I'm going to have to rather do some grovelling to wife or do some saving up first, My engine us nearly 12 years old 65k miles and on original chain It seems daft to spend money on that when I can have a brand new engine.You said not lag ago that you'd never go stage 3, you'll have a harrop before the years out.
Project Chill 1
#701
Posted 14 August 2013 - 06:52 PM
#702
Posted 14 August 2013 - 06:55 PM
Chill, you might as well go the whole hog and get comp cams. You're going to want super tech springs also to get that high rev range. Do you think we could get something off these engines if one of us said we wanted 3-4?
I think you should ask the question, lets face it nobody on here will want the inlet and exhaust manifolds so they might do a deal for 3 or 4 engines. I know there are at least three people considering buying one and if the price was right I might buy one for a spare
Edited by vocky, 14 August 2013 - 06:56 PM.
#703
Posted 14 August 2013 - 07:03 PM
Edited by ArticMonkey, 14 August 2013 - 07:03 PM.
#704
Posted 14 August 2013 - 07:07 PM
Thumbs upright might be worth mentioning on z22se to Mr vocky would you please break down the full cost for me in a PM if you like I could always get in on GB if it saves money but I might just have to buy the parts then save up more for installation,Ill send a message to the seller. I could also collect them all and deliver them to the vocky workshop to save on postage cost? I'm sure you've got space for Neil.
#705
Posted 14 August 2013 - 07:17 PM
I may be interested too.
#706
Posted 14 August 2013 - 07:24 PM
Not if you change the crank to the z22se one
Would be very curious to this one.
So far i have only seen external trigger wheels to use z22se ecu.
Swapping the crank with the trigger over would be so much nicer. (if posible)
Edited by smiley, 14 August 2013 - 07:25 PM.
#707
Posted 14 August 2013 - 07:26 PM
#708
Posted 14 August 2013 - 07:38 PM
Would be better in long run as I will have a new engine, Mine is old requires work chains etc possible water and oil pump Probably not worth pushing this engine any more than I already haveYes I can understand that it is cheaper if replacing every item and then sell the z22se engine afterwards. But a lot of those items will probably be fine. Vocky are you sure the Wiseco std bore pistons drop straight in on a new engine? If so why don't people just get the block honed and fit the std bore pistons?
#709
Posted 14 August 2013 - 07:44 PM
#710
Posted 14 August 2013 - 08:24 PM
Edited by oakmere, 14 August 2013 - 08:25 PM.
#711
Posted 14 August 2013 - 08:36 PM
#712
Posted 14 August 2013 - 08:37 PM
It's 3k for a new standard z22se from stealers Was planning on doing a other 20 k miles on my engine over the next 3 years before upgrading, It might take me that long to save up for all the bit for the Saab lump It would be ready for a harrop It's annoyed me that I have had to turn my engine down to save it plus I could sell the z22se motor the way it is if I have a engine ready to go in Just waiting for a final estimate to convert to Saab lump from vockyYes it would be nice to have the reliability of a brand new engine. But all getting very expensive for 30bhp, £1000 per 10 bhp sounds like N/A tuning. Unless this is all leading to a Harrop?
#713
Posted 14 August 2013 - 08:48 PM
#714
Posted 14 August 2013 - 09:01 PM
I still think it was Joe's piston that failed first and not a rod on his spectacular engine failure at 270bhpI would love to know what the std pistons would take SC. We know they failed at 300bhp with NOS but this is much harder on internals. Anyone know of a piston failure?
Rods and crank are definitely better.What will the std Saab internals take? Assume they are better than the std Z22se.
Every Saab tuner I've spoken to has said the pistons in the B207 need upgrading over 320bhp (in a turbo setup anyway). Doesn't entirely match with the experience of the LSJ guys but we've no idea if they're actually the same pistons on both, or whether they're just the same dimensions. Though that does tie in with GM's component failure mode chart.
#715
Posted 14 August 2013 - 09:14 PM
And that guys, is why 250 is the sweet spot.
#716
Posted 14 August 2013 - 09:17 PM
And why it gets totally nuts when you start aiming at 400bhp.And that guys, is why 250 is the sweet spot.
#717
Posted 14 August 2013 - 09:20 PM
Which we are all pushing by running 260isch with an extra 30 parasitic loss of the SC.
Without blowing anything up, and thrashing them on the track.
#718
Posted 14 August 2013 - 09:29 PM
#719
Posted 14 August 2013 - 09:33 PM
#720
Posted 14 August 2013 - 09:39 PM
It's hard to go back though. It's a similar situation with the car market as a whole, they were more fun with less power and actual connections to the engine and chassis, but if anyone made something like that now everyone would complain that it's underpowered and unrefined.
