Project Chill 1
#741
Posted 15 August 2013 - 06:27 PM
#742
Posted 15 August 2013 - 06:29 PM
But what's the point. You need to press in the new sleeve and then machine them which you can't ezactly do in the car.Can also be done in the car...
#743
Posted 15 August 2013 - 06:54 PM
Nop, the GM sleeves come pre-honed to factory spec bore and only require a top trimming to a little above the deck. (there's a small cutter in the toolkit for that purpose)
Search for GM part 88984129.
(Wanna borrow our GM toolkit? )
#744
Posted 02 September 2013 - 05:38 PM
Pic from the asda charity do,
Going to get stuck in tomorrow brakes need bleeding and I have also new pads have glazed .
Will also have to fit new arch linear and it should be almost ready to drive again,
#745
Posted 02 September 2013 - 07:11 PM
Edited by haggi961, 02 September 2013 - 07:11 PM.
#746
Posted 02 September 2013 - 07:13 PM
It's set up for 16/17 That's why a ripped the arch linear out because I ran the 17 all round for the charity do but ended up going balls out.Looks low mate but looks well.
#747
Posted 01 October 2013 - 04:44 PM
#748
Posted 01 October 2013 - 05:37 PM
#749
Posted 01 October 2013 - 06:07 PM
Yes it does Got a free tire and hoist brackets and a bit of seatbelt toFook me you don't hang about!
It still has the inlet attached.....?
#750
Posted 01 October 2013 - 06:09 PM
#751
Posted 01 October 2013 - 06:11 PM
Unsure 2.2 at moment, But I have had second thoughts because the internals in this engine are better than I fist thoughtAre you keeping it 2l or going 2.2?
#752
Posted 01 October 2013 - 06:18 PM
Don't think engine capacity is really limiting factor with these engines, you'll get a faster revving engine as a 2.0 and higher rev limit. If you look at the GM build book they take is from 2.2 to 2.0 for that very reason.
#753
Posted 01 October 2013 - 08:39 PM
#754
Posted 08 October 2013 - 09:55 AM
#755
Posted 08 October 2013 - 10:01 AM
#756
Posted 08 October 2013 - 10:33 AM
Is there any negative to keeping it 2.0L? Like less torque or summut?
#757
Posted 08 October 2013 - 10:41 AM
You will get less torque, but it will rev higher
#758
Posted 19 October 2013 - 10:49 AM
Thanks JT
#759
Posted 02 November 2013 - 10:48 AM
#760
Posted 02 November 2013 - 10:56 AM
Do the large black bolts need removing
