posts
Posted 14 August 2013 - 06:30 PM
Also can't understand the maths on that one? I thought all Wiseco pistons required machine work for the reasons mentioned in the other thread. It makes a lot more sence if the std internals of the new engine would take the power.
#693 CHILL Gone DUTCH
Posted 14 August 2013 - 06:37 PM
Because the engine would be new you wouldn't need A quick breakdown of some parts required to rebuild an old z22se engine shows it's the cheaper option; rebore - £150 crank bearing shells - £100 oil pump - £300 water pump - £75 rear main oil seal - £35 saab sump - £65 saab head - £200 timing chain - £185 balancer chain - £130 oil pump gasket - £20 crank pulley oil seal - £10
#694 vocky
Posted 14 August 2013 - 06:38 PM
that's a total of £1260, then if you use the sodium filled saab valves instead of paying £400 for some from the states that makes a rough total of £1660
then you could keep the brand new springs and save another £350 if you don't plan on going past 7200 rpm, so a saving of about £1k
Edited by vocky, 14 August 2013 - 06:40 PM.
#695 CHILL Gone DUTCH
Posted 14 August 2013 - 06:44 PM
that's a total of £1260, then if you use the sodium filled saab valves instead of paying £400 for some from the states that makes a rough total of £1660   then you could keep the brand new springs and save another £350 if you don't plan on going past 7200 rpm, so a saving of about £1k
Could save on cams if I bought the b207R engine I think
Edited by CHILL Gone DUTCH, 14 August 2013 - 06:44 PM.
#696 vocky
Posted 14 August 2013 - 06:47 PM
saab cams are shite :blush:
Mr T tried some b207r ones and lost power :ninja:
#697 CHILL Gone DUTCH
Posted 14 August 2013 - 06:48 PM
saab cams are shite :blush:   Mr T tried some b207r ones and lost power :ninja:
Ok scrap that
#698 ArticMonkey
ArticMonkey
  • 4,792 posts
Chill, you might as well go the whole hog and get comp cams. You're going to want super tech springs also to get that high rev range. Do you think we could get something off these engines if one of us said we wanted 3-4?
Edited by ArticMonkey, 14 August 2013 - 06:49 PM.
#699 CHILL Gone DUTCH
Posted 14 August 2013 - 06:49 PM
Chill, you might as well got the whole hog and get comp cams. You're going to want super tech springs also to get that high rev range. Do you think we could get something off these engines if one of us said we wanted 3-4?
I can't see advantage of going above 7200 rpm with m62 charger
#700 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 14 August 2013 - 06:50 PM
You said not lag ago that you'd never go stage 3, you'll have a harrop before the years out. ;)
6 user(s) are reading this topic
0 members, 6 guests, 0 anonymous users
